1602 and 3002 codes
Discussion in 'Generation 1 Prius Discussion' started by georgeofthejuggle, Apr 5, 2010.
  1. georgeofthejuggle
    georgeofthejuggle New Member
    Been a lurker here for quite a while. I get the most out of reading peoples problems and then the few that have answers posting them. Thanks to those that have the answers. Greatly appreciative.
    Year: '01
    Mileage:128k
    Ownership: 2nd owner bought in 96 with 80k
    Previous problems: not many, brakes redone, new 12v battery, occasional loss of power with exclaimation point that goes away. Also the blue coolant light comes on for the first few minutes of driving.
    Here in Mass. we cannot get an inspection sticker if the check engine light is on. Code indicating o2 sensor needs replaced. (forget the exact code but can post it). Mechanic replaced o2.
    Not sure what was happening next but at one point on the test drive he got Japanese text on the LCD. Then it would not start. Let it sit and everything was ok. He thought that having the scanner hooked up was doing something.
    At this point he got 1602 and 3002 codes and recommended taking it to the dealer. He thought that the hybrid and engine computers were not communicating and a "flash" to the software might need to be done.
    Any thoughts?
  2. bwilson4web
    15,937
    You're in luck!
    Good Prius Friend Hobbit hangs in that neck of the woods and I understand he has the NHW11 compatible, Autoenginuity scanner. Send him a PM and you'll be in excellent hands.
  3. georgeofthejuggle
    Update: Should be a 1636 code not a 1602.
    Met with Hobbit today. Thanks for the referral! Very interesting time.
    Checked a number of connections to the ECU and they all seemed to be working correctly. But were not able to get the check engine light off.
    He did not have his scanner with him so we might try to get together again next week.
  4. jk450
    jk450 New Member
    There should be a code for that issue stored in memory.
    It's supposed to do that.
    There is no code that indicates that the sensor needs to be replaced, only a code that indicates that something is wrong with the circuit. The actual issue needs to be pinpointed before parts are replaced.
    He may be right. Some aftermarket scanners (the Launch X431 comes to mind) can cause this effect.
    Such scanners often falsely report codes, so it's hard to know where you really are until you get a report from a scanner that can be trusted. The Autoenginuity scanner has been mentioned. Unfortunately, that scanner has a checkered past with the Gen 1 Prius, in terms of connectivity as well as accuracy. There is ample evidence of this in the archives.
    Versions prior to 8.2 can falsely report nonexistent codes, and cannot communicate with some key modules. Version 8.2 has apparently addressed some communication issues, but its accuracy remains unknown.
    A few folks have reported experimenting with one, but have not, as far as I know, tested it enough to determine whether or not the issue with false codes was fixed.
    I would recommend finding someone who can record codes and subcodes as well as enhanced freeze frames, and have them record all information prior to clearing codes, and then give that information to you, as well as information on any codes that return. Since your vehicle appears to have multiple codes, I would recommend a factory level scanner or equivalent.
    Folks on this forum may howl at such a suggestion, but it's kind of pointless to try to diagnose a vehicle without knowing the validity of the information that you are using to diagnose it.
  5. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    I was a complete *idiot* today and forgot probably the most
    important piece of gear when packing up for this meeting --
    the laptop with AE and the obd-ii widget! But given the type
    of problems, all seemingly having to do with communication
    between ECUs, I wanted to unearth the hybrid ECU and have a
    look at its connections. In the Classic, it's buried under
    the slanted part of the passenger footwell. Wiring looked
    okay physically, reseated the connectors on it and the engine
    ECU behind the glovebox. Then I got a scope on the various HTE
    and ETH and HTD and such serial-comm leads and they all look
    solid, passing lots of little data packets back and forth.
    There's no CAN bus in this car, it's all dedicated RS485-like
    differential pairs run between the modules.
    We also checked the throttle body; nice and clean inside. And
    the 12V seems solid enough, despite the battery being a couple
    of years old. But that's about all we could poke at sans scantool,
    so we'll have another go at it in a few days. It's starting to
    sound like the indy techs pulled the wrong codes, because really,
    if there's a problem with the hybrid computer talking to the engine
    computer the car will have a bit of difficulty actually going
    anywhere.
    _H*
  6. hobbit
    4,089
    468
    Bahstahn
    We had another crack at this car today, with proper diagnostics.
    The "ecu malfunction" code was still present, along with a more
    generic P0171 "too lean" code. We already know the ECU comms
    are fine, having seen healthy bits on the scope. We cleared the
    MIL and started over, and the first thing I started watching was fuel
    trims. Long-term was like 20% or more, and short-term all over the
    place; both rose significantly as the engine was placed under load.
    While the car *seems* to be running fine I did notice a slight
    stumble when running the engine up to its 2400 RPM test condition
    by pressing the go-pedal in Park, as well as a significant correction
    in mixture trim and a resultant dip in RPM on going to Neutral to
    come back off that to base idle.
