Gen3 PHEV optimum mpg is all about HEAT
Discussion in 'Gen 3 Prius Accessories and Modifications' started by dan2l, Apr 3, 2010.
  1. dan2l
    dan2l 2014 Prius v wagon
    653
    263
    Vancouver Wasington
    2014 Prius v wagon
    Hello Everyone,
    I have installed an Enginer PHEV kit into my wife's 2010 Prius IV. Now I am learning about optimizing the Mileage. I have come to believe that optimum mileage is all about heat. That is, ICE temp is becoming a major factor in getting the best mileage.
    I think that today the Enginer system may be the only PHEV to work with the Gen3. I expect other more expensive systems to adapt to the Gen3 when they get the programming matched to the Gen3 computers. However, I think that this issue of ICE temp is going to be a factor for all PHEV systems so I would like to keep this open to all PHEV systems.
    First some of my data.
    You see that I have a range from 60mpg to 100mpg.
    The 60mpg is my wife driving it as if it were a normal car. The PHEV usage is limited because the ICE is on a lot to keep the heater and defrost going.
    The 90+mpg are for times where I could optimize the use of the electric motors and keep the ICE off for long periods of time. During this time the ICE temperature drops and eventually this kicks the ICE on and lowers the mileage.
    I have a ScanGauge and I do significant grill blocking. I do not yet have a EBH. Every thing else is stock.
    Thanks,
    Dan Lander
  2. 5power
    5power Junior Member
    74
    cleveland
    Good work and write up Dan, so its all about regulating engine temps.... The more heat the better, engine stays off. How does the Phev work on the highway, and does the battery last the life time of the car? I look on their website and it's 2k for the kit right? I do mostly highway commute I wonder if I should invest in one? Does it give u a boost in power on the low end? I find it hard for me to stay in EV mode on the streets. Are you happy with the kit?
    Sorry for all the questions, I've never heard of this until your post. Thanks again for any feedback... Brandon
  3. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    At the extremes of hot and cold, the temps, "heat," of the HV battery, or
    batteries, will also have a negative MPG effect. :(
    At the cold end, the batteries are slow to discharge/recharge until they
    reach maybe 45 or 50 degF -- after a night-long winter night "cold soak."
    On the hot end, oh, maybe 100 degF, the batteries have reduced
    capacity -- after a long "hot soak" in an uncovered summer parking lot.
    In both cases, propulsion will require more ICE power and reduced MPGs
    until the HV battery/batteries are stabilized at "normal" temps.
    IIRC, the Nissan Leaf monitors the battery temps during charging
    and heats/cools its batteries as needed to provide full power at least on
    initial start up.
  4. dan2l
    653
    263
    Vancouver Wasington
    2014 Prius v wagon
    Hi Brandon,
    The Enginer Systems are $2k for the 2kwhr kit and $3.5k for the 4kwhr kit. This price includes $500 for normal installation. I have the 4kwhr system installed in my wifes 2010.
    I have not done 60mph. At 50mph I see normal mpg during acceleration then about 100mpg at constant speed flat and level. At 50mph the ICE is spinning but not providing much power. At 42mph it will run constant speed flat and level with the ICE off. For these high mpg's you can do about 5 miles before the Prius decides it needs to recharge its HV battery and pulls power from the ICE lowering the mpg. In the case of 42mph with the ICE off, the temp also drops during the 5 miles to the place that the ICE also runs to warm itself back up.
    The Enginer batteries are LiFePo4. They are spec'd for 2000 cycles.
    PHEV kits do not give more power. They only let you use electrons instead of some of the gas.
    The Enginer system is simple. It does not change any of the Prius programing or do any spoofing.
    Thanks,
    Dan Lander
  5. linuxpenguin
    linuxpenguin Active Member
    352
    182
    Hi Dan,
    Have you tried driving with the heater / defroster on yourself? I would recommend trying to drive the vehicle with said heater on and see how it impacts your known mileage. I suspect you'll find that driving habits play a more significant role in mileage results as you touched on in your other thread.
    Heat certainly plays into how often the Prius uses the gasoline engine, but it also has a lot to do with acceleration speed and how accustomed you are to doing simple things like backing off the pedal
    and reapplying pressure to turn the engine off.
    The new Gen3 Prius warms up much faster than the Gen2 because it recirculates the exhaust (no more coolant thermos). It's also more efficient at lower RPMs than the Gen2 was due to the new engine (so the heater usage shouldn't impact mileage as much on the Gen3 as on the Gen2 in other words).
    I assume when you say "driving it as a normal car" you are referring to more normal pedal acceleration speed as well?
    EDIT:
    Battery efficiency is also directly impacted by temperature as well--I agree with Rokeby on that point. The question is how much of a temperature swing is there on your batteries. For Nickle metal hydride there is a pretty big efficiency dip when it's cold. The same is true for Lithium, though typically not as bad (can't say for sure on the batteries you have, all chemistries are different).
    The vehicle limits how much power goes in and out of the batteries when it's cold--for example, driving the car when the batteries are around 0F, you are basically driving purely with the gasoline engine since the wattage out goes effectively to zero. Typically it starts to decrease around 65F.
    Andrew
  6. dan2l
    653
    263
    Vancouver Wasington
    2014 Prius v wagon
    Hello Rokeby,
    I am speaking of ICE temperature, not battery temperature.
    The PHEV systems do not change or effect Prius HV battery temps. If anything the PHEV batteries keep the Prius HV battery at a more constant charge state and temperature.
