Stupid newbie mistake--how screwed am I??
Discussion in 'Newbie Forum' started by Psych_Prof, Jul 22, 2010.
  1. Psych_Prof
    Psych_Prof New Member
    53
    Southwestern Illinois
    I'm so, SO mad at myself!
    Okay, confession time: Tonight after work at about 6:30, I pulled my 2-week-old 2010 Prius into the garage, compulsively checked to be *sure* I had turned everything off (still getting used to the car), and left the garage. Then, I proceeded to go to band rehearsal in someone else's car, sure that my Prius was safely parked. When I got home approximately 4.5 HOURS LATER, I opened the garage door, and what should I see but a LIGHT ON inside my Prius. Specifically, it was one or both (I spazzed out and cannot remember now) of the push-on overhead lights on the ceiling. !!!
    All I can figure is that, because it was daylight when I left, and because the lights inside the car stay on for a few seconds anyway upon exiting, I somehow didn't see it, despite compulsively checking for things.
    Now, the real coincidence is that, just last night, I was reading some of your scary 12-volt battery stories on this forum. I CANNOT BELIEVE that I made this mistake, and now I'm super anxious and paranoid. My guess is that I probably just drained my battery, and it's only a matter of days (weeks?) before I walk out to a dead car.
    I realize that every situation is different, and that no one has a crystal ball. I also realize that battery life is determined by many factors. However, almost all of you here have more experience with this than I do. How screwed am I???
    My Questions:
    -- How long would you *guess* that I have now before I'm stranded with a dead 12-volt? (another way to ask the question: how much power do these overhead lights draw?)
    -- From what I've read here, I didn't hurt the traction battery. Is this true?
    Other pertinent information: When I got into the car, it started up just fine with no delays, and everything seemed to be responding as normal. I drove around for about an hour in the hopes that this would do some small bit of good, although, from what I read here last night, once a battery has once been run down, recharging it (by driving) doesn't really help all that much, and the damage has been done.
    I'd really, really appreciate any light anyone can shed on this--preferably a few different opinions/comments. :( :(
  2. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
    Are you freaking serious? You're crying over leaving the dome light on for 4.5 hours? I hope you're joking because this is gotta be the st......... never-mind. Dome lights draw about .5 to 5 watts per bulb. On a healthy battery, it would take at least a couple of days to drain the power. I recently replaced my dome lights in my Tacoma to couple of 15watt high power LED dome lights. I left the lights on for 2 days and my Tacoma started right up. The Tacoma needs 200+ amps to start the engine where as the Prius only needs about 20-30 amps to boot. Those people with dead prius batteries were letting their cars sit for weeks sometimes months in parking lots. It doesnt take that much to jump start a prius. You could do it with a drill gun battery.
    A regular car battery can't be deep cycled. If they are cycled they can only be charged back to 70-80% of its original capacity. Since original capacity is 200-400% of what a starter needs to start a car, after it's been cycled and charged back up, the engine starts up like a brand new battery even though it lost 20-30% of its original capacity. My parent's 98 Sienna's original Toyota battery had been deep cycled at least 10 times in its life. It lasted 7 years before it couldn't recover enough to hold a charge.
    If it makes you feel any better, read this... Prius Startup Current about Gen II 12V battery and some info on the HV battery. Gen III should work the same.
  3. wmcbrine
    wmcbrine Junior Member
    56
    Laurel, MD
    I would just add that you may not even have left the light on. If left in "Door" mode, the interior lights come on automatically when you approach the car while carrying an SKS key, in anticipation of you getting in. Neat, huh? But the first time I saw it, I thought I'd left the light on, too.
    2 people like this.
  4. MJFrog
    MJFrog Active Member
    780
    267
    NE Oklahoma
    2018 Nissan LEAF
    Since it started back up you probably dodged the worst of it. Battery capacity is most likely reduced but not critically...yet. Just keep an eye on it and try not to do it again.
    Once the car is successfully started, all 12v power comes from the inverter...it's just the power-up sequence that depends on good current from the 12v battery. THAT can cause wackiness!
  5. Airbalancer
    Airbalancer Active Member
    892
    73
    Cobourg, On, Canada
    I killed the battery on my truck once, call the auto club for a boost been running for 3 years no problem
    people have to chill out more
  6. PriusG3IV
    PriusG3IV New Member
    37
    Kentucky
    I'm in accord with WMCBRINE's opinion that you may not have left the interior lights on at all.
