Turn the heating on
Discussion in 'Gen 3 Prius Main Forum' started by Spenumatsa, Jul 15, 2010.
  1. Spenumatsa
    Spenumatsa Junior Member
    77
    Nashua, NH
    Excuse me if i sound dumb, but how do i turn the heating on my 2010 Prius.
    Apart from that i seem to having a little difficulty with defrosting my front windshield. The other day, the outside temp was around 78 and i turned the defrost on. It was taking a long time to defrost and at the end of the drive which lasted around 15 minutes, i could still see the frost on the bottom of my windshield like a patch. I am not sure if i am doing something wrong. I also read here on the forum's that it is advisable to keep the A/C in auto. Is that right. Any suggestions will be helpful.:)
  2. jrct9454
    jrct9454 Junior Member
    73
    Vancouver, WA
    My first suggestion is a thorough reading of the appropriate section of your owner's manual.
    The "auto" setting for the climate control works very well. To deviate from its settings, you need to read the manual and follow directions.
    When trying to defrost, or eliminate moisture from the inside glass, it is essential to have the AC compressor engaged - this is what is going to pull the moisture out of the air.
  3. skm009
    skm009 Member
    132
    Ohio
    Not really sure as I am a new owner myself.
    But my guess is that you could turn the heat up by hitting the temp up button.
    Also every time I use Auto for a/c the blower starts blowing up full speed, can this setting be changes somehow?
  4. qbee42
    3,081
    Set your climate control system to A/C Auto. Make sure the A/C compressor is enabled. To get heat, turn up the temperature setting. To get cooling, turn down the temperature setting. Press the defrost button if you need to clear the windshield.
    Just as a note, at 78°F you will not have frost on your windshield. It may fog up, but it certainly won't freeze into frost.
  5. Spenumatsa
    77
    Nashua, NH
    Tom,
    You are correct. I meant fog. But why would it still be there even after drive for 15 minutes? It was not on the entire windshield, but just as a patch? I will see if it happens the next time.
  6. qbee42
    3,081
    The defroster on the Prius is very effective. If you still have fog after a few seconds, I would suspect one of two things:
    1) The A/C compressor is disabled.
    or
    2) You have a dirty spot on the inside of the windshield that holds moisture.
  7. richard schumacher
    7,666
    1,047
    United States
    It's been relatively hot and humid there recently, true? so maybe condensation on the *outside* of the glass? Otherwise a coolant leak in the heater core is an ugly possibility; got any funny odors or weird fluids on the inside of the glass?
    There's no way to explicitly turn on the heater. You just have to set the temperature higher.
    And yes, closely read through the entire Owner's Manual.
  8. Flaninacupboard
    Flaninacupboard Senior Member
    1,297
    213
    Midlands - UK
    because you didn't allow the climate control to fuction properly (AC enabled). AC isn't just about cooling air, it's also about extracting moisture. hitting the "Demist" button without AC enabled will just keep blowing the same cold damp air at the screen.
  9. johalareewi
    johalareewi Member
    393
    44
    uk
    Hitting the demist button turns the AC button on (does on mine) and cranks the fan speed up to max. Works a treat.
  10. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    Above near-freezing temperatures, the A/C compressor is always forced on in defrost mode, as is fresh air intake.
    If you want to test heat, you can bump to max hot. Simply choosing a temperature allows the climate control system to determine how much heat vs. cool to deliver to reach the desired temperature.
  11. jburns
    jburns Senior Senior Member
    829
    111
    Archdale, NC
    This sounds like the most likely cause. If the window glass temperature drops to the dew point of the outside air, condensation will form on the outside of the glass. Its the same thing that causes moisture to form on the outside of a cold drink container in the summertime. The eastern US has been having dew points in the 70s the past few weeks so it doesn't take much cooled air blowing on the windshield to cause condensation.
  12. OldArmy94
    OldArmy94 Crazy Prius Man
    Arkansas
    In my parts, I turn on the heat by rolling down the windows. j/k
  13. energyandair
    energyandair Active Member
    905
    339
    Victoria BC Canada
    The fan and compressor are controlled to respond roughly in proportion to the deviation from temperature setpoint.
    If the temperature inside the car is just a little higher than the setpoint, the fan and compressor will only deliver a little cooling air and a little cooling. If, as is usually the case when you first turn a/c on, the temperature inside the car is high and the setpoint is normal, the difference is large so the fan and compressor will run as hard as they can to bring the temperature down quickly.
    If if the noise and draft bother you more than the heat, you can raise the temperature setpoint until the fan slows down. You can then progressively lower the temperature setpoint to your preverred setting as the car cools.
    Running in Eco mode will also limit compressor operation to save fuel. I'm not sure what effect it has on the fan.
