Wall charging HV battery
Discussion in 'Gen 2 Prius Accessories & Modifications' started by shortbus, Jan 3, 2008.
  1. shortbus
    shortbus N00B
    Cincinnati
    Is there a way to wall charge my Prius battery so that the battery is all green when I go to work in the morning?
  2. Flying White Dutchman
    4,376
    313
    yes
    buth it needs some instalation work..
    any money
    there is a company ( going to look it up ) that provides a straight current 500 volt output from a 110/220 volts wavevorm input
  3. Flying White Dutchman
    4,376
    313
    here is one
    http://www.brusa.li/e_welcome.html
    not the 1 i was looking for but anyway when i find it i wil post it
    was a us based company and the charger was green colored
  4. shortbus
    shortbus N00B
    Cincinnati
  5. Flying White Dutchman
    4,376
    313
    http://www.Manzanitamicro.com/
    yes thats the one
    just found it myzelf
    i emailed them to
    only a long time ago..... got a price back somewhere around 2600 dollars and 75 for shipping within us
  6. shortbus
    shortbus N00B
    Cincinnati
    Alright.
    HAH.
    I buy one and hook it up how?
  7. hawaiiguide
    hawaiiguide Junior Member
    35
    Honolulu
    Why do you need it? I can make my 06 go all green within 5 miles.
    Suggest you try experimenting with the accelarator pedal to get green bars. On our car they come and go quickly... easy come... easy go.
    Good luck.
    hawaiiguide :)
  8. patsparks
    10,664
    567
    Adelaide South Australia
    The traction battery isn't 500 volt, isnt it more like 210V?
  9. bestmapman
    1,289
    242
    Kentucky near Cincinnati, OH
    Please describe what you are doing to accomplish this.
  10. shortbus
    shortbus N00B
    Cincinnati
    More reading and a few emails from people that know more then me got me the conclusion that this is pretty pointless.
    Sorry for wasting your scroll mouse. ;)
  11. Flying White Dutchman
    4,376
    313
    wy?
    because for you it means spending a lot of money on it because you can not do it yourself?
    if you can DIY then its not pointless i think
    what are the arguments?
  12. shortbus
    shortbus N00B
    Cincinnati
    Well, It id completely do-able.
    That was a clip from an email I received. So, yes it would be do-able, but no one has done it because it is pretty much pointless.
  13. Flying White Dutchman
    4,376
    313
    o yes
    always add battery's when using plugin:D
    i am sorry i think plugin and add. battery's as the same thing:)
  14. David Beale
    David Beale Senior Member
    5,963
    1,988
    Edmonton Alberta
    It's worse than pointless to try to charge the stock NiMH battery. It's going to shorten the battery life. There are very good reasons Toyota doesn't want the battery fully charged - EVER!
    1. A NiMH battery becomes inefficient at accepting a charge once it gets to about 80% charge, and begins to convert about 1/2 or more of the charging energy to heat. In other words, you could easily overheat the battery, if not when charging, then after, when driving. Yes the system will sense the temp rise and cut off the charging, but that happens -after- it heats up. The cells with the lowest capacity will heat up the most, and they -could- overheat enough to loose electrolyte. They would then have even lower capacity. You would quickly (perhaps as quickly as a few weeks) spiral into a non-functioning battery.
    2. You will fool the system as to its' state of charge. It's not nice to fool the system! You DON'T want it not knowing what's what!
    The reasons the stock battery lasts so long include:
    a) Care was taken to "match" the cells in each battery re capacity and chemistry (both vary a bit in a production line).
    b) The battery is never allowed to fully discharge or even approach full discharge. This is to ensure the lowest capacity cell will not fully discharge. If it does and the system continues to discharge the battery that cell will be charged in reverse. This is death to NiMH cells. They "whisker", shorting themselves out of the battery.
    c) The battery is never allowed to fully charge or even approach full charge. This is to ensure the lowest capacity cell will not fully charge. If it does and the system continues to charge the battery that cell will overheat a lot and vent electrolyte, loosing still more capacity. The next cycle will be worse still, the cycle after that even worse again. The cell will quickly loose enough capacity that the battery will loose the function of that cell.
  15. shortbus
    shortbus N00B
    Cincinnati
    Yeah, thanks.
    That is pretty much a rehash of the emails I got.
  16. Syclone
    Syclone Member
    540
    The whole point of the battery is to accumulate what would otherwise be wasted energy using regenerative braking, allowing the ICE to operate in it's most efficient power band and dumping the excess power into the battery, etc. During driving you can go from a virtually discharged battery (20 - 30%) to 7 green bands in a few minutes.
    Externally charging the NiMh battery would, at best, give you about 1 - 1.5 miles of range before the ICE kicks in.
    Based on this, there is, truly, no point to externally charging the NiMh battery. If you were able to install a battery with about 10 times the capacity, an external charging system would become practical.
  17. Flying White Dutchman
    4,376
    313
    stop talking about the standard batt.
    put in some add. batt's and use them to keep the stock batt no more then 80% ( i am reading post above about this ) charged
  18. AkustaVirtaa
    AkustaVirtaa Sähköistäjä
    198
    Finland EU
    Is this still true?
    I really like to charge it anyway. For me half mile is something…
    Any new chargers in market or DIY experiences?
  19. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    Yes it is still true, there are however a good range of add on battery packs that are relatively cheap IF; you want to go to the trouble. There are several threads on this, do a PC search.
  20. vertex
    vertex Active Member
    672
    144
    new york
    2018 Prius Prime
    Well, It may or may not be pointless. I am making an inexpensive charger for this purpose. My case may be unique however. My morning commute is 2.2 miles. I can make it in EV mode if I start out with a green, or almost green battery charge. The ICE does not run at all for the commute then. I end the trip with about the same charge I start with, the last part of the trip is a steep downhill grade that recharges the battery.
