Can't "SEE" my oil <> Why?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by cyberpriusII, May 3, 2010.
  1. cyberpriusII
    1,155
    1,732
    Mars Hotel
    Ok, I just started wearing glasses, and no, I won't post my picture with me wearing them....:(
    But, ever since I got my Prius I have had trouble seeing the oil on the dipstick. So, I never really know where it is at...except, like after three months or so....it seems to be easier.
    So, with new glasses, still no luck.
    But I was reading through the Amsoil post on the main forum, and someone mentioned the fact that it is impossible to see these "new lightweight oils."
    So is this the trouble? My previous car ran 10-40 oil and never had a problem reading the dipstick.
    If so, maybe I can toss the specs:D
  2. Patrick Wong
    18,200
    6,500
    Sigh. Just hold the dipstick so that you can see light reflecting off its surface. Then you can see where the dipstick is wet and where it is dry.
  3. cyberpriusII
    1,155
    1,732
    Mars Hotel
    Patrick:
    I may be blonde.....but.....I do try to twist the thing every direction, I look at both sides and it still looks like no oil.
    I've even tried stealth methods of slowly working a paper towel down the stick to see if I tell when the towel starts to absorb any liquid...but the oil must sense my trickery...
    Maybe I had better see about getting stronger glasses:rolleyes:
  4. Patrick Wong
    18,200
    6,500
    Do you ever have a sunny day in Oregon? Wait for one of those, then hold the dipstick in the sunlight, reflect the light into your eyes, then you can see where the fluid level is.
    Or, maybe the level is really too low and that is why you don't have any oil on the dipstick?
  5. cyberpriusII
    1,155
    1,732
    Mars Hotel
    Sun???, well, I think we get something like that for a couple of hours about August 12th.
    I have to say that I usually do this check in the shelter of my poorly lit carport, which is under a dense stand of fir trees. But it beats the pouring rain, which at the moment is coming down at a 45-degree angle, being blown by a 35-mph east wind.
    I'll report back Aug. 13th.
  6. Patrick Wong
    18,200
    6,500
    Yes, the dipstick check is really tough to do, if you don't have enough available light. Maybe a flashlight would help?
    The good news is that the Prius engine works efficiently so that the engine oil is slow to become contaminated with combustion byproducts. The bad news is that the relatively clear oil is hard to see if you aren't able to see reflected light in the dipstick...
    Have you solved the mice problem; or do you still find evidence left by your little friends from time to time?
  7. uart
    uart Senior Member
    4,220
    1,209
    Australia
    Yes you're not alone. I also find the new oil so near transparent that it's difficult to see on the dipstick.
    Funny story, the first time that my wife had the Prius serviced at the dealer I of course had to check that they'd done the oil properly. So after she drove it home I pulled the dip-stick and was horrified, "those dumb %^@@#s have forgotten to put any oil in" I yelled. Haha, a few seconds later, after very carefully examining the dip-stick at various angles I finally saw it, so pale and near transparent but at least it was there, phew!
    It didn't help that it was 1/4" overfull and I wasn't really looking for the transistion above the full line. Anyway I was so relieved that it did indeed have oil that I wasn't too concerned about the overfill.
    BTW. When I fill my older car at home the oil I use is a very light honey color and I can usually see it ok even when new.
  8. chrisengst
    chrisengst Junior Member
    42
    Ithaca, NY
    Question. It is suppose to be important to get high milage to not overfill oil. When the dealer overfills, does one loosen drain plug and drain out some of the oil?
  9. NASCAR Mike
    NASCAR Mike Senior Member
    83
    Richmond VA
    Too much oil will cause drag on the crankshaft and foaming.
    If you have a too much oil you can either remove the drain plug and remove some but I think it will come out too quickly. I would drain the oil from the oil filter. It will only allow a limited amount to come out. Retighten, run engine, shut off. Check level.
  10. uart
    uart Senior Member
    4,220
    1,209
    Australia
    Yeah some people do remove some oil when this happens but I didn't bother. If it was over a 1/4" then yes I would bother (and complain to the dealer) but the 1/4" doesn't seem to hurt too much. Well I'm still getting 4.3 L/100k (54 MPG) so it cant be too bad.
    Actually it's been nearly 8000km since that oil change and I haven't rechecked it yet. So I think I'll check it again in the next few days and see if I can detect any consumption. Maybe it's used the extra oil by now.
  11. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    Buy a nice LED flashlight??
    _H*
  12. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    i have always had difficulties checking the level as well. i usually do about 3 "dips and wipe" and kinda average the results... ya, i know; really stupid to admit that on a public forum.
    on my 04, i actually went as far as pumping oil out to see if the level changed.
  13. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    511
    63
    In addition to the trick of using light reflecting from the dipstick surface to tell where it is dry and where it is wet with oil, I found that it is much easier to see the oil if you check the oil when the engine is cold, as opposed to checking it after a long drive and the engine is still hot, because the viscosity of the oil is higher at lower temperature and you get a much thicker coat of oil on the dipstick and it would be that much easier to see. Hope this helps. Good luck! :)
  14. anxious
    anxious Junior Member
    Long Island, NY
    which is correct?
    checking oil when engine is cold or warmed up ?
  15. Patrick Wong
    18,200
    6,500
    You'll see the maximum dipstick reading when you check the oil level while the engine is cold and has rested overnight. If you check the oil level after the engine has run, some amount of oil coats the cylinder head and valve train, and this will take a while to drip back down into the crankcase.
    Hence I would say it is correct to check the dipstick when the engine is cold and the car is resting on a level surface. However it is more important to periodically check the dipstick when it is convenient for you (buying gas for example), than to wait for the perfect moment when the engine is cold.
  16. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    hmmm, i thought u checked it when it was warm because of expansion?
  17. BAllanJ
    BAllanJ Active Member
    667
    78
    Kingston Ontario
    I got one of those syringe-like things they sell for measuring 2stroke oil for small engines and attached that to a quarter inch clear plastic tubing. You can feed that down the dip stick hole and pull the plunger back to suck out a syringe full. 4 full syringes will take it down from a quarter inch high. I just bought a little pump thing that attaches to an electric drill that I may try next time.
    I'm close to my next 8 Mm oil change, so if they screw it up again I can try the new pump.
  18. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    421
    Whereabouts Unknown
    If you're blond, you don't check the oil level. Just wait until the low oil light comes on or the ICE stops running.
    :cheer2:
  19. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    Admittedly, it is difficult. I just take the dipstick over to my magnifying light.
  20. uart
    uart Senior Member
    4,220
    1,209
    Australia
    Hi BAllanJ, I don't know what size your syring is but I'm interested in approximately what volume of oil that "4 full syringes" totals. Is it about a cup full (250mL) or is it more/less?
    Thanks.