    That being said, "IF" you clicked the map light switche(s) thinking that you HAD left them on (but really had not) then you may have turned them on when you thought you were turning them off.
    You might check it this way:
    a. Turn off your car
    b. Lock your car.
    c. Close the garage door (so it gets card inside of your garage) and go inside the house (this is important so you get far enough away from your car that the SKS doesn't "sense" that the key is near by and turn on the "welcome lights").
    d. Wait long enough for the interior lights to auto dim --> and turn off (about 60 seconds).
    e. Now, open the house door to the garage and look at the car. Are the interior lights on? No? you're OK. If "Yes", then appraoch the car, unlock it and turn off the map light (or whichever light is illuminated).....and repeat from step "a" until there are no lights on inside of the car when it is locked and the SKS is not near the car.
    --> Alternately, you can leave the car unlocked, but leave the key INSIDE THE HOUSE (or just far enough away that the car doesn't sense the SKS) and then go out and see which lights are still illuminated. if there are none, you're good to go!
  7. Psych_Prof
    53
    Thanks to everyone so far for the responses.
    To PriusG3IV & wmcbrine -- Good point, but unfortunately, I'm pretty sure I left the light on. I know about the lights coming on upon approaching the car with the SKS, and although this usually happens when I approach the driver's side, it doesn't when I approach the passenger's side. Last night, I walked around the passenger's side first and saw it. Also, when I got in the car and shut the door, I left it alone for a minute, hoping that I'd see it auto dim and all would be good. IIRC, just one of the lights dimmed, which leads me to think that I had left the other one on. I then physically pushed it to turn it off. But again, I was admittedly freaking out at the time, and all of this isn't crystal clear to me now.
    MJFrog -- You said "Battery capacity is most likely reduced but not critically...yet." This is what I was afraid of. Would you recommend taking it to the dealer to get it tested? (I'll admit I'm not the best DIY-er, and that being the case, I don't want to cost myself thousands by screwing up the battery by doing something to it myself!) Do you think I helped recharge it at all by driving it immediately?
  8. qbee42
    3,082
    You should be fine. In the worst case scenario you shaved a few weeks off the life of the 12V battery. It's no big deal.
  9. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    As long as you were able to start it, and drove it awhile to charge that bad boy back up, you are probably good.
  10. ksstathead
    ksstathead Active Member
    1,244
    245
    Kansas
    1) You don't have to drive it to charge it. Just need to put in ready mode and let it sit. The HV will slowly charge the 12V without going anywhere. When the HV gets low, the ICE will start long enough to recharge the HV. Open the garage door so the engine gets air and you don't get CO.
    2) Always lock the car with the door handle. It will fail and beep if you've left anything on.
  11. Psych_Prof
    53
    Okay, I'm feeling much better after reading all your replies. I can sometimes let my anxiety get the better of me! No, it wasn't a smart thing to do, but maybe it wasn't that big a deal. Lesson learned: be more careful in the future!
    Thanks again to everyone who responded. =)
  12. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    My research tells me that there is no tangible reason to believe you have done any long term damage to anything but your own personal psyche...relax.
    But when things like this happen, it could be a message from the universe. I'd trade your Prius in immediately before something else happens. You're obviously living in fear and that's not harmony between man and machine...
    Really, think it through, while inconvient what was the worst that could happen? Worst case the 12V is drained to the point of unredemable failure (astronomically unlikely given circumstance) and you'd have to purchase a new battery or keep your mouth shut and pretend you have no idea why it failed and see if Toyota would cover it, in either case you'd emerge in good shape.
  13. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    a decent lead acid battery should be able to withstand 10-50 significant discharges with only a minor change in its life. for what you did, you should still have had significantly more than 50% of your capacity left. its only when lead acid hits 65% or 35 % discharge that anything at all happens. (that figure has been debated)
    now, with all that in mind. remember any battery has a finite life. proper charge management will help you get most of that life out, but no matter what you do, you have used up a part of your battery's total charge. but as others have stated, you did no real harm
  14. Mark57
    2,945
    2,740
    OK
    Dude, decaf. This is the newbie forum. It's exactly meant for these kinds of questions. Hybrid vehicles with two different types of batteries can be unsettling for many people until they get used to what does what.
