Reached the 50mpg mark!!! Yeah!!!
Discussion in 'Gen 3 Prius Fuel Economy' started by GreenGuy33, Mar 21, 2010.
  1. plumeria
    plumeria Junior Member
    New York
  2. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    Good job everyone keep up the good work!!!!!!!!!!!!!!!!!!!!!!
  3. Skoorbmax
    Skoorbmax Senior Member
    2,641
    264
    Western NY
    We have 350 on the odo now. Best I've done is about high 50's myself over a fairly short trip but I was going _really_ slowly. It was a Sunday morning and I was driving on the left hand side of eco almost all the time.
  4. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    I do.
    sunnyside MS - Google Maps
    But I carry so much in my car that I average 42 MPG.
  5. Tom183
    Tom183 New Member
    652
    65
    Maine
    I got 54.0 (displayed) on a highway trip yesterday, doing 73mph or so most of the way - sunny near 60F. Might have had a slight tail wind, but it was also uphill a bit too.
    The return trip was a different story - foggy and 45F. Averaged 46 mpg (displayed), so my total trip hit 50mpg flat (displayed). Going to start another thread about that...
  6. Erikon
    Erikon Active Member
    819
    105
    Rochester, NY
    Actually saw over 70 MPG (displayed) yesterday, around town driving! Gotta love the warm weather!
  7. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
    I have a Gen II and a long highway trip usually nets me 54+ MPG with cruise set at 69 MPH for most of the way. I have done this on several trips from Akron, OH to Virginia Beach (without even having to stop for fuel) and many trips from Akron to Columbus or Cincinnati. If you can stand to set at 55 - 60 MPH especially when driving through city interstates you could easily see 60 MPG on clear days.
  8. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    My commute has some flat sections (San Mateo Bridge), but the rest are hills, including a long one (the Dublin grade). My commute is about 85% highway 15% city/stop&go. Weather was varied (some clear days, some rainy days, some "cool" days (42-45F). I averaged 57 mpg (calculated).
    The trick is slowing down.
    You may not want to do what I do, but it works. I drive in the right hand lane....55 mph. I've been doing that for 4 years now. My old Integra was averaging 38 mpg on this same commute over a 2 year period. So my mpg's went up by nearly 20 with the new car.
    Try slowing down 5 mph from your current speed. The overall difference in speed won't make a appreciable difference in your commute time, but your MPG's might increase by 2.
  9. Tom183
    Tom183 New Member
    652
    65
    Maine
    The biggest influences on mpg:
    1) temperature
    2) rain
    3) tires (type and pressure)
    4) distance
    5) speed
    As noted above, I got 54mpg displayed on a highway trip doing 74mph most of the way - but the weather was both warm and dry, my tires were firm (>40psi), and the distance was well beyond the warm-up range.
    Speed is only one factor, but it is one of the only ones you can control - tire pressure is the other.
  10. Rebound
    Rebound Senior Member
    3,991
    2,638
    Portland, OR
    Driving technique matters a lot as well. Slow acceleration versus jack rabbit stops & starts not only improves your mileage, but affects your vehicle's longevity.
    Example: The highest performing cars are Formula 1 racers. They use all sorts of ultr-expensive, super-durable metals, and yet, in the Indy 500, they are driven so hard in 500 miles that 1/3 of them experience mechanical failure. Drive hard enough, and your car won't last 500 miles. Mash the acceleror, stomp the brakes, and careen through every turn, and you'll wear any car out before its time.
  11. toyolover
    toyolover Member
    441
    67
    toronto, canada
    4.1L/100km - wow, impressive. I am in Ontario/Toronto and have my Prius 2010 since last November. The lowest fuel consumption showing on the computer is 4.9L/100km. The actual consumption, according to my own calculation on every fill up, is actually about 5.15L/100km last week.
    Are you using regular or premium gas? What tire pressure do you have on front and rear tires? I am wondering if these are the factors for higher fuel efficiency.
  12. toyolover
    toyolover Member
    441
    67
    toronto, canada
    I can't imagine my 2010 will get the fuel efficiency as low as your 2007. May be I need a couple years for breaking in period in order to get your mileage. It's amazing you can get the consumption number so low. BTW, are you reporting the computer consumption number or from your actual calculation between fill ups?
  13. Tideland Prius
    16,466
    You must master P&G young one hahaha.
    On my 2010, my first dealer tank was 4.2L/100km on the computer (i tihnk it was 4.5L/100km calculated by hand). IT's definitely more efficient than our 2005. (I'm still aiming to break my record of 3.9L/100km but that'll take some time as parts wear in)
  14. Quinlan00
    Quinlan00 Junior Member
    2014 Prius c
    I've only had my Prius for two weeks, but I've been able to get over 50 mpg on both my refills by simply paying attention to the Hybrid System indication, and trying to stay out of the 'power' area.
  15. toyolover
    toyolover Member
    441
    67
    toronto, canada
    No kidding? 3.9L/100km:rockon:
    How long did you have to break in the engine to achieve that? You seem to have the Gen2 which has a smaller ICE. Could that be the reason? I use the ECO mode about 60% and the factory default mode for 30% and Power mode for 10%. Highway driving is about 70%. The Gen3 seems to use less gas when it is in city stop and go traffic, am I right about this?
  16. Tideland Prius
    16,466
    Oh it took 3 long years for me to work on P&G and I just happen to have a nice long commute route that summer which incidentally, included a mountain which makes that 3.9L/100km achievement even more amazing. Tyres were worn down (replaced them the following year) so maybe that has a part in it. The calculated was very close.. 3.9L/100km as well (I can't remember the 10th digit off the top of my head).
    I don't know.. the new 2010 still netted me 4.2 on the dealer tank despite having a larger engine (and it's also heavier than my 2005 b/c of the extra equipment like the solar roof and radar). I'm definitely looking forward to summer (though my tyres still need to be broken in as I've been using winter tyres). Up and over the Rockies netted me 4.3L/100km as I approached Kelowna from Calgary. Pretty sick.
    Oh and my record tanks are all 100% city driving
  17. Oakmont
    Oakmont New Member
    26
    Pittsburgh
  18. TheSpoils
    TheSpoils Member
    304
    49
    New Jersey
    In the 2010 Prius [ 80F temps + 65mph highway + 44psi ] = 60.3 mpg for 563 miles
  19. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    Fantastic!