    So now it boils down to a typical lean-condition engine problem.
    The supposed communication errors did not return, so I guess those
    don't self-clear in this car without help.
    Lean fuel-trim conditions that change like that between idle and
    loaded often indicate a dirty MAF. I took a look at it and where
    I should have seen those nice little white beads I saw dark brown,
    so I tried my cleaning trick with alcohol. In contrast to the two
    other MAFs I've cleaned this way, this one didn't really take to
    it and the wire elements still looked dark and like they still
    had gunk stuck to them or that they might have even been a little
    burnt somehow. And the fuel-trims didn't change. I could drive
    the long-term down temporarily by holding my fingers in the
    throttle throat next to the MAF "pedestal", forcing more air
    through the MAF itself.
    Force-charging to create a higher engine load drove the long-term
    trim up over +40%, around which the MIL went back on. *sigh* So
    the current theory is that a new MAF is needed, and we can't rule
    out the possibility of a vacuum leak somewhere in the maze of hoses
    but that wasn't anything we were going to find in a quick later
    afternoon of looking around. I wonder how it got that gunked-up
    in the first place...
    _H*
  7. bwilson4web
    15,937
    Excellent report:
    PCV valve?
    The small outlet hole at the 11:00 o'clock position relative to the MAF sensor might be the source?
    Other than doing a compression leak-down test, I wonder if there is another way to detect excessive blow-by?
    Are you having any problems with connecting the AE to the NHW11s? I've found setting it to ISO9141-2 seems to avoid inducing ABS errors. Better, I'm still seeing intermittent problems.
  8. hobbit
    4,089
    468
    Bahstahn
    Well, once again "morning after" hindsight wins. We could probably
    have swapped in the MAF from *my* car that was sitting right
    there behind us to test things and help localize the problem; I
    think they're exactly the same unit in NHW11 and NHW20.
    Both PCV hoses come in safely underneath where the MAF is
    located, so I don't think the perennial "oil fog" problem that
    goes on down there can affect it. I've never seen oil on any
    of the MAF parts, just a little bit of light dusty stuff. But
    the wires in George's unit almost looked burnt somehow.
    It was *sort of* working as holding a finger over the tongue
    or next to it did affect engine idle and the LTFT, but I don't
    think it was reading right.
    _H*
  9. Patrick Wong
    18,200
    6,490
    See my post #12, looks like the MAF is different although the throttle body assembly is the same.
  10. bwilson4web
    15,937
    What sort of prices for a MAF sensor?
  11. beam99
    beam99 Junior Member
    uk
    Did you try spraying carb and choke cleaner around the inlet side of the engine to see if you have a air leak, what sort of readings were u getting from the o2 sensors.
  12. Patrick Wong
    18,200
    6,490
  13. jk450
    jk450 New Member
    Why not use the scan tool to identify the problem?
  14. bwilson4web
    15,937
    It is fairly common in the NHW11 to clean the throttle plate area of 'gunk' to avoid 'sticky throttle' and the MAF is on the far side of the throttle plate. I'm beginning to wonder if there might have been a design change between the NHW11 and NHW20 that reduced the amount of fuel and oil-mist laden charge that drifts back to the throttle plate and MAF area?
    The ZVW30 engine has a space in the block to separate out the oil and air. But I was wondering if the NHW20 might have a slightly longer section between the throttle plate / MAF area and the manifold. Perhaps a spacer or longer throttle body?
    Perhaps an IR camera might be able to observe a fuel and oil-mist vapor rising up to the throttle plate area?
  15. georgeofthejuggle
    BTW Hobbit, I called Wayside Auto in Seekonk and they do remember you. :D
    It is a haul for me to get all the way down to Seekonk and leave the car then try to get to work so I will just end up at the dealer next week.
    I thought I might try to clean the MAF with MAF cleaner. Just for kicks to see what happens. Would like to try Bobwilsons idea of changing the PCV valve too but saw all that is involved in getting to it and I am sure I would break something plastic excavating it.
    Sticker expires today so I will have to pay for another inspection. Blah.
  16. georgeofthejuggle
    Well I just got the call from the dealer and he came up with 171 and 110 and 100 codes also. All related to MAF so he says. $400. Will be done today.
    So Hobbit was right on the money. It would have been nice to replace that myself since it looked so easy but we never had the code pinned down exactly. I assume the 110 and 100 codes are subcodes that only the dealer can read?
    Well anyway thanks to Hobbit for his help. Getting those original communications codes out of the way probably saved me a bundle. i have no doubt they would have tried to sell me on a ECU.
    I also went to my mechanic for inspection of my KIA on Saturday. This guy also builds motorcycles. Nice day 80 degrees. I said "can I ask you another question about my Prius?" laughs and says "No NO not today" He just wanted to get out of there and ride.
  17. jk450
    jk450 New Member
    P0110 and P0100 codes can be set if someone disconnects the MAF sensor when its circuit is energized.
