Can my Prius pull a Uhaul trailer
Discussion in 'Gen 2 Prius Accessories & Modifications' started by jrod81, Mar 24, 2010.
  1. jrod81
    jrod81 Member
    161
    Fayetteville, AR
    Hey guys,
    I found this article: http://priuschat.com/forums/gen-ii-prius-main-forum/9198-you-can-tow-trailer-prius.html
    and that helps but I just wanted to get someone else who has done exactly what I am planning. My wife and I are getting a baby crib, changing table, dresser, and some other odds and ins for our new addition to the family. So, we have to drive from Arkansas to Dallas to get it all (about 750 miles total round trip). I was going to rent a truck but it is too expensive... Simply wondering if anyone has pulled the smallest size uhaul trailer with their Prius.
    I have a 2006 Prius with the trailer hitch from Uhaul that came on the car when purchased.
    thanks for the help
    jared
  2. qbee42
    3,082
    Legally I don't think Uhaul should let you rent a trailer, since the trailer rating for the Prius is zero.
  3. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    It is either legal or completely tolerated to tow a small trailer behind a Prius. At least in the US (and apparently not in Australia). The real question is whether doing it will break something, or shorten the life of the car. My guess is that a 1000 pound trailer can be towed on relatively flat territory at normal freeway speeds. At 2000 pounds, the car will have overheat problems, particularly the transmission. On a long uphill at full power, the traction battery will run low, and you will be left with the gas engine as the only source of power until the load goes back down. This means joining the trucks in the slow lane.
    I'm working on refining those guesses. The first thing I'll be doing is using a ScanGauge to monitor temperatures. I'd really like transmission oil temperature, but I'm not quite sure how to get that. When the temperatures go too high, you have to stop until they recover. I'm also looking into adding an oil cooler for the transmission. Starting a big trip with fresh transmission oil sounds good, and changing the oil after the trip sounds even better.
    As you can see, I think the weakest link is the transmission oil heat dissipation. But there are certainly other weak links, like engine and battery temperatures. The suspension was never designed with towing in mind, so that could be a problem.
    So go ahead and do it! Tell me what breaks before I find out myself...
  4. qbee42
    3,082
    It is legal to tow a trailer behind a Prius. Many of us do so routinely.
    The question was whether a Prius could tow a *Uhaul* trailer. I'm not sure Uhaul will rent one to pull behind an unrated car. I suspect they would face too much liability if something went wrong.
  5. RobH
    RobH Senior Member
    2,385
    991
    70
    Uhaul has some rather obscure policies. I think it's the Ford Explorer that they deem "unrentable". Not that the thing isn't big enough, but they don't like Ford lawyers.
    I haven't dealt with uHaul since the local facility tried to charge me for the 7 miles they drove a truck from another facility before renting it to me. Part of their "solution" to my objection was to double charge me for the same vehicle rented at the same time. I think they make a lot of money with these stunts on people who are already at wits end with a move.:mad:
  6. dogfriend
    7,512
    1,191
    Carmichael, CA
    Yes, they do not rent to Ford Explorer owners but they will rent to Mazda Navajo owners or Mercury Mountaineer owners (both of those are "badge engineered" versions of the Explorer.)
    They will probably rent you a Uhaul trailer for your Prius until someone has an accident and sues. Then they won't rent to any Prius owners anymore. Has nothing to do with safety or common sense.
  7. ravenmaniac
    ravenmaniac Senior Executive VP of Nothing
    156
    DC Metro Area
    Wouldn't it be cheaper and less worrisome to rent a box van from Enterprise with unlimited miles? You don't have the worry of overheating anything on the Prius since it is not designed for towing. One repair on the Prius could cost you three times the price of a box van. I am talking about a full size van, such as a 15 passenger without the seats installed behind the front two seats. They usually run about $60/day and you have no issues to worry about. Plus, you'll save 750 miles on your Prius! Think about it...:rolleyes:
  8. markderail
    markderail I do 45 mins @ 3200 PSI
    2,260
    163
    Pierrefonds (Montreal) Quebec Canada
    I've done it quite a few times.
    It depends on the tow rating of the hitch you have installed. I'm good for 2000 kilos, but, the Prius never could pull that much.
    I rent the smallest one that has a roof and sealed door. Of course, my MPG doubles on the highway pulling it, and I keep my speed at/below 55MPH.
  9. Hytec
    Hytec New Member
    236
    MS Gulf Coast
    You might consider if you are still under warranty. My 2005 Owner Manual states in no uncertain terms that the Prius should NOT tow anything! I don't know anything about warranties for other years. However, it might be very expensive if you had a major drive train problem expecting to be covered by your warranty, only to have the Service Manager show you evidence that you had towed a trailer and present you with a get-serious bill.
  10. Ford Galaxie
    Ford Galaxie Member
    63
    30
    Rome, GA
    2014 Prius v wagon
    Ask question. Get Answer. Yes.
    [​IMG] [​IMG]
  11. deces
    deces Junior Member
    Tucson, AZ
    Sure they would, they will even install a the trailer hitch on your prius too.
