New owner question
Discussion in 'Gen 2 Prius Main Forum' started by czjohnson, Aug 4, 2005.
  1. czjohnson
    czjohnson New Member
    Southeast Wisconsin
    I've had my Prius for almost 2 weeks now and I can't seem to figure out how to run only the vents for fresh air. I don't want the A/C or the heater on, just want to run the fan for the vents. Is this possible?? Am I making sense? The car is wonderful but I need to become better friends with it.
  2. rustyj
    rustyj New Member
    Newark, CA
    Easy,
    Turn on the A/C, go to the climate menu, press the A/C on the MFD (light should go out), fan adjustments will work as expected.
    Make sure the selection for fresh air (bottom left) is selected vs. recirculate.
    Enjoy.
  3. KTPhil
    KTPhil Active Member
    1,379
    22
    You also must still set an appropriate temp.
    PITA. A "vent" button on the MFD would be welcome.
  4. jeromep
    jeromep Member
    827
    Eastern Washington State
    Also, set temp to outside temperature. If outside temp is below 65, you cannot set the system temp below 65 because it will kick in to max cool and that will bump up the fan speed. If the outside temp is above 85 you cannot match that temp with the system because it will kick in to max hot above 85. However you can make the A/C system full manual by selecting the air outlet, selecting your fan speed and turning off the a/c. However temp control is still going to be automatic, try to match outside temp.
  5. czjohnson
    Southeast Wisconsin
    If I have the A/C system off, why do I need to fool around with the temperature setting?? This started off as something that should be so simple, now it sounds like I'd have to pull over to the side of the road to make all the adjustments!
  6. LeoP
    LeoP New Member
    Upstate NY
    I've only had my Prius for a week, but this is how I run the fan without the AC:
    Go to Climate.
    Make sure Auto is Off
    Go to AC button - if there is a yellow line across the top of the button, the AC is on. Touch the AC button and the yellow line should go away and the AC is off.
    Select the fan speed you want.
  7. prius04
    prius04 New Member
    1,161
    NorthEast USA
    You are right. With the AC off the automatic setting, the temp button does nothing to the AC. However, this is a way to set the heater manually. Set the temp higher than ambient, and the heater will come on. Set it below ambient, and nothing will happen if the yellow bar is off above the AC button..
    You can set the fan from low to high, and you can set the recirc versus outside air.
  8. c4
    c4 Active Member
    607
    51
    In order to get outside air, the fan must be on (auto or a speed setting of your choice; if it's OFF, the vent closes regardless of what the fresh/recirc setting is), and the mode switch should be set to high-level (the upper vents), and you may still need to fiddle with the temperature setting, otherwise the A/C computer (which still controls everything even though the compressor may not be running) overrides and you may end up getting recirculated air vs. outside air..
    The climate control system on the Prius is easily the most annoying thing about the car..
  9. DanMan32
    DanMan32 Senior Member
    3,799
    27
    Tampa Bay, FL
    I don
    I don't believe so. While driving 70MPH, I turned off my HVAC using the steering wheel control. It was on Auto, so it went to Off. I had it on Recirc, so it stayed there. No air flowing from vents.
    Set Recirc to Fresh, air is felt coming in.
    A good way to really find out is try the recirc while behind a smelly diesel truck. Fresh - smell. Recir, no smell.
  10. c4
    c4 Active Member
    607
    51
    The NCF is confusing as hell where it concerns the A/C and ventilation system operation.. The last time I read it, it seemed to suggest that the vent is closed if the blower is off, but looking at the text and diagrams yet another time, perhaps the other linkages to the mode control can also override..
    In any case, the air flow is very small without the fan going- I tried it but couldn't swear to whether there is a flow or not, but then that could also be related to the speed-dependent nature of the vent- there's a graph in the NCF that seems to suggest a speed dependent hysteresis loop for opening and closing the vent (opens when you slow below a certain speed, and closes when you increase speed over a certain threshold)
    I'll reiterate that this is easily the worst designed system on the Prius..
  11. prius04
    prius04 New Member
    1,161
    NorthEast USA
    Actually, I don't think it's that bad a system at all. In fact, I think it's a pretty good system. It's a combination automatic system, if you want auto. But it's also a totally manual system at the same time if you want that. I've had (one) car that was "auto only" and it was hard to do things manually, but of course most of my cars that had working AC were totally manual. This car does both well. No completely intuitive, but once you get the hang of it it's understandable.
    And yes, when you have the refresh button on, and the fan speed zero, the air coming out of the vents is low, but it definitely IS coming out. I tried it at 70 MPH and there is no doubt air is coming out. Enough for an air change, but no where near enough to be "refreshed".
    And on my 04 Prius, if you have the fans off, the temperature buttons and AC button are greyed out. But if you have the fans on any speed, the AC button comes live, and the temp buttons are live. If you make sure the AC is off, that temp button is still live, but it had no affect on air temp until I reached max hot, and then very hot air blew out. But from 84 degrees all the way down to max cold, there was zero change in the temperature of the air coming out, unless the AC was on.
    So with the AC off, that temperature button only affects the heater, giving you a manual system.
  12. c4
    c4 Active Member
    607
    51
    My biggest beef is that the vent is nowhere near enough compared to my old Corolla... The specific scenario where the Prius system fails spectacularly in my eyes is in damp rainy weather..
    On my old Corolla, simply setting the mode to defog and opening the outside air vent was sufficient in most cases to keep the windshield clear. Sometimes you also needed to turn the heat up, but in most cases, the extra warmth was welcome.
    With the Prius, the defrost mode does automatically open the fresh air vent, but it also forces the A/C on (but on the Classic, the A/C light stays "off" and you cannot manually turn the A/C off- I understand this is different on the HSD and you can turn the A/C off manually). The A/C does turn off if you switch the fan off or the mode to FOOT/DEF, but then this also places the vent under automated control (opens and closes depending on temperature, speed, and other factors) and the low flow in this case does not allow enough outside air in to adequately defog the windows and the interior rapidly begins to feel stuffy and the windows fog over.. Opening the windows will help, but lets the rain in, so you're forced to use A/C to keep the windows clear and you suffer the MPG hit when you really don't need to..
    As I've posted elsewhere, the system annoys me enough that I keep wanting to tear out the A/C ECU and put in manual cables to control the vents myself- environmental settings are such a personal thing that I doubt that any automated system can fully satisfy everybody, whereas a fully manual system may require some tweaking and fiddling, but you can generally find a setting that makes you reasonably comfortable..
  13. auricchio
    auricchio Member
    921
    Cambria, CA, USA
    <div class='quotetop'>QUOTE(c4 @ Aug 9 2005, 01:35 PM) [snapback]114962[/snapback]</div>
    Naw, you want vent? My 1963 Dodge Dart had vents. A vent box under the dash above the driver's left leg and another above the passenger's right leg. Five-inch-square manual doors: you either opened or closed them. We used to call them "Hurricane Doors."
    But I'm just being silly.
  14. kDB
    kDB New Member
    241
    Fenton, MO
    <div class='quotetop'>QUOTE(DanMan32 @ Aug 9 2005, 01:25 PM) [snapback]114878[/snapback]</div>
    i'm sure the vent only close when recirc is on. pass a dead skunk once a week, you'll figure it out.
