Gen III Prius IV LCD display dark
Discussion in 'Gen 3 Prius Technical Discussion' started by sfmole, Jul 21, 2010.
  1. sfmole
    sfmole sf_mole
    San Francisco, CA
    The small LCD display (Int temp, fan speed, etc.) in my Prius IV with Nav Package is very dark, read "unreadable" when sunlight is prominent in the car. This is so even with the panel rheostat turned all the way up to bright. Is this a faulty display or is there any work around if not? Thanx. Craig
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Mine is fine but I believe there is a TSB out there for "cloudy displays". Call your dealer about it.
  3. dtuite
    dtuite Silverback
    182
    31
    Redwood City, CA
    LCDs are transflective and ought to maintain high contrast ratios across wide viewing angles and external lighting conditions. I'm with spiderman.
  4. chrisj428
    chrisj428 Active Member
    680
    144
    35
    Vernon Hills, IL
    Craig,
    Does it remain dark with your sunglasses off? (serious question)
  5. sfmole
    sfmole sf_mole
    San Francisco, CA
    Yes. I don't wear sunglasses. Probably should! ;o)
    I rented a Nissan Versa while traveling recently. It had
    a similar display and it was as bright as could be in all
    kinds of ambient lighting.
  6. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    I have the same problem on my Gen 3 II
    Edit: Found this thread
    http://priuschat.com/forums/gen-iii...5-cloudy-blurry-ac-screen-21.html#post1041196
    That TSB is old and doesn't cover recent production, but the problem sounds the same.
    Does anyone know if there is a later TSB?
  7. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    I was chuckling when I read the question regarding taking off one's sunglasses. I'm wearing polarized sunglasses and they do a helluva job in darkening the screen. I have to "rotate" the angle of my head and then the screen lightens up.
    I hope you find out what is wrong (if anything) with your screen.
  8. RRxing
    RRxing Senior Member
    2,561
    1,837
    NEPA
  9. chrisj428
    680
    144
    35
    Vernon Hills, IL
    ;) Exactly. I have the same problem.
