calculated vs. computer MPG - Please post your results
Discussion in 'Gen 3 Prius Fuel Economy' started by F8L, Jul 10, 2009.
  1. vday
    vday Member
    312
    Israel
    2.1 gallons
    that sounds like a lot
    That is 17-18% of the whole tank capacity:)
  2. EvGriga
    EvGriga New Member
    Israel
    Computer trip meter reports avg. 52mpg
    I Calculated by myself for the same trip 48mpg
    Stinks!
  3. vday
    vday Member
    312
    Israel
    That is about 8% which is about ave.:) for all of us
    I would also prefer a more exact reading
  4. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    435.2 miles / 8.515 gals / 51.130 mpg / indicated 53.2 mpg
    real world driving
    alfon
  5. maltbyman
    maltbyman Junior Member
    Greater Seattle Area
    I am getting about a 2mpg optimistic view from the Prius, very similar to my 2004 Prius.
  6. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    For my first 5 fillups (2750 miles)
    Reported = 60.4 miles per gallon
    Actual = 57.4 miles per gallon
    Roughly a 5% overestimate. I deal with it, despite my Quality background....and all the "anality" that comes with it.....
  7. kidstoymaker
    kidstoymaker New Member
    Oklahoma
    After 5 tanks on my 2010, actual is within a fraction of 5% under the gauge on every tank. I drive mine like I drive, never baby it so my actual mileage is close to 45mpg. 75MPH down the highway and I do my best to stay up with traffic. My EVO got 20/24 so I'm very happy with the purchase.
  8. bwilson4web
    15,989
    Last year, I collected this set of data from folks who volunteered their actual and indicated MPG:
    Column 1 Column 2
    0 indicated actual
    1 37.9 38.5
    2 41.2 38.9
    3 41.5 39.3
    4 43.6 41.3
    5 44.3 42.4
    6 44.6 43.2
    7 44.9 45.0
    8 44.9 45.0
    9 45.7 43.7
    10 45.7 43.4
    11 46.5 45.2
    12 46.6 47.3
    13 46.7 44.6
    14 46.8 43.3
    15 46.9 44.8
    16 46.9 44.8
    17 47.7 46.8
    18 47.8 44.7
    19 48.1 45.7
    20 48.2 46.0
    21 48.2 48.0
    22 48.2 45.2
    23 48.3 45.5
    24 48.4 46.9
    25 48.4 46.9
    26 49.2 47.1
    27 49.3 45.8
    28 49.3 45.8
    29 49.5 46.2
    30 49.6 46.4
    31 49.7 50.1
    32 49.7 46.6
    33 49.9 48.2
    34 50.0 46.7
    35 50.4 47.2
    36 50.4 47.2
    37 50.7 49.0
    38 50.7 47.9
    39 50.7 49.0
    40 50.7 47.9
    41 51.0 48.0
    42 51.0 48.0
    43 51.0 49.4
    44 51.4 48.7
    45 51.5 51.8
    46 51.5 48.8
    47 51.6 51.1
    48 51.6 51.1
    49 51.7 49.4
    50 52.0 49.0
    51 52.0 48.8
    52 52.1 51.9
    53 52.3 49.4
    54 52.4 49.9
    55 52.4 49.8
    56 52.5 51.8
    57 52.5 53.2
    58 52.6 51.4
    59 52.7 48.8
    60 52.7 51.2
    61 53.0 50.4
    62 53.1 50.5
    63 53.1 50.9
    64 53.1 49.8
    65 53.4 50.9
    66 53.6 50.8
    67 53.7 50.3
    68 53.8 52.6
    69 54.0 52.0
    70 54.0 50.0
    71 54.1 51.2
    72 54.3 53.4
    73 54.8 49.5
    74 54.9 52.3
    75 55.0 48.5
    76 55.0 51.0
    77 55.0 52.8
    78 55.1 50.8
    79 55.1 51.1
    80 55.5 51.2
    81 55.5 50.3
    82 55.5 52.6
    83 55.7 53.3
    84 56.0 52.3
    85 56.1 51.5
    86 56.3 56.0
    87 56.4 52.9
    88 56.5 48.6
    89 56.6 51.0
    90 56.7 54.2
    91 56.7 54.0
    92 56.9 56.7
    93 57.0 54.6
    94 57.1 55.4
    95 57.1 55.9
    96 57.1 51.4
    97 57.1 55.4
    98 57.1 55.7
    99 57.3 55.2
    100 57.4 55.6
    101 57.4 54.8
    102 57.5 52.6
    103 57.6 54.1
    104 57.6 56.5
    105 57.6 54.1
    106 57.7 55.3
    107 57.7 55.7
    108 57.8 55.9
    109 58.0 55.5
    110 58.2 56.0
    111 58.4 53.2
    112 58.4 54.3
    113 58.5 55.8
    114 58.8 55.3
    115 59.0 55.9
    116 59.0 55.2
    117 59.1 56.4
    118 59.2 55.2
    119 59.3 56.2
    120 59.9 54.6
    121 59.9 56.9
    122 59.9 56.7
    123 60.1 54.3
    124 60.1 58.0
    125 60.4 57.3
    126 60.4 57.0
    127 60.7 57.3
    128 61.0 58.5
    129 61.3 58.4
    130 62.0 59.4
    131 62.3 56.7
    132 63.6 53.8
    133 63.6 59.7
    134 65.9 63.2
    135 68.1 62.4
    136 73.2 68.7
    137 76.4 64.0
    138 80.5 71.4
    PriusChat user data.
    I did a series of analysis trying to identify the outliers and eventually came up with this chart:
    I tried different approaches to find the outliers and this one matches my expectations for a linear offset:
    1.0 - 0.9548 ~= 0.0452 = 4.52% error
    The "0.9548" is the slope of the a linear trend line through the ~160 samples. As for the outliers, I tried trimming both ends but still had a Y-axis intercept problem, it didn't go through zero. But when I set a 10% threshold for outliers, the line came smack dab through the zero axis point.
