HV battery possibly going bad, dealer said so too?
Discussion in 'Gen 2 Prius Main Forum' started by desertrider2215, Jul 1, 2010.
  1. desertrider2215
    156
    usa
    About to hit 130,000 in 20 miles. For the past 10-15k miles, I have been consistently getting under 40 MPG, about 36/37. Only can I get 40+ for a whole tank when I do mostly highway driving. Before, my tanks would average 42-48 mpg. I can't for the life of me get over 40 when driving in the city.
    My battery is also doing some funky things..sometimes when I turn the car on for the first time on a new day, my battery will go from green or blue (the blue right before it hits green) and will literally drop to one or two slivers of red in 15 seconds. I took it in when it first started doing that and they did a software flash or update, something along those lines.
    I thought that would've worked, but my low mileage still remained. I'm not complaining about 36 mpg cause its better than my old car (12). I am mad because if my hybrid battery is going, the dealer needs to replace it while it's still under the 150,000 mi. calif. warranty. Called the guy up again at the dealer today told him the software flash did not work, he said they cannot replace it until they can replicate the actual battery dropping from blue to low red in 15 seconds. How the hell am I supposed to show them that? I can hardly make it happen, but it sure is a sign that the battery is going as our other Prius does NOT and never has done that. I even sometimes lose power on the freeway when going up large hills, the car will completely lose power when the gas is applied.
    He even said that he thinks the battery is going but what are the limitations on the warranty and what needs to happen before they replace it? Haven't had good experiences with this toyota dealer anyways:eek:
    thanks!
  2. Patrick Wong
    18,200
    6,491
    Perhaps you could make a video of this happening.
    Usually the Prius will have to log a DTC that relates to the traction battery before the dealer will agree to replace it under warranty. Your service advisor is probably going out on a limb by saying the dealership would be willing to take action on the basis of the SOC display dropping quickly.
  3. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    If it was me, I would sure check the 12 volt battery, before swapping the HV battery.
  4. desertrider2215
    156
    usa
    Good thinking, I did when this whole thing started and ended up getting a new one. Thanks : )
  5. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    So even with a new 12v, it is still doing this?
  6. desertrider2215
    156
    usa
    Yes, I have had the new 12V in for probably 4 months now, my tank right now is 35.7 for 200 mi :eek:
  7. striker308
    striker308 Three time Prius owner
    302
    43
    Evans, NY (USA) / South Williamsport, PA (USA)
    I have had mine do that from time to time. I'm at 90K now and the dealer tells me as long as it regenerates to "any level" I'm they won't even look at Error logs. here in NY its only 100K warranty on the HV.
    I have had the car for two years now, only twice seeing a green condition. its allways blue. I have very short in-town drives, over 90% of my drives are highway and are 40 plus miles one way.
    I have noted that when I have seen the HV do this it has been on a hot day and the auto temp is at max trying to cool the car. since you are in CA hot in NY is normal there. do you leave the Auto temp on when you shut the car off?
  8. sktn77a
    sktn77a Member
    303
    NC
    Desertrider: I wouldn't panic - you've got 20,000 miles of warranty left. Even then, if you have a record of this issue and it keeps recurring after the warranty expires, you should be covered. It's annoying that you aren't getting the mileage you're used to getting. Have you considered taking it to another Toyota dealer for a secon opinion?
  9. RobH
    RobH Senior Member
    2,371
    987
    70
    Sunnyvale, California
    Here is an example of the battery report that the Toyota Techstream scantool software produces. You might try to get a copy of it from your dealer.
    This report is from a normal condition 2006 Prius with about 40,000 miles on it. Any comments about what values to look out for would be welcome.
  10. dhancock
    dhancock 2 Prius Family
    357
    40
    Hamburg, NY (Buffalo area)
    Look again. NY has same emissions warranty requirements as CA. It's 150K on the HV battery.