    I am confident that I am not seeing any issues with battery temperatures.
    Thanks,
    Dan
  7. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    Dan,
    I don't think that we're at odds here. I acknowledge that what you've
    said fits nicely with what is know about the HSD operating algorithms.
    Once the ICE kicks on, the HSD keeps an eye on ICE and catalytic
    converter temps and will as necessary run the ICE apparently solely
    for the reason of keeping those temps up. While the Enginer system
    does not do any active spoofing, the additional HV power does create
    conditions, extended running as an EV, where the ICE and CC temps
    would fall below the HSD-set lower limits and the ICE kicks on. All this
    is fine and well.
    The basis or my earlier post is that environmental conditions -- they
    can be simplified to the ambient temperatures in the cabin and HV
    battery box -- affect the HV battery. I did not mean to imply that
    temps in your HV batteries have a direct affect on each other.
    After a night-long cold soak at 0 degF it can take 30 miles to get the
    HV battery up to normal temps. This has a direct affect on MPGs seen
    during the period.
    Not to take this into mind would lead to a belief that the ICE had a
    problem... not so. (The HSD takes an active role is raising the Prius
    HV battery temps. It tries to raise the SOC to ~65%, and uses lots
    of small discharges and charges to heat the battery internally.)
    It sounds like you are doing a great job wringing the best FE/MPGs out
    of your Enginer augmented Gen III. Well done... :rockon:
    I'm more than a little envious, I can only just barely hold 50 MPG as a
    year 'round average on my Gen II. Such is life.
  8. dan2l
    653
    263
    Vancouver Wasington
    2014 Prius v wagon
    Hi Andrew,
    Yes, of course I have tried driving with the heater / defroster on!
    Your comments make it clear to me that you have missed the point. The point is that as we use PHEV to maximize mpg, the ICE runs so little that it never fully heats up.
    Yes the Gen3 heats the catalytic converter quicker. But it does not heat the ICE water to the 149degF point when being used in modes to maximize use of the electric motors. Having the heater on clearly stopped this heating progress in my experience. I can see all of this on my ScanGauge.
    I do use maximum grill blocking. But a short stop or a long run below 42mph with electric only still allows the temp to drop low enough that EV mode kicks out at 11 mph. Without EV mode it is not possible to get enough acceleration to drive with traffic without kicking the ICE on.
    When the temp is up, I can push the EV button and accelerate to 25mph reasonably and then use a light foot between 25mph and 42mph to drive in town traffic with the ICE never coming on.
    Thanks,
    Dan Lander
  9. banshee08
    banshee08 Member
    284
    72
    El Monte, CA USA
    Dan,
    ICE temp is very critical to MPG. I have learned over the last 6 months with the Enginer System is that during my nightly commute home which is mostly EV mode for about 35 miles. My coolant temp can drop to about 100F and if I am not light on the pedal the ICE will start up. It will keep running until it reaches about 130F and then I have EV mode until 45mph. I am planning to do some grill blocking next winter. For now I have adapted my driving to monitor coolant temps also since springs is here in So. Calif. Someone, I think Ken(from Japan) did post up a schematic of a device to trick the ECU on the coolant temps with a variable resistor but I am not too clear.
    -Chan
  10. linuxpenguin
    352
    182
    *sigh*, Sorry Dan I didn't mean to touch a nerve again but there's no need to get upset. All I'm saying is that I believe the driver aspect (pedal behavior more specifically) is more important than the ICE temperature. An easy way to determine this would be to plot your own MPG averages with and without the heater on for similar (ideally the same) drives. This would establish your driving style and habits as a control environment and thus show how much of a factor said engine temperature actually is (obviously you must let the ICE cool off equally between runs or else it will invalidate the results).
    I don't think anyone--myself especially included--will dispute the fact that ICE temperature plays heavily into maximizing mileage.
    The title of the thread makes it sound like getting best mileage is entirely dependent on the ICE temperature but I disagree--I think it much more depends on the drivers individual habits and routines than anything else (within reason of course). This is all that I am suggesting.
    Andrew
  11. dan2l
    653
    263
    Vancouver Wasington
    2014 Prius v wagon
    Hi Andrew,
    Between 60mpg and 70 mpg I would agree that optimization depends more on the driver. But once a driver is good enough to get up in to the 80mpg range then ICE temp is much more important.
    Thanks,
    Dan
  12. dan2l
    653
    263
    Vancouver Wasington
    2014 Prius v wagon
    Hello Everyone,
    I have been driving my 2010 Prius PHEV now for a couple more weeks. I have learned to better judge how far it will go before the 4kwhr battery pack needs to be shut down.
    Today I was doing a drive where I figured that I would need to turn off the Plug-in pack about 4 miles from home. So I did not try to maximize EV. The change I made was to not push the EV button at every stop. So the ICE would come on for the acceleration then I used the gas peddle (let off quickly below 42mph and then ease back on) to keep the ICE off the rest of the time.
    I found that the ICE temp came up and stayed up much better. As a side note, I was not using the heater. The short cycles on the ICE held the temp up better and also improved the range by not using the batteries as harshly during the acceleration. I did get farther, to within 1 mile of home so I am guessing a 3 mile improvement.
    The surprising thing is that my gas mileage did not go down. It appears that I had enough improvements in temp and in efficiently to make up for the short times of burning gas on those accelerations.
    Thanks,
    Dan
