Save to change 15" for 17" wheels?
Discussion in 'Gen 3 Prius Main Forum' started by dejongj, Apr 21, 2010.
  1. dejongj
    dejongj Member
    171
    Whipsnade, UK
    Hello, I am looking to order one this week. I really want the sunroof option but can't stand the 15" wheels. At first I thought the same as with other cars I had, just change the wheels...I've found some very nice ultra light 17" wheels and job done...
    But then I started reading on here and got confused, it seems that there are further hardware changes between 15" and 17" and also software changes but am not certain I noticed a conclusion. I can only test drive 17" models in the UK...
    So conclusively;
    a) Is the steering feel/software in 15" and 17" models the same?
    b) Is the number of turns in 15" and 17" models the same?
    c) Is it save for the car to just upgrade the 15" wheels with 17" versions with same as OEM tyres etc...
    Dealers told be computers get confused, insurance is invalidated etc...My BS meter went up, but then reading on her there might be something in it.....I
    Help :eek:
  2. telmo744
    telmo744 HSD fanatic
    2,181
    769
    Portugal
    Well, I was in the opposite. I wanted very much 15", and could not r€ach solar roof level to get that. Had to take 215-17" wheels that lowers both MPG and comfort...and increases tire replacement costs...
    Toyota dealers told me it was not possible, each layout has its wheel dimensions referred in the documentation.
    The funny thing is...I love the car at the same...
  3. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    Adjust the tire profile appropriately to keep the same overall diameter and it's safe to change to the 17" (or down from 17" to 15"). The suspension is different in the two models, but both will be fine with either wheel. Do make sure the tire you are putting on has at least as high a load rating as the one you are replacing. This will usually mean you can't go to a narrower lighter tire. Which is the only part that -may- be dangerous.
    You will have to adjust the tire pressures when you change the tire size (though you could probably "get away" without bothering).
  4. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    questions a & b: No they are not the same, the 17" wheel cars (PriusV in the U.S.) have a different steering motor and a different rack and pinion ratio. This give the 17" wheel cars about one less turn lock to lock on the steering and a slightly larger turning circle, 36 vs 34.2 feet.
    question c: Changing the 15" wheels for good quality 17" wheels should not be a problem, just make sure the offset is correct. Also, I would recommend using the same size tires that come standard on the PriusV, 215/45-17. I think if you search this site you may find some have already made the change. I don't know about the warranty question.
    http://priuschat.com/forums/gen-iii...79348-17s-brake-software-steering-system.html
    http://priuschat.com/forums/gen-iii...fications/78131-new-17-momo-wheels-tires.html
  5. dejongj
    dejongj Member
    171
    Whipsnade, UK
    Thanks for the info...I've seen those links which is what confuses me a bit....
    Hmm why oh why does toyota have to make it complicated for themselves and have two different setups....
    I'm not so keen now on changing it up as I the PriusV felt slower (steering wise) than what we are used to but acceptable, however going slower and having a different steering motor I am not certain I like....
    Knowing our local consumer laws, changing wheels in such a situation will invalidate both warranty and insurance....
    Such a shame, never come across a car where the setup is physically different on different size wheels...Sure you need to keep an eye on offset, diameter etc But different steering hardware/software...
    Ah well I guess there goes the sun roof :-(
  6. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    To add to what others have said, I have a Prius V (with 17" wheels), and this week had a non-V loaner with 15" wheels, and the steering was noticeable less responsive. The 17" wheel cars have a more direct steering ratio (which I much prefer, now having driven a 15" wheel Prius for a day). The lock-to-lock is less on the 17" cars, but that's not something you notice--it's just a result of the more direct steering ratio.
  7. dejongj
    dejongj Member
    171
    Whipsnade, UK
    Thanks that definitely made my mind up...Guess you can't fit the solar roof afterwards :-(
  8. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    It's a bit mind boggling that nobody has once to my knowledge expressed any interest in fitting 16" wheels on the 2010 Prius ...
    it's always ... 15" or 17", 15" or 17"
    Do you know or does anyone around here believe a smidgeon that a 16" wheel would actually hit a very sweet spot lookswise, performancewise and comfortwise on the 2010 Prius?
    Does anyone give one darn iota about this?
    I call Toyota dealers, asking if Toyota has any option to put a 16" wheel on a II - IV ... no, the 17" wheel ... for $455 per wheel. $2,000 for wheels ... forget it!
    I ask salespeople ... do any customers have interest in a wheel option on the Prius? No, that's not what they want the car for. I'd like a car that looks a little bit more balanced.
    It kinda stinks when I can see a 2010 Insight EX with a great looking, bare alloy 15" wheel that looks proper on the car .... but it's on an Insight with microsize back seat.
    I look at the 2010 Prius, up through the IV with it's bland looking plastic covers over 15's and high profile donuts. Ok, the 50 MPGs is great, but geez, give a little Toyota.
    I think a lot of people would give up a mile per gallon and spend and extra $500 or so for OEM 16's ,55 series tires steering upgrade as an option on their III or IV Prius.
    Unfortunately, I seriously doubt Toyota will package this as a little more steering fun is not really on the agenda.
    Better to wait on the CT200h ... they're talking about some more driving excitement for that car. 44 MPG average would be fine for me. I'll bet it turns up close to that.
  9. pixelmixer
    pixelmixer New Member
    102
    Seal Beach CA
    Hence, why I am getting a V. Absolutely (for me) transforms the overall look of the car.
  10. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Last time I rented a III, noticed a good bit of wheel turning to turn out of the driveway onto the street. Got used to it after that, but, it's a bit too docile for my taste.
  11. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    The 17 is a good looking wheel. I think it might all look a bit better and ride a tad more comfy with 205/50 - 17" tires which is what is run on a Mazda 3S. I don't know if anyone makes a low resistance 205/50-17" tire.
    anyrate, nevermind, the Prius has a torsion beam rear suspension. I'll be glad when Lexus brings out the performance in the upcoming hybrid sportback.
  12. dejongj
    dejongj Member
    171
    Whipsnade, UK
    If I had my way I would actually go to 18's...I'm running on 22's on my own car (up from standard 17's), plenty comfortable...But I guess speeds and driving style are a bit different in Europe :) It's all those bendy roads we have I guess, I hate how the small wheels make a car soft and roll in rapid corners...
    Anyway I've attached a wheel I was looking at in 15, 16, 17, 18 size on a Prius which clearly shows the difference...We all have different tastes but for me it has to be 17 or 18....
    However if there really are technical differences in the car it is all irrelevant unfortunately as I won't jeopardise the warranty.
  13. Tideland Prius
    16,621
    16 looks like a good compromise for those who want comfort, appearance and I guess a little better handling (not sure if it makes a big difference).
    The steering feel is the same but as others have said here, there's a different electric motor and the steering ratio is quicker. I believe Toyota GB doesn't allow dealers to sell 15" wheel models with aftermarket 17" alloys. They have to leave it up to the customer to add the 17" after the purchase. One of the rare cars that has warranty issues (there was no such problem with the last Gen Prius, probably because the same electric motor was used for the 15" and 16" models).
    Edit:
    TRD TF4 17" Alloy
    Pricey though...
    ¥139,125 for a set
  14. dejongj
    dejongj Member
    171
    Whipsnade, UK
    Oh I like that wheel!
    Today my mission is to track down a 15" prius to test drive it and feel the difference for myself....
