2010 oil change diy disaster!!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by cbo111, May 23, 2010.
  1. cbo111
    cbo111 Junior Member
    Calif
    Warning, Warning, Warning!!
    I just about blew my engine this week. While driving at 70mph at the start of a mountain grade, I look in my rear view mirror and see black smoke pouring out the the back of my 2010. I quickly pulled off the highway and smelled a burning odor as well as seeing smoke coming off the rear tire area and engine compartment. YIKES!
    I look under the engine area and see a mass of oil dripping all the way down the undercarriage onto the tail pipe. Hmmm, this isn't right.....
    A $275 tow into my toyota dealer for diagnosis. The diagnosis....someone put the o-ring on the oil filter housing incorrectly. That someone of course would be me. I have done three oil changes on this car and put the oring in the same slot every time. Apparently I was just lucky for the past 25,000 miles. There was no slow dripping or any other indication of a problem previous to the highway oil puke. Fortunately I only lost about 2 quarts according to the dealer, so no engine damage. If this had occurred at night I would not have seen the black smoke and probably drove on until the engine light came on.
    I am attaching a powerpoint slide to try and illustrate the correct slot or the o-ring.
    Don't do what I did and slide the o-ring all the way to the base of the filter housing. There is a slot just above the base that the o-ring fits into. I incorrectly assumed that the ring should go all the way down the housing.
    One of life's fun little lessons;)
    cbo
    Tehachapi, CA
  2. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    That was a close call. Thanks for the warning
    How far was your car towed, to rack up a $275 bill ?
  3. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Another reason why I don't like those cartridge-style oil filters
  4. cbo111
    Calif
    37 miles. Insurance company say they will pay, so I consider myself lucky.
  5. RodJo
    RodJo Member
    423
    56
    Boston
    That sucks. Good thing there isn't any real damage.
    I couldn't read your attachment, but it sounds like you placed your O-ring against the mounting flange. I believe the O-ring goes just at the end of the threads -- at least I hope that's right. There is a handy slot there to help remove the old O-ring.
  6. josh2008
    josh2008 Active Member
    365
    144
    Princeton, WV
    Consider yourself lucky, we have a 2010 Corolla with 5300 miles on it sitting in our shop that requires a new engine because its locked up for the same reason. What most likely happened is that the o-ring tore slightly (trust me, it doesn't take much) when you were twisting it in. This is why lubing the **** out of the o-ring and twisting it in to the housing very, very slowly is important.
  7. SageBrush
    11,627
    2,533
    Southwest Colorado
    Checking the oil level at fuel ups would catch slowish leaks.
  8. New_Yorker
    New_Yorker New Member
    517
    69
    Sounds like a good reason to let a dealer bear the responsibility for all the oil & filter changes. If the engine ever is damaged, there is a paper trail to show that you were not responsible for the "O" ring being damaged or installed improperly. Always the potential down side to back-yard mechanics.
  9. SageBrush
    11,627
    2,533
    Southwest Colorado
    I wonder if this is the reason my wife always lets me drive
  10. RodJo
    RodJo Member
    423
    56
    Boston
    Well a failure could be the fault of a poorly designed filter canister. The O-ring shouldn't come off or tear during installation. If the O-ring is correctly placed and there is a failure, then I think it's still Toyota's fault regardless of who installs the filter. The burden would be on Toyota to prove you screwed up.
    Anyway, all the paperwork just shows it that the dealer did the work shown by the paperwork. It does not prove that you didn't perform another oil change after the last dealer oil change. Again, if you or your mechanic does the change according to directions, I think any failure would be covered by warranty.
  11. socratesthecabdriver
    283
    31
    greece
    one thing i just realized is that wages in the states are so high that it is imposible to service your car in the dealers shop or by a car makers aproved shop!here in greece it will cost the same to get an oil change at the dealer as it does in a lube shop!the problem is that its faster at the lube shop making a lube joint favorable by most! then the problem is that if something hapens to the engine while in warranty they wont cover it if you change oils and service the engine out of dealer! i remember that does not stand in the states !! they just ask for the first oil change if i stand corect!?
    i just drive it about 250km a day.i dont mess with it! if nobody takes their cars to the dealers they will just end up crooks! that is arguable i know, they are considered to already be crooks but always start out in good faith!the law tends to be on our side!
