Chassis Stiffening Plate
Discussion in 'Newbie Forum' started by timkf1, Apr 6, 2010.
  1. timkf1
    timkf1 New Member
    Cincinnati
    I am new to Priuschat, so I don't want to start any arguments, but as most noob's I am very skeptical. I have read many positive things about the BT Plate and quite honestly dont understand why it WOULD work.
    Looking at the chassis plate, I can't see that it does anything. It can't do anything but keep the bottom of the tunnel from spreading or pinching, which the factory piece is obviously adequate for. That only leaves racking (where the left side goes forward and the right goes back, or vise versa in the same plane). But since it bolts into the same two holes, it seems to me it would not add stiffness there, either. To add racking resistance, the bolt holes on each side would have to be further apart, front to back (look to be only about 2 inches spread on each side). First user comment I found was a guy who did a blind test using his wife as the guinea pig--gave her wrong verbal info about what brace was installed and she gave him her impressions that were consistent with his info, not the actual part in the car. In fact she though it was best with no brace at all when he told her the BT brace was in there. So even if it does something, it is a very small bang for buck.
    Can anyone give me scientific feedback or do I just have to go waste $150.00 and then sell it for half price to some other sucker only to have thrown away $75.00 in the end?:confused:
  2. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
  3. timkf1
    timkf1 New Member
    Cincinnati
    I appreciate the response. So, how thick does aluminum have to be to achieve the same rigidity as steel? I mean, I think the only reason the aluminum plate is thicker is because if it were the same thickness as the factory original, it would just tear in half under stress. On the same note, the factory steel is thinner because it doesn't have to be as thick to provide the same rigidity.......
    I'm seeing a Mythbusters episode in my near future............
  4. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    Steel has wonderful tensile strength, aluminum, not so good. (some alloys do fine)
    [ame="http://en.wikipedia.org/wiki/Tensile_strength"]Tensile strength - Wikipedia, the free encyclopedia[/ame]
    However in Flexural Strength, thickness is squared, so the thicker Aluminum is much more resistant to flexing.
    [ame="http://en.wikipedia.org/wiki/Flexural_strength"]Flexural strength - Wikipedia, the free encyclopedia[/ame]
    I could not make heads or tails of Wikipedias article on deformation, which is the strength I think the steel part lacks.
    Deformation (engineering) - Wikipedia, the free encyclopedia
    Sorry.
  5. San_Carlos_Jeff
    San_Carlos_Jeff Active Member
    871
    160
    Northern California
    2012 Chevy Volt
  6. dogfriend
    7,512
    1,189
    Carmichael, CA
    You picked a great topic. :madgrin:
    I'm sure there is no controversy about this topic. I can't possibly see an argument breaking out over this. :madgrin: :D
  7. dogfriend
    7,512
    1,189
    Carmichael, CA
    Hopefully you aren't cornering hard enough to permanently deform the plate. :madgrin:
  8. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    I am hoping even the steel plate stays in elastic deformation, not plastic deformation. I am hopeing the aluminum plate does not deform.
    I noticed cross winds have MUCH less effect on my driving, even if that is all placebo, it is a good thing.
  9. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    There is also this much shorter thread.
    ...[ame=http://en.wikipedia.org/wiki/Perception] perception [/ame]...
    You pays your money and you takes your chances.
    YMMV :p
  10. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    OMG, it's ALIVE!!!
    RUN!! RUN FOR YOUR LIVES!!!!!
    [I have a BT plate, and love it]
  11. patsparks
    10,664
    567
    Adelaide South Australia
    Be as sceptical as you like, I was also a sceptic but got a BT plate second hand quite cheaply so gave it a try and I am a convert. No, it won't make a Prius handle like a Maclaren F1 but there is a noticeable improvement.
    As has been said earlier in this thread and countless others, the aluminium plate seems to be more resistant to flexing under compression than the steel plate. Because the firewall is attached to the front strut towers I am not sure how much value there is in a front strut brace but plenty who have fitted this part have said it makes a difference for the better too.