    Having the outliers all reside on one side of the user data suggests that their pump may have delivered less fuel than indicated on the receipt. So I would caution anyone who sees their indicated versus actual mileage to be off by 10% to 'note' that gas station and pump and try someone else. If the error goes lower, say closer to 5%, and returns to 10% or higher when going back to the original station, it is time to file a report with the state weights and measurements office. For good measure, send a copy to your state representatives and keep your records for an attorney. It may also be OK and just a 'rounding error' in the Prius indicated mileage.
    Many years ago, Alabama had some pumps that if the dollar value hit on a certain, low digit number, the gas quantity would 'adjust' up. What this meant was you had to detect a pattern and it only had to thieve 1 out of 10 times.
  9. Matt Herring
    Matt Herring New Member
    421
    51
    North Andover, MA
    Thanks Bob...good info! If anyone has an excel spreadsheet they use for their fuel logs that has formulas built into it that takes into account weighted figures for tanks based on miles driven...please pass it along as I'd like to incorporate this into my own fuel log (or just use yours)!
  10. PriusRos
    PriusRos A Fairly Senior Member - 2016 Prius Owner
    1,973
    218
    Rockville, MD
    I tried to paste a table showing all my fill-up results since I bought the car last July...but unfortunately it threw away the formatting. Here are my lowest and highest readings. The lowest occurred during very cold weather after my usual short, stop-and-go commutes. The highest was after a 650-mile road trip with no traffic or weather issues. As you see, the variance is 5% for both (although I've had as low as 1% and as high as 8%).
    Lowest (1/16/10)
    Displayed MPG: 33.4
    Calculated MPG: 31.77
    Variance: 5%
    Highest (5/29/10)
    Displayed MPG: 54.60
    Calculated MPG: 51.69
    Variance: 5%
  11. ricksprius
    ricksprius Junior Member
    31
    Saugerties, NY
    For me, over the course of 4 fill ups, the computer is averaging about 2.75 mpg optimistic.
    Tank-wise I am averaging 53.5.
    Was hoping for more as I was doing not too much less in my '03 in the warm weather.
  12. marvmark
    marvmark Junior Member
    Cincinnati
    Here are my numbers FWIW.
    14 fill-ups:
    average miles: 454.4
    average gallons added: 9.04
    average hand-calculated mpg: 50.3
    average FCD mpg: 52.8
  13. drsbm3
    drsbm3 Junior Member
    34
    manassas
    After ten fill-ups I am at 2.33 MID average over-predicting calculated. My average fuel mileage is 55.3 mpg and climbing now that summer has arrived (last 2 fill-ups averaged 59mpg). That is 4.2% over-prediction by the MID. I find that if I fill my tank with the same methodology each time (automatic pump click-off, then add by hand, one more click-off), I get pretty consistent MID readings, 4% high, plus or minus a few tenths.
  14. drsbm3
    34
    manassas
    Rick you are in the 85th-90th %tile for all GenIII drivers for mpg, and in the 99.9th %tile for all automotive owners. If you include oxcarts, rickshaws, horse buggies, bicycles, golf carts and other land vehicles, you are at the 99.99th %tile. So, relax and be proud.
  15. tedjohnson
    tedjohnson Member
    347
    72
    Greenfield MA
    2 fillups, MFD avg says 61.25 , Pump avg says 61.13 Pretty good agreement - 3/10 Date of manufacture.
  16. tickmark40
    tickmark40 New Member
    62
    Brownwood, TX
    I have 3 fillups. Total miles just slightly over 1100 and highway miles 850. Just made a long trip with A/C at 75 and cruise set around 70mph.
    Car computer is showing an average of 50.1 mpg and calculated it is 48.53. I am very happy with these numbers.
  17. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    computer 49.5 / calculated 47.6 mpg.
    same pump, same pump speed. veh parked at same spot when filling.
    had over 380 miles on tank.
    last fill up was 2.5 mpg off in the positive after over 400 miles, same pump etc.
    alfon
  18. traveler1600
    traveler1600 New Member
    Panama City, Fl
    I have 19,000 miles on my 2010. The computer continuously overstates mileage by as much as 4mpg. It has varied as much as 5 and as little as 1. The higher the mileage the more spread is realized. In addition to this Toyota misscalculation, the speedometer is between 1 and 2 mph off compared to three different GPS's that I've used. I haven't taken the time to figure out what the real overstatement error is. I was getting 49-50 by the computer, 47-49 by the pen and paper method. Over the last four tanks, the mileage has dropped to 40-42 driving the way I normally do. If I turn everything off and really baby it I get 45 mpg. That's with my normal day to day driving. When I get on the highway (once every couple weeks to the inlaws) The mileage is the same as it was 48 mpg. Everyone is talking about the heat and AC dropping the mileage, but I live in Florida. It's been above 80 degrees for some time now. I have an apointment wed to get the charging system checked.
  19. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    The weather in the northwest is getting warmer and the mpg's are
    getting better.
    here are the results.
    note: same gas pump / shut off on first click at slow speed/ same vehicle location when filling up.
    6/14/10 / 384.5 miles / indicated 49.5 / calculated / 47.632
    6/20/10 / 289.5 / 51.8 / / 49.554
    6/27/10 / 346.1 / 55.1 / / 53.131
    Remember Oregon is 10% Ethanol ALL YEAR LONG
    alfon
  20. tedjohnson
    tedjohnson Member
    347
    72
    Greenfield MA
    Average offset for 5 tanks of gas for me is the HSI reads 1.2 MPG over the pump calculated of 59.2....
