Tire rotation: when to torque lug nuts: tire in the air or on the ground?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by 2009Prius, Apr 25, 2010.
  1. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    Is it better to tighten the lug nuts while the tire is still in the air or OK to tighten with the tire on the ground (under load)? Thanks!
  2. Patrick Wong
    18,210
    6,510
    On the ground, for the following reasons:
    1) there's no chance that the car will fall off the jack while you are exerting force on the lug nuts
    2) you won't stress the transaxle parking pawl, if the car is on the ground and the parking brake is firmly set.
    Just make the lug nuts fairly tight, like 25-30 ft-lb, before lowering the car to the ground. This ensures that there's no gap between the hub and the wheel.
  3. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    Tighten by hand in a five point "star" pattern while the car is on the
    jack.
    Lower car and tighten to correct torque, 76 lb ft.
    Could be 'guestimated" with a lug wrench... better done with a torque
    wrench.
    More.
    FWIW, the 2008 Owner's Manual says you should use wheel chocks
    when jacking the car up. Funny though, a pair isn't included in the OEM
    equipment... :confused:
    I'd gladly trade the near useless cargo net and first aid kit I got for a
    pair of gen-you-whine Toyota wheel chocks. :glare:
  4. dtuite
    dtuite Silverback
    182
    31
    Redwood City, CA
    I think Patrick Wong's reason # 1 is the best. The kids in the tire shop will do the "zshoop-zshoop" thing to your lug nuts with the car on the lift, but then they're not likely to torque it off the lift. On a jack, man, I'll try to find a rock or something to use as a chock.
  5. dogfriend
    7,512
    1,190
    Carmichael, CA
    I follow the same method as Patrick. I would add that its difficult to get 76 ft lbs (or 100 ft lbs in the case of my Explorer) on the nut with the wheel in the air. The wheels will tend to rotate while you are tightening. Using a air impact wrench makes it possible, but the torque will not be accurate unless they use a special torque limiting extension. A hand operated torque wrench is the best way to tighten the wheel nuts.
  6. Patrick Wong
    18,210
    6,510
    Yes, this is true if both front wheels are elevated, as one wheel rotates in the opposite direction from the other.
    If only one front wheel is elevated, then the CV joints, differential gears and parking pawl will be subjected to some stress as you tighten the lug nuts on the elevated wheel.
  7. 2009Prius
    2,705
    512
    63
    I was told that in the good old days a Toyota car (truck?) would come equipped with a set of wrenches. How about that! :D
  8. dogfriend
    7,512
    1,190
    Carmichael, CA
    I think the Prius should be equipped with a service manual and diagnostic software on DVD and a USB to Data Link adapter. They could make it an extra cost option for a few hundred $, but it would be better if they just included it in the price of the car. :madgrin:
  9. 2009Prius
    2,705
    512
    63
    Yes and the diagnostic laptop. :D
  10. dogfriend
    7,512
    1,190
    Carmichael, CA
    The software should run on any modern laptop. :madgrin:
  11. kohnen
    kohnen Grumpy, Cranky Senior Member
    317
    58
    Fullerton CA
    Nah. 76 ft lbs is nothing compared to the amount of torque that the parking pawl will see if the (3000 lb) car is on an even moderate hill.
    You really aren't going to snap anything in the transaxle with 76 foot pounds. If you do, then you'd want to find out while the car's in a garage instead of parked somewhere (and starting to roll downhill).