  12. timkf1
    timkf1 New Member
    Cincinnati
    I don't plan on Autocrossing my Prius, but I'm about to sell a Z06 corvette and just want to improve my everyday drive without wasting $$$$. I appreciate all the comments! My Corvette is my "fun" car to drive, and if I'm selling it, I'd like to increase the fun in driving my Prius on a daily basis. Thanks a million everyone!
  13. hyo silver
    hyo silver Awaaaaay
    15,268
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    Coming from a Vette, you're bound to notice a few handling shortcomings of the Prius. It's great at what it was designed for, but a sports car it ain't. There are many ways the handling can be improved, and a BT plate is one of them. Granny on her way to the bingo hall isn't likely to appreciate the difference, but someone used to a Corvette likely would.
  14. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Prius and Corvette, what a combo. They have #1 and #2 highest owner satisfaction.
  15. kmc6566
    kmc6566 Junior Member
    61
    England, AR
    I'll add my 2 cents since I also bought the stiffening plate from the guy on ebay for $60.
    I would totally recommend it. I feel it does corner better now but for me the most noticeable difference is with crosswinds at highway speed.
  16. Presto
    Presto Has his homepage set to PC
    1,326
    24
    Vancouver, BC
    Go full out and get all the chassis braces, and suspension! It'll vastly improve cornering, and definitely increase the fun factor.
  17. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    Some things to think about adding:
    1. Cheaper Stiffening Plate ($59):
    Toyota Prius G7 Performance Stiffening Plate 2004-2009 : eBay Motors (item 120550358780 end time Apr-08-10 20:58:19 PDT)
    2. Thicker Touring Edition Front Stabilizer Bar ($75) and Rear Stabilizer Bar ($49):
    http://priuschat.com/forums/gen-ii-prius-main-forum/41925-touring-suspension-parts-research.html
    3. Strut Tower Brace (Tanabe $159 plus shipping; BT Tech $250 including shipping; TOM's $289 plus shipping; the Tanabe brace is a straight across design while the BT Tech and TOM's braces are a bowed and apparently thicker design):
    http://priuschat.com/forums/gen-ii-...-strut-tower-brace-install-pictures-text.html
    [​IMG] BT Tech Strut Tower Brace Install - By GadgetDad (Lee) v2.doc
    A. BT Tech ($250 including shipping) (but currently not in stock).
    PriusChat Shop : Toyota Prius BT Tech Strut Tower Brace - $250.00
    B. Tanabe ($159 plus shipping) and TOM's ($289 plus shipping):
    Toyota Prius 2004 ~ 2009 NHW20 Performance, Handling & Electronic Accessories :: Sigma Automotive
    I have the BT Tech Stiffening Plate and the BT Tech Strut Tower Brace. You'll notice improved handling more from the Strut Tower Brace than from the Stiffening Plate.
    I think I will be replacing the standard stabilizer bars with the thicker Touring Edition bars.
    Good luck.
  18. 200Volts
    200Volts Member
    439
    46
    Northern CA
    My guess is the BT plate helps most in reducing the chassis twisting during crosswinds or cornering. The thicker the plate, the better it resists twisting (i.e a piece of paper, versus a 2x4 of wood).
  19. timkf1
    timkf1 New Member
    Cincinnati
    You all are full of info, and good info at that! I know, I get all kinds of raised eyebrows from fellow workers at my Toyota Dealer I work at. They all asked me to take a pic of my garage so they could see them sitting next to each other. I think I'm convinced, and I've already ordered the Tom's stabilizer bar....waiting impatiently....I just couldn't wrap my head around the science behind the stiffening plate.
  20. Genoz World
    Genoz World ZEN-style living
    797
    22
    La Canada
    STIFFER CHASSIS = allows the suspension to work better. Also, less body roll and chassis flex.