  12. tumbleweed
    tumbleweed Senior Member
    4,067
    690
    Eastern Oregon
    I saved a couple of the old O rings that I removed when changing the oil filter. Last time I changed oil and filter I climbed under the car after I ran it for a minute or so and noticed a little oil on the bottom of the filter housing. It is possible that the oil was just left over from when I removed the filter but I don't think so, I clean that area pretty carefully.
    I took the filter back out and installed one of the old O rings and checked it again the next day after driving it 20 or 30 miles. No more leaks. I found no sign of damage on the leaky O ring and it was in the correct slot. I put it on with a torque wrench, 215 inch pounds. This was my fourth oil change and I had no leaks the other three times.
    This may be an area that we need to watch, it could happen just as easily if it were done by the lube guy at the dealer. The under engine cover makes it even worse because the oil may not drip down on the driveway where you would see it.
    I suggest running the car a few minutes after you finish the oil change then climb under again and inspect all around the filter area for oil seepage.
  13. Den49
    Den49 Member
    498
    269
    Maryland
    I strongly concur with using a torque wrench to tighten both the filter (18 FT/LB) and drain plug (27 FT/LB) on the 2010 Prius.
    The 2010 Prius cannister/cartridge filter with o-ring has a different feel than the old metal can filters so it is risky to rely on the old school hand tighten feel or number of turns method to tighten it. Also, it is intersting to note that the torque requirement for the metal can type filter on my 2007 Camry is 10 FT/LB, which is typical for such filters and less than the Prius. If one uses the hand tightening method on a Prius after having been used to doing so on metal can filters, it is likely that the Prius filter may not be sufficiently torqued.
    We can still change our own oil on the Prius. I know I will be more careful than the junior tech at the dealer. However, I have come to realize that the Prius is much more sensitive to perfoming even routine maintenance/repair operations according to the book than other cars I have owned.
  14. adric22
    adric22 Ev and Hybrid Enthusiast
    642
    145
    Fort Worth, TX
    I just want to confirm. Does the 2010 Prius use a different style oil filter than the 2009 and previous? I change my own oil on my two 2008 models and the only O-ring I've ever noticed is attached directly to the filter. I always put a little oil on the ring to make sure it seals well. I just want to make sure I don't end up in the same situation.
  15. walterm
    walterm Active Member
    466
    202
    34
    2022 Prius Prime
    Yes, the 2010 Prius filter is simply a filter element that goes inside a housing that you remove/replace. The O-ring for the housing is along the side where the threads are, as opposed to on the face/mating surface.
    It's more environmentally friendly (less waste) but slightly more hassle to deal with.
  16. Mendel Leisk
    40,467
    I'm a current Civic Hybrid owner, but have been reading up on the Prius. I managed to download a pdf owners manual. I'm a little suprised to find no oil change instruction in there. Might help if they published an instruction. Is there one, short of springing for the full Service Manual?
  17. fotomoto
    fotomoto Senior Member
    5,626
    3,802
    So. Texas
  18. GSW
    GSW PRIUS POWER
    537
    74
    Jacksonville
    YIKES is right! I've changed my oil and filter in my 2010 Prius 4 times already in the past year and a half. Now I'm concerned about whether or not the O ring stayed in the groove. You can bet I"ll be double checking the next oil change to make sure that its not leaking!!! (Also keep a little closer eye on dip stick levels for while.)
  19. Mendel Leisk
    40,467
    Fotomoto, thanks for that!
    I see the pdf is produced by a DIY'r, not from Toyota. There's an odd disconnect here, that Toyota doesn't publish something.
    Hmm: when I save the pdf I see it's the second one I've found: both are by DIY'rs though.
  20. tumbleweed
    4,067
    690
    Eastern Oregon
    I agree that Toyota should put DIY oil change procedure in the owner's manual, unfortunately Toyota owner's manuals are not very good. They do have an oil change procedure in the maintenance manual but the DIY versions on this site are much better.
    I think they should hire some PriusChat people to write, or at least edit, the owner's manual. I won't be holding my breath waiting for that to happen though.
