How much do TPMS sensors go for?
Discussion in 'Gen 2 Prius Main Forum' started by Supreme, May 27, 2010.
  1. Supreme
    Supreme Hypebeast
    182
    Philly
    I installed some new wheels and they couldn't transfer my sensors over. :mad: Guess i'll be riding around with an orange light. I'm thinking about dumping my sensors now as they are just collecting dust. What is a fair asking price for them?
  2. RobH
    RobH Senior Member
    2,373
    987
    70
    Sunnyvale, California
    I got one off eBay for about $25 delivered.
  3. David Beale
    David Beale Senior Member
    5,963
    1,987
    Edmonton Alberta
    Put the sensors in the car and reset the TPMS system. Your light will go out and stay out. At least then they will do -something- for you. ;)
  4. Supreme
    Supreme Hypebeast
    182
    Philly
    One or all 4??
  5. Mike Dimmick
    Mike Dimmick Active Member
    963
    249
    Reading, UK
    Champion ToyotaWorld wants $76.78 apiece for new ones.
    Was there not enough space in the new rim for the sensor to fit?
  6. Patrick Wong
    18,200
    6,491
    All four, assuming that the system can be tricked to keep the warning light off when the TPMS sensors are registering 0 psi pressure.
  7. RobH
    RobH Senior Member
    2,373
    987
    70
    The current pressure has to be something like 8 psi over the warning level. Some people have commented that it's 75% of pressure at reset. Would be an interesting test to see if 75% of zero passes the test...
    One idea I've seen is to create a manifold out of PVC pipe. Drill holes for the sensors, mount them inside the pipe, cap off both ends. Then inflate the rig to enough pressure to make the sensors happy.
    Another idea is to just unplug the TPMS computer. That will either shut it up, or make another computer freak out over it's absence.
    Or you could purchase sensors that fit your new wheels.
    The eBay unit that I bought got put in my spare tire. I think TPMS is great. I'm not very good about checking tire pressure, and TPMS is far more attentive. I should really try setting the warning pressure as close to operating pressure as would work without false triggers.
