calculated vs. computer MPG - Please post your results
Discussion in 'Gen 3 Prius Fuel Economy' started by F8L, Jul 10, 2009.
  1. dtuite
    dtuite Silverback
    182
    31
    Redwood City, CA
    Multiply by 0.833 to get Colonial miles per gallon.
  2. Analogkid1958
    Analogkid1958 Member
    119
    61
    Yorktown, IN
    2024 Prius
    I've always seen a two-three mpg discrepancy. How do you folks do your calculated - do you stop the pump at the first click or what - how do you determine you're filling to the same amount each time?
    On a related note - has anyone noticed the fact that the fuel level display goes down a bar or two, then goes back to full? It doesn't seem to be related to incline...
    Thanks!
  3. Mr Bill
    Mr Bill Junior Member
    Lee's Summit, Missouri
    After 4,500 miles, I find the computer mpg to average around 2.5 mpg higher than my calculated mpg.
  4. nolo contendre
    nolo contendre Hybrid Noob
    Montgomery, TX
    My first 3 tanks, all this month were:
    50.5 mpg MID 50.5 mpg Calculated (Dealer Tank)
    53.7 mpg MID 51.1 mpg Calculated
    54.3 mpg MID 52.7 mpg Calculated
    Date of MFG: 02/2010
    I always fill up with 2 pips showing on the guage and I fill one click after the auto shut-off.
    Nolo
  5. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    After eight months and 11,000 miles, my displayed mpg averages 3.3 mpg higher than my calculated at the pump mpg. I figure this to be a 7.1% error.
  6. tonyl
    tonyl Junior Member
    27
    20 tanks:
    Computer= 56.6 / Calculated= 54.8
    Best 67.2 @343 miles
    Worst 44.6 78+mph @225 miles
    Hubcaps removed, mud flaps added 3 tanks ago no change in mpg.
  7. tunnie
    tunnie New Member
    va
    2010 Toyota Prius III with Navi
    5,000 miles and about 45 mpg...tried many driving techniques and even 40psi, cant get better gas mileage...
  8. mainerinexile
    mainerinexile No longer in exile!
    403
    73
    Maine
    Yeah, I've seen the gas gauge go down a pip and then go back up, too. What is that all about?
  9. Downrange
    Downrange Active Member
    372
    209
    2024 Prius Prime
    SE
    First fill-up tonite - indicator said 54.1, got 9 gallons and 468 miles for 52 actual. Salesman said he "filled it up as far as he could" so I did the same, let it trip the auto shut off twice, so I think that's pretty close to as much as it would hold.
    Looks like a 2MPG diff, which seems to be a lot of peoples' experience.
    Built 11/09
  10. eldiee
    eldiee Member
    118
    17
    Iowa on Mississippi River Bluffs
    We have a 2010 V and now have 8500 miles. The computer always reads high. It is between 2-4 mpg higher than actual. Today actual for 512 miles was 53.3 and computer said57.3mpg. Normal is between 2-3 difference. Our average on the computer for 8500 miles is 54.8 mpg. Even with the 2-3 mpg error it still is great mpg. I really don't get to upset with the computer error as long as we average over 50mpg.
  11. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    how many litres in a US gallon ?
  12. Philosophe
    Philosophe 2010 Prius owner
    437
    72
    Montréal, Québec (Canada)
    A Google search calculation for "1 gal in liter" returns:
  13. miogps
    miogps Junior Member
    PA
    I just did the first fill-up. Computer MPG is 54.8 as against 53.7 actual. Driven on local roads with lots of ups and downs. It's mentally challenging to drive Prius especially after my jackrabbit style in a Corolla (1993 manual) that gave 38-40mpg on the same roads. Still drives corolla 3 times a week and Prius 2 times for a daily commute of 46 miles.
  14. luger
    luger New Member
    london canada
    On my 2010 version 111/IV at 700 Kilos I used 1 tank about 39.xx or for what gas tank it is rated for, can some one tell me my US MPG. Thanks
  15. drsbm3
    drsbm3 Junior Member
    34
    manassas
    My last three tanks were :
    57.4 MID, 55.02 calculated, 2 Pips at 491 miles
    60.2 MID, 57.25 calculated, 2 Pips at 525 miles
    59.8 MID, 57.59 calculated, 1 Pip at 531 miles
    Overall mileage is 57.06 MID, 54.26 calculated which is a 2.8mpg difference, so 5% variance. I fill 1 additional click after the auto shutoff. So my calculated mpg average is higher than the 50 mpg rating but lower than the optimistic prius computer.
  16. Smeerlup
    Smeerlup Junior Member
    Toronto, Ontario, Canada
    I
    After 5 fillups actual mileage = computer avg for the tank * 0.91 +/- 1%
  17. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    If I'm translating what you are asking
    700 km driven
    39 Liters of petroleum used.
    (700 km)*(0.62 miles/1 km) = 434 miles
    (39 liters)*(1 gallon/3.79 liters) = 10.29 gallons
    434 miles/10.29 gallons = 42.2 miles per gallon.
  18. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    179 miles, 54.8 indicated / 51.8 true.
    Also tank was filled to brim to brim no guess work
    alfon
  19. Rebound
    Rebound Senior Member
    3,996
    2,644
    Portland, OR
    It is NOT good to fill the tank up the neck and to the brim. You should stop filling after one click. The reason is that the emission control systems include [ame="http://en.wikipedia.org/wiki/Onboard_refueling_vapor_recovery"]vapor recovery system[/ame], which routes vapors from your gas tank through a charcoal canister (or similar). If you fill the tank all the way, this vapor line can fill with fuel, soak the canister, and ruin it.
    (Sorry if I sound like a nag, just trying to help)
  20. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    I did this to get a absolute true reading .
    This is more accurate than the first click at the pump, also I do not do it on a
    regular basis.
    Just for those who have never completely filled their car, after the first click you can get about 2.1 gallons in the tank before it 'brims".
    alfon
