AC Leak, is it the compressor?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by khameleon, May 20, 2010.
  1. khameleon
    khameleon New Member
    Hello, I just came back from the local toyota dealer with some bad news. Apparently I need a new compressor quoted at $3200.00 Cdn.
    A few weeks ago I took my 2004 Prius into the dealer to get an AC diagnostics. At that time it was hardly working just blowing warm air. It did seem to be a bit colder tho when the car was in motion. With that visit I was told that there is a leak in my AC system and they recharged it and added a dye, to help determine where the leak was coming from. I was told to use the AC as much as possible from then till my follow up appointment.
    During the next week and a half I used my AC all the time. and it has been working fine. I have noticed today tho that it seems to not be providing cold air when the car is stopped, I assume because of the leak and the quantity is going down. Anyways I took the car in today to see where the dye was coming out, after a bit of a wait I was told it was the compressor, and it was noisy.
    When I run the AC and listen to it, it seems to purr and I don't notice any abnormal sounds. Kinda sounds like an air pump we use for our air mattresses. I asked to speak to the mechanic so they could explain to me what exactly is going on, did they find a leak, and if so where was it. It seems weird to me that the noisy compressor was not mentioned two weeks ago when the dye was added. Not to mention the AC seems to work fine when the fluid is topped up. So what exactly is wrong with the compressor then? Do Compressors get internal leaks?
    Unfortunately the mechanic could not be found, so I am waiting for a call back. This is a Toyota dealer, but they are big. It is like a production line there, and a line up of cars to see a mechanic. So I was unable to get the hands on explanation that I am used to with a mechanic. I just got handed a sheet with a 3200 dollar estimate.
    I know AC systems are tricky but has anyone had or heard of a leaking Compressor, that needed to be replaced. I guess my only other option is to try another dealer, or wait to hear what this mechanic has to say so I have a better understanding of what is wrong. Thanks for you time.
    Khameleon
  2. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    511
    63
    Welcome to PriusChat! You came to the right place. There are many experts here (I am not one of them).
    For $3200 I would definitely ask to talk to the technician and also get a second opinion from another dealer.
    I made a recording of my AC compressor sound here:
    I was concerned with the staring noise but later the dealer said it was normal.
  3. khameleon
    Thanks for your video. With it I took my laptop out to my car to do a sound comparison. I put the car in ready mode, Max cold was set and listened. The sound was very similar. My Blower fan seems a bit noisier so its hard to tell. But all in all the compressor sounds consistant.
    But after about 30 seconds, the compressor stopped. I went and looked and it was still set for max cold. After 20 seconds or so warm air made its way into the cabin. This would perhaps explain why it feels like its not working when I am stopped at lights. I am a little perplexed as its an electric system and should have no care if the car is in motion. Is there something that would be shutting it off to lower the load on car. Is this a symptom of the Compressor failing or something else? I let the car sit in ready mode for a few more mins and the compressor did not come back on. I then shut the car down and restarted it and it worked again for a short time.
    Any ideas?
  4. Patrick Wong
    18,200
    6,500
    Since a dye was added to your system, you should be able to see the location of the leak. I suggest that you have this pointed out to you.
    If the compressor housing has a tiny crack within or if a gasket has failed, that might be the source of the leak. If the problem is a gasket, ask whether that can be replaced.
  5. derkraut
    derkraut Member
    299
    28
    SAN
    $3200cdn for a new compressor? I don't think so. I suggest you go somewhere else for a 2nd opinion. Large Toyota Dealers can give you the shaft, just like any other auto repair facility. If it's a leak, it's probably in a hose or fitting. Repairing that should be around $200-300cdn. The compressor is probably shutting down because it is out of refrigerant.
  6. khameleon
    Do you know if it was visable dye? Do you need a black light to see it? I know they should have shown me, and I asked but its like fast food there, in and out. Really disappointed..
    I will have to look around for someone else. If the dye is already there, it should save on the diagnostics.
    I forgot to mention its 3200 just for the compressor not the labour. I could get central air for my house for less then that.
  7. Joe 26
    Joe 26 Member
    242
    42
    Columbus, Ohio
    Yes the dye shows up under UV light.
  8. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    The dye generally isn't daylight visible. You need a "black" light to see where it is
  9. 2009Prius
    2,705
    511
    63
    Would a UV LED do?
  10. khameleon
    Will have to try and locate a black light and check it out at night.. I have been looking around and see referb compressors for 350 US. Has anyone had any luck with these.. Could almost by 10 of them for the price of one Toyota unit.
  11. jayman
    13,439
    641
    Winnipeg Manitoba
    It should work
  12. khameleon
    Well I got a UV light and looked all over and didn't see anything obvious. I also put a AC current meter on the cable and found that the compressor was pulling anywhere from 3.5-5 Amps. I did however pull off the cap on the low pressure side and when i did i head a small hiss, and it was wet and showed the fluid with the UV light. I then checked the H pressure side and heard the same hiss, but not nearly as much fluid there. Is it normal to have a hiss when removing the cap? Or is that a possible leak? Also I can't wrap my head around this. Why would a Compressor that runs off an electric motor not work when the car is not moving? Any Thoughts?
    Thanks
  13. jayman
    13,439
    641
    Winnipeg Manitoba
    Maybe I missed this earlier, but was the pressure checked and adjusted?
    It's normal to hear a slight hiss when you remove the cap
  14. khameleon
    Yes a few weeks ago when I took it in. they told me it was a leak, topped it up and added the dye. On my follow up visit I was told it was the compressor. But never informed where the leak was. After they added the dye and topped up my system, The AC worked much better.
    Khameleon
  15. jayman
    13,439
    641
    Winnipeg Manitoba
    No A/C system is 100% tight. Over the years, you must expect slight migration of H-134a. If the factory fill was marginal to begin with, over time you can expect problems
    So, to clarify, the A/C works much better but still isn't 100%?
  16. khameleon
    It worked much better after the fill up but now it is getting less capabile of cooling the car as time goes by. I imagine because of a loss of freon. Also it will be blowing cold air and when I come to a stop the cold air fades away and the cooling will stop completely till I get the car in motion again.
  17. Patrick Wong
    18,200
    6,500
    Make your car READY, turn on the A/C, then open the hood and look at the radiator fans. At least one fan should be blowing. If not, that will be the explanation for the above problem.
    It is possible that your air conditioning system has two issues: the refrigerant leak, plus something else.
  18. khameleon
    Just checked the fan. It is going and shuts off if I turn the AC off. I read a post of the forum and a person had an issue with the ac not working when the ICE was not running. The solution for them was a new AC amplifier. What exactly does this do. Since it is a similar problem thought it was worth asking.
    Thanks.
  19. Patrick Wong
    18,200
    6,500
    See page BE-106 in the first attached file. The other file provides an overview of the system.
