Connecting bolts for....???
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by mrshow555, Apr 13, 2010.
  1. mrshow555
    mrshow555 New Member
    42
    LA
    ...side panel.
    Someone did a hit and run on my car and I was going to replace the panel myself with one from a junk yard. I have the Haynes manual but didn't see the specific section on where the bolts are to take off this (quarter?) panel. It looks like there's one bolt under the hood and two by the door. Anyone know if it's more complicated than that, and if so where are the bolts located, and does anything else need to come off/out in order to access it?
    Thanks!
  2. mrshow555
    42
    LA
    I think I figured it out, the Haynes repair manual instructions on page 11-18 section 25 about the front fender, can anyone confirm this is the part? or is it the front/side quarter panel???
  3. dogfriend
    7,512
    1,190
    Carmichael, CA
    Here is the location of the bolts holding the front fender. There is also a clip shown in the second illustration.
  4. mrshow555
    42
    LA
    awesome you RULE!!!
  5. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    Ow. Too bad you couldn't catch the mf that did that... but yes,
    the bolts holding that piece on are creatively tucked away along
    the edge of the hood opening [fairly obvious], behind the plastic
    fender-liner around the wheel, and inside the door opening.
    I think you might have to partially drop the nose to get at
    one of them -- see this for a vague guide.
    _H*
  6. mrshow555
    42
    LA
    Sweet thanks! and yes I'd like to catch that mf too!
