"Hybrid System Warning" light
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ozymandias, Jul 21, 2010.
  1. ozymandias
    ozymandias Junior Member
    83
    Virginia
    My wife just called and said this light came on. She said when it came on the car turned off its cruise control but kept running. Now she says it seems to be running fine but the light is coming on.
    The car has around 110k miles and I just replaced the spark plugs, air filter and engine oil about 1k miles ago. Any suggestions on what it could be? I'm going to have her pull codes at the auto parts store but she needs to do about 20-30 miles of driving today for work. Is it safe for her to do so?
  2. Patrick Wong
    18,200
    6,500
    Which light are we talking about: is this the red ! superimposed upon the outline of a car, appearing in the MFD? Are any other warning lights on?
    It's not safe for your wife to plan to drive 30 miles without knowing the root cause of the problem.
    The generic OBD-II code reader available at the auto parts store cannot be relied upon to retrieve DTC associated with the hybrid vehicle ECU or traction battery ECU.
  3. ozymandias
    83
    Virginia
    She said it's the red triangle and on the MFD there is an outline of a car with an exclamation point. I didn't ask her what color it was. She took the car to autozone and they weren't able to read any codes like you said, but now the light is gone. I found a shop nearby which says they can read hybrid codes for free so she is going to take the car there. I have a feeling it is either a sticking throttle body or the inverter coolant pump.
    Anyway, I'll keep this thread updated as things progress. It definitely lit a fire under my nice person to hurry up and replace the transmission fluid...I've been lazy about getting a 24mm socket.
  4. Patrick Wong
    18,200
    6,500
    Well, if the inverter coolant pump was the root cause, then as the inverter overheats, the DC/DC converter would allow the 12V bus voltage to sag. That would result in the brake, ABS, and VSC warning lights to come on.
    Since your wife did not report this, I do not think that is the problem.
    If the throttle plate was the problem, then I would expect the check engine light to come on, not the car with !. The latter warning is telling you something is wrong with the hybrid vehicle system.
    I recommend that you have your wife immediately drive to the nearest Toyota dealer so that the DTC can be read and she can rent a car to carry out her daily agenda. Good luck.
  5. ozymandias
    83
    Virginia
    Is the Toyota dealer the only place which can read the DTC (what does DTC stand for)?
  6. Patrick Wong
    18,200
    6,500
    The Toyota dealer is likely to be the only place that can reliably read the diagnostic trouble codes as well as the info subcodes that provide additional information about the problem. This is because a special diagnostic laptop is required to retrieve this information. Also, you'll want to know what the tech's diagnosis and estimated repair price is.
    An independent shop that specializes in Toyota may also have this test equipment available. It is unlikely that an independent which is a generalist will have this.
    If the Autozone staffer had cleared the DTC, then there's no point in taking the car to the Toyota dealer now. You'll have to wait until the warning lights reappear.
    When that happens, immediately take the car to the dealer without delay and ask the service writer to have a tech come out to retrieve the DTC before the car is turned off. Good luck.
    edthefox5 likes this.
  7. ozymandias
    83
    Virginia
    I don't think they cleared the codes. I was reading in another thread that if it is a temporary problem and it goes away the light will turn off after 3 starts but the code will be retained...I'm hoping that is what happened. She's at the independent shop right now, and if they don't find any codes then I guess we are going to have to wait for it to show up again. Is there any common thing which can cause this? My wife's work is such that if she sees this code come up she can't just stop what she's doing and run to the dealer.
  8. Patrick Wong
    18,200
    6,500
    If the master warning triangle and the hybrid vehicle warning icon are the only items that appear, then really, any number of hybrid system issues might be causing the problem, including:
    1) transaxle failure
    2) inverter failure
    3) traction battery failure
    4) hybrid vehicle ECU failure
    It appears that the problem is intermittent at least for now. Does your wife notice any driveability issues or unusual noises? Has the car's mpg declined?
    Dena2005 likes this.
  9. ozymandias
    83
    Virginia
    Hmm, ok. The shop said someone was using the equipment to read the DTC and she would have to go back in the morning...
    She hasn't noticed any driveability issues, and the mpg seems ok. The car is reporting the battery is 3/4 full. I'll take the car for a test drive when I get home, as she's pretty bad at noticing stuff like this.
