cpap machine charging from Prius in campground?
Discussion in 'Gen 2 Prius Main Forum' started by jendbbay, Jun 20, 2010.
  1. hyo silver
    hyo silver Awaaaaay
    15,261
    1,601
    off into the sunset
    I've left my Prius locked and running in a campground before, and it's worked well. But I was only powering a cooler for a short time, not a cpap machine, so the suggestions of getting an inverter and trying it at home first seem like good ideas. You may find an available outlet in the campground, so you could pack an extension cord just in case. A little note on the receptacle explaining the 'mission critical' use might not hurt, either, just in case someone else decides they need the outlet more than you do, since you're sleeping anyway and 'obviously' not using it. :rolleyes:
  2. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    did i forget to mention i've powered my uncles breathing machine and air mattress of my setup for 7 hours or so... including charging his wheelchair?.. the power was out for 10 hours or so... grid power switched back on around 4:30am that morning.
    i've even used it while camping... that was only an amp or so
  3. jendbbay
    jendbbay Member
    223
    Everyone who has responded is amazing. I wanted to thank you and say that my husband is reading and deciding and we will probably have some more questions. I love Prius chat and finally have managed to get him into it. He is so busy driving the car that he doesn't have time to study it. We are tickled over the idea that it is a generator and can be used during the post earthquake periods that we have out here from time to time. I am not exactly sure how we will solve this issue, but we will be updating you.
  4. jendbbay
    jendbbay Member
    223
    from my husband
    "I will be getting a 1K inverter with pure sine wave output. i'm worried that this may run down the battery if i leave it on overnight. I have seen 800 mA as the minimum current draw of these units. It that's true, I would have to remember to turn off the inverter or risk losing my battery. That's what I'm worried about. I guess I should just become a member, and I could then use my own password. "
    I would give him mine, but i can't figure out what it is! I am auto logged in.
  5. fuzzy1
    10,335
    Make sure hubby reads the Harvard Press article that Evan points to in reply #7:
  6. richard schumacher
    7,664
    1,043
    United States
    Leave the car ON ("Ready", exactly as though you were about to drive it away) in Park and the parking brake set. The car will start the engine as needed to keep the batteries all charged up. You can do this until it runs out of gas. That would probably take a couple of days if you start with a full tank. Test the setup in your own yard before taking it on the road.
  7. LeadingEdgeBoomer
    289
    29
    New Mexico
    The online source where I bought my latest CPAP machine (fax them the prescription) also has rechargeable battery packs that are compatible with various machines. I don't know if they have enough power/longevity for a humidification module.
    This may be more convenient if you have daytime access to AC power for recharging.
  8. jendbbay
    jendbbay Member
    223
    Okay, i think the question really is, if the inverter he plans to buy draws 800 mA standby current when the switch on the inverter is on, but the inverter is not connected to any devices, then will this discharge the 12 volt car battery completely? He fears he will forget to turn off the inverter switch. Though, I believe I will always tell him to turn it off, I admit he is pretty forgetful.
    The inverter does have a cutoff when the battery reaches low voltage, but he doesn't know if that does the job of preventing the discharge described above. He doesn't yet have the inverter.
    Again, many thanks.
  9. Patrick Wong
    18,200
    6,492
    12V x 0.8A = 9.6W. This is equivalent to one light bulb left on.
    Suppose the car is IG-OFF and the inverter remains on for 8 hours. This will result in 6.4 Ah being taken from the battery. When new the battery's capacity is ~36 Ah. Normally you should not discharge the battery below 50% if you desire long battery life.
    The bottom line is that if the 12V battery is fully-charged and in like-new condition, leaving the inverter on for an 8 hour period will be OK. However, if the battery is marginal then leaving the inverter on for that time may result in a no-start situation the next day. Hence you would be well-advised to make sure the inverter is off when not in use.
  10. V8Cobrakid
    3,790
    152
    as richard has said.. leave the car ON in Ready mode.... with the car in park... parking brake applied too.
    as for the inverter.. you'll only use it for camping and power outages. attach a quick-connect on the 12v side... this way, when you're done using it, you can unplug the entire unit... instead of worrying about shutting it off by a switch. it also allows you to take it out of your car whenever you want.
    i recently disconnected mine. if i were to leave it on when i turn the car off, i would hear it's internal fan run... if my 12v starts to run low, it sets off an alarm. (audible outside of my car)
  11. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    511
    63
    As mentioned earlier many campgrounds now have sites that supply 120V AC power (and running water). I would look into that as a hassle-free alternative.
    If you go with the inverter route I would triple check that the Prius dash shows "READY" before going to sleep.
    Good luck! :)
  12. rld
    rld New Member
    norcal
    Thanks for all the info everyone. I'm the guy trying to install a 1KW inverter. Up till now I have been asking messages via my wife, jenbbay.
    I'm still trying to figure out a few things.
    1) Should I really put in the 150A fuse as the Xantrex docs demand or should I join the Darwin club?
    2) Will the 10.5 volt cutoff on the inverter save the battery if I leave the inverter power switch on by accident? The consensus here seems to be that if I forget to turn off the inverter and go into non-ready on the prius, then the battery gets totally discharged. I wonder if anyone actually has had that happen?
    3) Where can I get a 90A quick-disconnect, i.e. a socket and plug? I see 50A ones for 120VAC and 240VAC but no 90A ones (of course one for 120VAC would work fine for 12VDC as well because the insulation will be better than needed.) Digikey and Mouser don't seem to have it.
    I went to West marine and they have all of this stuff but the $ is adding up. They want $350 for the inverter, but the web shows $250, which I can also get at Fry's (NorCal) too. The cables are $20, fuse $20, fuse block $30 etc etc. Maybe I should go down to 600W or less.
    All this just for a CPAP driver.
    Anyone have experience like this?
    Thanks
  13. fuzzy1
    10,335
    Actually, this is not a good assumption, even though it is done frequently.
    Many AC disconnect devices rely on the zero crossings of the alternating current to function properly. When the contacts break, they allow an arc to flow initially, with the expectation of extinquishing it at the next current zero crossing. For this reason, very many 120VAC fuses, circuit breakers, and disconnects do not have agency approvals for any DC, even 12VDC.
    This distinction is very important for systems that require permits and electrical inspections, such as home solar installations. But for projects without permits, a huge number of people get away with this substitution.
    The other caveat is that 12V systems cannot tolerate as much voltage drop as 120V and still function as intended. But at 90 amps, you will know this by how hot the parts get during operation.
  14. gatorglenn
    gatorglenn Member
    138
    45
    Atlanta
    I am a CPAP user and I sometimes camp on motorcycle trips. I posted a note before about a possible solution using a seperate 12 battery.
    Honestly I think using a 15 to 30 thousand dollar car to run a CPAP machine overnight is nuts. Why risk any damage to your car or even run it more than needed if you can get a battery backup for a couple of hundred dollars to do what you need?
    Just my 2 cents worth and it ain't worth much.
    Good luck,
    Glenn
  15. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,800
    Undisclosed Location
    Please, please, please,...
    Whatever you do, test it out extensively before leaving...and I'd also have a back-up source.
    It's PURELY SELFISH, but I don't want to wake up and see headlines on FOX NEWS exclaiming, ....Toyota Prius suffocates man while sleeping......
  16. qbee42
    3,076
    You can buy a DC disconnect from a marine or RV store. Don't assume that AC devices will work well on DC systems.
  17. rld
    rld New Member
    norcal
    I'm amazed at all the attention on this. Thanks.
    I have just finished putting in a 1KW inverter (Xantrex) into the Prius by connecting 4AWG cabling through a 150A ANL fuse directly to the battery. The connection is difficult due to the thickness of the cable and the wimpiness of the connections to the battery, but it is conservative on my side so I don't see any problem. The 4AWG is capable of about 100A.
    The ground wire from the battery is rather thin - probably only 8AWG or smaller. It is hard to believe that the battery can be recharged on an engine-on duty cycle of 5min/hr or some such low percentage of the time without requiring huge current to average it out. I don't remember where I heard about this 5min/hr but that is the basic idea. That huge current would have to be a multiple of the current I am drawing, which is about 80A at 1KW. So we would get 1hr/5min*80A = 960A. How does this work out?
    The fact that the inverter is 1KW allows me about 15Ahr/90A = 10min of runtime without charging. I read about a guy or two who put in such an inverter and then ran power tools at construction sites or as emergency power to a house on an almost continuous basis, so again, the fast charging capability is needed.
    Does anyone know how the charging can be at such a high amperage? The small ground strap makes it look improbable. The DC/DC converter seems necessary for this all to work out, so if that is the source of the power - the traction battery - then I should not connect the negative inverter to the negative on the 12v battery but instead to the chassis ground. The cable coming into the positive on the 12v battery is about 4 or 6 AWG, so that part looks OK.
    Being a pure sine inverter - which is apparently required for the cpap's humidifier - bumped up the $ tremendously (0.5K$).
    I hope this is clear. It is rather complex situation due to the various power sources.
    There are indeed campgrounds with power, e.g. in Oregon, but we're going to the high Sierra where there aren't any. I could probably get away with separate batteries but there still needs to be wiring of various kinds for the recharge and we have to carry batteries around etc. The car would have to stay put during the daytime recharge, but we want to drive around. We are going for two weeks, so a single charge on the battery is insufficient. A single night requires about 3.6A*8hr = 28.8Ahr with humidifier, so only a big battery can do it if we want to stay to less than 50% state of charge.
    The inverter serves in an emergency too.
  18. Patrick Wong
    18,200
    6,492
    The 12V battery is charged whenever the Prius is READY. Once the Prius is READY, it doesn't matter whether the gasoline engine is running or not, from the point of view of the 12V battery, since it is charged by the DC/DC converter within the inverter. The DC/DC converter maintains a constant ~13.8VDC when the car is READY, and that voltage level is what causes the 12V battery to be charged at a moderate pace.
    You are right that the inverter negative cable should be connected to body metal in preference to the negative terminal of the battery, because the inverter will be obtaining power from the DC/DC converter, not the 12V battery. Good luck, hope you have sufficient time to test your inverter over a prolonged period prior to embarking on your vacation.
  19. qbee42
    3,076
    Adding to Patrick's comments, in Ready mode all of the 12V power comes from the HV battery via the DC to DC converter. Your CPAP machine will be powered by the HV battery, not the tiny 12V battery.
