List of Voice Commands
Discussion in 'Gen 3 Prius Technical Discussion' started by viprius, Jul 24, 2009.
  1. viprius
    viprius Junior Member
    46
    Southern California
    Hi all -
    Sorry if this was already asked somewhere about Gen III Prius but I did not find anywhere.
    Can someone post the list of all Voice Commands that can be used?
    Also, this my experience with my vehicle but, if my LCD Screen is off my Voice command does not activate i.e. when I press the voice button on my steering wheel when the LCD screen is off, nothing happens. Does that mean I have to keep the LCD Screen on to use voice commands?
    Also, just to get me started, please tell me the voice commands to do this (if possible) :):
    1. Search for chinese/mexican/etc. restaurants nearby.(Basically search for POI).
    2. Enter destination address verbally.
    Thanks,
  2. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    There's a few pages of voice commands in the back of the nav quick guide.
  3. yardman 49
    yardman 49 Active Member
    606
    77
    Northern Kentucky
    On the G2s, the entire list of voice commands is available in the "on screen help". To access it, you press the voice command button on the wheel, and then on the Nav screen you press the "Help" button. Then you can navigate through all the various categories of voice commands.
    Maybe the G3 works the same way.
  4. mfischer2
    mfischer2 Junior Member
    Fort Collins, CO
    Can I get the voice command voice to shut-up and stop reading all the commands to me?
  5. stream
    2,977
    452
    Long Island, NY
    Yes--there a setting to turn that off. Can't remember how, but instructions are in the manual. Or you can press the voice command button to interrupt, and continue after the beep.
  6. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    According to my .pdf nav manual if you push "Setup" then "Voice" you should get a list of voice options. Starts on page 242 of the nav manual.
  7. RonJ
    RonJ Junior Member
    Arizona
    viprius
    Here's a list I made up for the commands in excel format
    see if it works for you. I belive you have to have the LCD
    screen on, however I've never tried it with out it on.
    RonJ
  8. Wix
    Wix Junior Member
    Cullman, AL
    Awesome thanks
  9. jayvee
    jayvee Member
    341
    89
    WA
    Link to attachment is not working - could you please re-attach?
  10. PaJa
    PaJa Senior member
    678
    114
    92
    Czech republic
    The link is fine, I just open it.
  11. RonJ
    RonJ Junior Member
    Arizona
    Here you go ... xls & pdf ... the xls you can mod or correct
    any mistakes I may have made.
  12. Anas Almustafa
    74
    28
    Arbela, Irbid, Jordan
    Thanks RonJ, those voice commands were helpful
  13. BadAssPrius
    BadAssPrius I got to make my Prius stand out all on its own!
    CHICAGO, IL
    Thanks for the voice commands guys.