  11. Patrick Wong
    18,200
    6,491
    This diagnostic report shows that the difference between minimum and maximum module voltage is very small (which is good) and also shows that module internal resistance is very small (which is also good).
    If the OP obtained a similar report for his car, my belief is that report would show a similar result. Otherwise the OP would see the master warning red triangle light as well as the MFD hybrid vehicle or traction battery warning icon.
    The problem with the diagnostic report is that it does not show capacity of the modules, which has undoubtedly diminished in the OP's car, since it has logged 130K miles. Note that the Toyota hybrid system warranty does not guarantee that the traction battery capacity will remain the same as a new car.
    If I was the OP I would be inclined to "stress" the traction battery by taking a drive to a local mountain (for example Big Bear or Lake Arrowhead, or head north on I-5 to Tejon Pass.) Or find one of those roads that has a sign saying to turn off your AC to avoid engine overheating, that would be ideal.
    Drive uphill as quickly as possible with the AC on full blast, to put the powertrain under heavy load.
    When the car loses power, do any warning lights come on? What does the traction battery SOC gauge show: one red bar, no bars, or what?
    Can you take a video that shows the car is READY, the shift selector is in D, you are depressing the accelerator pedal fully, and yet the speedometer reading is declining?
  12. esdras29
    esdras29 best prius
    adelanto
    drive it goin uphill to you hits red so burn up faster..thats what the dealer want..
  13. desertrider2215
    156
    usa
    It does this when my battery bars are high up in the blue. I took the car in yesterday to the dealer and they now reset the system or something. They had their guy who is the "dealer pro" on hybrids look over it and do some stuff so we will see. Have 30 miles on this tank and it's at 33 MPG now, we'll see!
  14. desertrider2215
    156
    usa
    Here's a picture of my current mileage:eek:
    Bunch of bullsh!t if you ask me.
  15. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Maybe fill out the mpg questionnaire, there could be other factors.
    But in the mean time, consider this: Very very few other cars will even get close to the "low" mileage you are getting now.
  16. desertrider2215
    156
    usa
    I understand that, but I used to be getting 45-48 in the city, now it's this. So there's something wrong, taking it back this week. Maybe its just old, lol:rolleyes:
  17. Patrick Wong
    18,200
    6,491
    Was that photo taken 10 minutes after you had started the car for the first time that day? Or was it taken after the engine was already hot, you had turned the car off, then turned it back on and driven it for 10 minutes?
    If the former, normal behavior would show the first bar at around 25 mpg because the engine is cold and the ignition timing is retarded upon first startup. Lots of energy is expended on warming up the catalytic converter.
    Then you would expect to see subsequent bars at 45 mpg or higher depending upon driving speed, terrain, etc.
    I am wondering what is the engine coolant temp when the drivetrain has warmed up. Normal temp would be around 190 degrees F. Perhaps you might ask for this to be checked when you take the car in, as engine coolant temp is accessible to the Toyota diagnostic laptop. (Or if you have an instant read IR thermometer, you can measure the temp of the thermostat housing yourself.)
    If the thermostat stays open, then engine coolant temp will be below normal and the engine will operate less efficiently.
    I would also ask for engine ignition timing to be checked. Perhaps the timing is running retarded which will also cause inefficient operation.
    Have the iridium spark plugs been replaced yet? Have you already checked other items such as tire pressure, wheel alignment and parking brake drag?
  18. kammssss
    kammssss Member
    287
    86
    SoCal
    Hey, did your RPM go up significantly when you saw the red bars? I had a similar experience a few weeks ago. My SOC went from 60 to 35 on the ScanGauge. I've never seen it go below 40. I have a 2005 with 168,000 miles. Also, I have the Enginer plugin kit installed. I figure that was my problem. Weird things happen in the heat. I just disconnected it because it is too hot to use it right now, and everything seems to work normal. I just went to Vegas last week, and the SOC never went lower than 40, which is normal. Further, I've noticed that the RPM will increase significantly if the SOC is below 40 when the car is on the move. Peace.
