Front end bra/mask installation difficulty
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by mondokj, Aug 11, 2005.
  1. mondokj
    mondokj Junior Member
    Seattle, WA
    I have a 2005 Package 6, with the HID headlamps.
    I purchased the "official" Toyota Front End Mask, and tried to install it last night. I am having one problem.
    There are two tabs on the mask (1/2" X 8" or so) near each headlights. According to the directions, you're supposed to tuck these in on the side and bottom of the headlight assembly.
    Easy enough to describe, but the seam between the body panel and the headlight assembly is really tight! I tried a screwdriver to pry the surfaces apart, and loosening the headlight top screw, but nothing seems to help.
    Any suggestions on how to get those pestky tabs tucked in??
    -Keith J.
  2. Bill Lumbergh
    Bill Lumbergh USAF Aircraft Maintainer
    537
    NorCal
    Same here! I had to fully remove the top headlight bolt (10mm), then you'll find you have a heck of a lot of headlight play to work with. It helps to have someone hold the headlight up off the fender while you cram the tab under the frame, then push down on the headlight, push in on the tab, and tighten the bolt you removed.
    Go Toyota with the tight clearances!
  3. BMcGraw
    BMcGraw Member
    230
    Southern California
    Put away that screwdriver! :mrgreen: All you have to do is start the tab "insertion" at about the 7 o'clock position on the left (passenger) side and at the 5 o'clock position on the right. It's a tight fit but it will go. Then it will slide right on up without a hitch.
    Hope that helps!
  4. Bill Lumbergh
    537
    NorCal
    I tried starting the tab as you said and it just wouldn't go. The clearance between the headlight and the fender was absolutely zero. Removing the headlight bolt made it much simpler.
    Wish mine was as easy as your's. :)
  5. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    ours was the same way. ugh. pain in the butt. we ended up loosening the headlight assembly too.
  6. BMcGraw
    BMcGraw Member
    230
    Southern California
    "If I have to come over there...." On second thought, no comment... :roll:
