Tanabe exhaust
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Supreme, May 11, 2010.
  1. Supreme
    Supreme Hypebeast
    182
    Philly
    I attempted to order a Tanabe exhaust this week based off of this:
    Tanabe USA R&D Blog | Concept G Test: 2009 Toyota Prius
    After speaking with several Tanabe retailers, it looks like the concept g and touring medallion exhausts for Gen II prius's won't reach the US for another 90 days. Just a heads up for everyone.
    I think i've officially run out of mods to purchase.
    hen lai liaw likes this.
  2. yardman 49
    yardman 49 Active Member
    606
    77
    Northern Kentucky
    What's the supposed benefit of this exhaust? :confused:
  3. Supreme
    Supreme Hypebeast
    182
    Philly
    Weight savings, top end acceleration improvement, sound (subjective)
  4. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    You mean it is even quieter?
    I bet the only detectable 'improvement' is that your neighbors hate you now.
  5. Supreme
    Supreme Hypebeast
    182
    Philly
    Good thing I don't have any of those. :rockon:
    KLD_Prius_PI_Synergy likes this.
  6. drees
    drees Senior Member
    1,782
    247
    I still can't figure out why they didn't tuck the muffler up into the stock location instead of having it hang down so far.
    Looks like something you'd have your local muffler shop hack together for $100 that you frequently see on old beat up imports driving around making lots of noise but not going very fast.
  7. ozarkgolfer
    ozarkgolfer Junior Member
    76
    Rogers, AR
    First time around I thought that was photoshopped but have seen other pictures and it's not. The exhaust is just hanging out the underside of the car - are there plans to tuck it on production versions?
  8. Supreme
    Supreme Hypebeast
    182
    Philly
    My guess is that if they tucked any further it runs the risk of melting the bumper plastics. That, or where they have it at gives the least amount of bends in the pipe.
  9. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    The heat shield is useless now. Cat will get colder faster and that will result in running ICE more often. It will come down to lower MPG.
  10. qbee42
    3,080
    Also, when you hang something like that on your car you want people to see it.
  11. drees
    drees Senior Member
    1,782
    247
    Not only that, but I think the design was done to make it as cheap as possible. It's a lot harder to properly design a system for the Prius which tucks the canister up out of the way while still looking "nice" for those people who want to see the exhaust tip. Personally, I prefer the hidden/stealth look!
    Huh? The cat is a LONG ways upstream from the muffler. There will be negligible difference in ICE run times and MPG as result of this muffler.
  12. yardman 49
    606
    77
    Northern Kentucky
    I'm assuming that you mean "louder sound", most likely.
    Some things to keep in mind about this:
    - The Prius sometimes spins the ICE very fast, when horsepower or torque demand is high, especially when the Traction battery is low on charge. So you can find yourself not going very fast, but making noise that would be appropriate for a higher rate of acceleration. Rather than having the desired "coolness" factor, it will make bystanders think "hey, look at that sad little car making all that noise and going so slow". Sort of like most of the "rice rockets" that I see on the road, that I can beat from a dead stop with my Sienna minivan!
    - As you already know, the ICE is often off when the car is not moving (depending on cabin temperature needs, etc). So in stop and go traffic, if the exhaust is loud, it will be pretty weird having the car go from being almost dead quiet to loud (at a fixed RPM) and then quiet again, without ever moving.
    - Ultimate acceleration is not just related to ICE output. Whether or not you will see a performance increase with a less restricted exhaust system is questionable. A couple of guys have tried supercharging their Priuses, but have met with very limited performance improvements. So a mere exhaust change most likely will not gain much performance increase, if anything.
  13. a_gray_prius
    2,927
    783
    IL
  14. blueumbrella
    blueumbrella Member of Prius Regeneration
    294
    34
    Seattle
    It appears to be hanging pretty low and I wonder if this might cause some problems.
  15. Prius/lexus
    Prius/lexus New Member
    46
    Lakewood
    Looks nice!
  16. macmaster05
    macmaster05 Senor Member
    4,050
    730
    Is this product still available? Buying information?
  17. Supreme
    Supreme Hypebeast
    182
    Philly
    I stopped trying to purchase it, every time I called they would tell me another month, another month....
  18. macmaster05
    4,050
    730
  19. Robert J. Knight
    Robert J. Knight Robert J. Knight Senior Member
    Lyman SC
    Can anybody give me some idea of the cost of this system?
    Thanks
    Bob Knight
  20. macmaster05
    4,050
    730
    Just follow those links I posted.
