What pump starts running under the hood when I open the door?
Discussion in 'Gen 3 Prius Technical Discussion' started by Ripley44224, Jun 9, 2010.
  1. Ripley44224
    Ripley44224 Member
    44
    Northeast Ohio
    Just curious-- After several hours of not running, I open the driver door and hear a pump of some kind start up and run under the hood. Runs for a while then stops. How long seems to depend on how long the car has sat there, but about 30 seconds max. Anyone know what it is?
  2. phoenixgreg
    phoenixgreg Senior member
    1,157
    294
    66
    Phoenix
    I think I read in another thread that it is the power brakes adding some pressure so you have instant braking just in case you run in EV mode briefly.
  3. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Yes, it's the brake accumulator pump...
  4. Ripley44224
    Ripley44224 Member
    44
    Northeast Ohio
    Thanks, all!
