Dashboard rattle
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by mark2852, Apr 29, 2010.
  1. mark2852
    mark2852 New Member
    Chicago
    I notice a dashboard rattle to the left of the steering wheel. I thought it might be from the cable that pops the hood, but it seens like it's coming from behind the dimmer control. The dealer thought it was a loose hose leading to the a/c vent, but even after they secured the hose, it came right back. Problem is that it comes and goes.
  2. Patrick Wong
    18,204
    6,505
    I've attached a photo of the area in case you want to DIY and look around.
  3. mark2852
    mark2852 New Member
    Chicago
    Wow, thank you Patrick! Your photo will be extremely helpful in my search.
  4. Bob64
    Bob64 Sapphire of the Blue Sky
    1,540
    93
    Virginia
    any hints on how to remove the left vent cover thingy near the steering wheel?
  5. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
  6. Patrick Wong
    18,204
    6,505
    That's the first part to remove when you want to disassemble the instrument panel. Grab the vent at the top and bottom with your two hands, and pull it out.
  7. ETP
    2,802
    1,170
    Auburdale FL
    I also have a rattle that comes and goes from somewhere on the drivers side dash. I cannot trace it to one spot while driving.
  8. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    I had a rattle which turned to be the upper glove box, the top portion was loose and ratt.eling. I removed the two plug covers that hide the screws and tightened the two philips screwheads. Took care of problem.
  9. direstraits71
    direstraits71 Member
    367
    65
    Central Coast California
  10. 2009Prius
    2,705
    512
    63
