1. RobustMcManlyPants
    RobustMcManlyPants New Member
    Durham, NC
    First, a million thank you's to everyone who contributes to this forum. For the doubtless hundreds or thousands of us who lurk and learn, THANK YOU!
    I recently had to go to the tire shop down the street because of a nail-in-tire situation (a screw had somehow wound up at the edge and a patch couldn't be done). In the process of filling it enough to limp into the tire place I noticed that one side of the tire was basically bald (27K miles, same tires as it had when I bought it) and the same was true of the rear tire on that side. I asked them to check the others and all four were essentially bald on one half of the tread.
    The guy told me about the need for aftermarket shims to get the tires "really, truly aligned," as he put it, but quoted me $315 for the parts and labor. He acknowledged that labor is the vast majority of the price.
    When I brought my '08 in for the recall on the gas pedal today, the service manager at the dealership shrugged off the question of whether the shims are necessary and said, "We did an alignment at 15,000 miles and there are no shim kits for an '08 Prius, so you've done everything you can."
    I've read forum posts here on this topic and I know that there are aftermarket shim kits and the conventional wisdom is to get an alignment shop to do the installation and alignment rather than a tire shop but I'm not aware of any places in my area that only do alignment or that do alignment but do not sell tires.
    I'm mainly looking to take the temperature on how much the installation and alignment generally costs. I confess that I suspect this dealership likes to rip people off to some degree so of course I'm pretty much ignoring their happy-go-lucky reaction to my tires only lasting for half their expected life. I'd like to go with the shims the tire place recommended, especially since I replaced the OEM tires with 80K-mile tires in hopes of not having to worry about this again anytime soon and I'd like to get all the life out of them I can, but $315 for the shim installation and alignment at the tire shop sounds like something of a rip-off, too.
    Any recommendations?
  2. RobH
    RobH Senior Member
    2,372
    987
    70
    Sunnyvale, California
    I would get a standard alignment job, and find out just how far off the rear is. Toyota's solution to a out of spec rear alignment is to replace the rear axle. If the car is still in warranty, then let them do that. If it's out of warranty, then a shim job is clearly in order.
  3. Patrick Wong
    18,200
    6,491
    I do not think your car is still covered under the alignment warranty. I would expect a four-wheel alignment with shim installation to cost <=$150.
    Perhaps you'll have to check Charlotte and Raleigh to see if those cities have specialty alignment shops that would be more reasonably priced. Good luck.
  4. sktn77a
    sktn77a Member
    303
    NC
    Which dealer told you they wouldn't shim the rear axel? I know one dealer in your area that shims the rear for an alignment.
  5. CBarr31
    CBarr31 Active Member
    436
    225
    Charlotte, NC
    I am with sktn77a on this one. You should be able to find a Toyota Dealership in your area that will shim your car. I had to do mine early on when it was still under warranty so I don't know what it costs since it hasn't needed it again since.
    There are several dealerships here in the Charlotte area that will do it that I know of.
    Good luck and happy driving.
    CBarr31
  6. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    I bought a set of Falkens from Sears ( my third set now) cost: $300, had them also align for about $75. (as I remember) As far as I have absorbed from PC, the ONLY way to align was to use shims. I did not hang around and watch the mechanic, I should have. My local Sears shop is very generous in that respect. :rockon:
  7. turnbowm
    turnbowm Junior Member
    So. Calif.
    It's my understanding that the alignment warranty is only good for the first year. Is that correct?
  8. Patrick Wong
    18,200
    6,491
    I believe you are correct: 1 year or 20K miles whichever comes first. Check your maintenance and warranty manual to confirm.
  9. RobustMcManlyPants
    Durham, NC
    Fred Anderson Toyota in Raleigh told me that there were no shim kits and that they would not shim the car. Hrm. Now I think I need to make some other calls...
    Thanks!
  10. TFT
    TFT Junior Member
    Sarasota, Florida
    Shims are available. I just shimmed my rear axle last week. Here is the thread with pictures.