  10. ozymandias
    83
    Virginia
    It's been months and I never saw the light again. I replaced the transmission fluid but I am not sure if that made a difference.
    However now I am reading about the coolant pump recall and I am thinking it might be our pump!
  11. Dena2005
    Dena2005 New Member
    Laguna Hills, California
    Hi Patrick Wong, some of your above questions are totally on point for my situation, so I am hoping that you can advise on what you were thinking in asking them. Recently, my 2005 Prius has been more sluggish and slower in accelerating. The car's mpg has declined from 40+ to 33ish. Today, I started my car to go to lunch and these warning lights came on:
    1) Red ! triangle (I think called Master Warning light) with the red ! superimposed upon the outline of a car, appearing in the MFD (I think called Hybrid System Warning Light) and the MFD says "Problem"
    2) Yellow ! indicator (I think called Brake System Warning Light)
    3) Check engine light
    A friend checked my 12 volt battery and it is fine. We noticed that the inverter coolant was low. Engine oil was a little overfilled (I won't be taking my car to the same oil change place again). I haven't driven the car since the lights came on because I was too worried to drive it and I am thinking of having it towed to a dealer. In your above post, you specifically mentioned a decline in mpg, so I was wondering where you were going with that? Would appreciate your thoughts! Thank you!
  12. fotomoto
    fotomoto Senior Member
    5,632
    3,809
    So. Texas
    I'm not Patrick but the next course of action is simple. You have trouble codes posted (the warning lights) so get them read. An auto parts can read some (but not necessarily all) of them for free while a Toyota dealer can read them all of course but usually for a diagnostic fee.
    If your 2005 is still on the original HV battery, it's most likely dying but the codes will tell us for sure.
    #12 fotomoto, Aug 12, 2016
  13. Patrick Wong
    18,200
    6,500
    Odometer reading?
    A mpg decline is indicative that the powertrain efficiency has been reduced. This typically results from an engine problem or a traction battery problem.
    As previously suggested, the diagnostic trouble codes (DTC) need to be retrieved. It appears that your car has at least one serious issue since the ! superimposed on a car outline warning icon has appeared in the upper left corner of the MFD. That points to a hybrid drivetrain problem.
  14. Dena2005
    Dena2005 New Member
    Thanks Fotomoto and Patrick Wong. I've attached the Vehicle Diagnostic Report from the dealer because I am not positive I am reading it correctly...Looks like several codes were pulled: P3000, P0A80, P3013, C1259, C1310, and B1421. Odometer reading is 145,000 miles. The dealer says that I do indeed need a new hybrid battery - says that block 3b is failing. :(
    Before taking my Prius into the dealer today, I checked the inverter coolant for waves and ruled out the inverter coolant pump as a possible suspect (there were waves in the coolant). I am still concerned about the low coolant level, but the dealer didn't seem concerned. The low level is about an inch below the low line. I'm planning to have an inverter coolant change done, but I read somewhere that the coolant should never be low unless there is a leak, so I'm concerned. Should I be concerned about the low level? I bought the car with 100,000 miles on it and so I doubt an inverter coolant change has ever been done. :-/
  15. JC91006
    JC91006 Senior Member
    16,761
    8,562
    I wouldn't worry about anything other than the battery. I would recommend you asking Toyota corporate for a goodwill warranty for the battery replacement. The service dept can do this for you
  16. Patrick Wong
    18,200
    6,500
    I agree that the traction battery needs to be replaced. It would not hurt for you to see whether Toyota might offer you financial help with the repair cost.
    Yes, the inverter coolant change should be done and the mechanic should look out for a leak in that system.
    I prefer Tustin Toyota (vs. Irvine Toyota) and also received excellent service from Rancho Santa Margarita Toyota when living in south OC.
  17. Dena2005
    Dena2005 New Member
    The refurbished battery comes with a 3 year/unlimited mileage warranty. I'm going to make sure to get that in writing!
  18. Dena2005
    Dena2005 New Member
    Toyota is chipping in a decent junk toward the repair cost, so I'm thankful for that. I'm proceeding with the inverter coolant change and praying that they don't find a leak. I'll keep Tustin Toyota and RSM Toyota in mind for the future. Thanks so much!
