Protective door mouldings?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by phoenixgreg, Apr 7, 2010.
  1. phoenixgreg
    phoenixgreg Senior member
    1,157
    295
    66
    Phoenix
    Wow, that's a wide molding! Thanks for the PDF. Mine have been holding up just fine as they've been installed now for several months. Picking a height is tricky as no molding will completely protect your Prius from every conceivable door. Higher up could work better against SUVs and trucks. Lower down is better against a standard car. Mine are up high and so far, no dings (yet!).
  2. Scaurex
    Scaurex Junior Member
    46
    Vancouver, BC
    2025 Prius Plug-in
    XSE Premium
    Here is the wide, tapered one installed. Only blackberry pics, so they aren't the best...
    robing25 and danvee like this.
  3. danvee
    danvee Blizzard Brigadier
    326
    53
    New Jersey
    That looks great!
    The tapered mouldings (and the way they're mounted) really fit with the lines of the car.
    I've got to start saving my pennies again....;)
  4. Scaurex
    46
    Vancouver, BC
    2025 Prius Plug-in
    XSE Premium
    Here are some better pics of the tapered moulding installed...
    I do like the way they follow the rake of the top crease on the door. The other moulding that looked like it went almost straight across, even though the front was 2" lower than the back.
  5. jimmyjam
    jimmyjam WE KNOW ITS A PRIUS BECAUSE OF THE WAY THAT IT IS.
    181
    Iowa....a place to snow
    Where did you get these? are they all white. or white with silver inlay?they look great!
  6. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    While I'm not a fan of moldings, yours is the nicest one I've seen.
  7. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Same here. I'm no molding fan but those look like they belong.
  8. txl146
    txl146 Member
    301
    NY
    Thanks for the instruction. I just ordered a set!
  9. 453126437
    453126437 New Member
    1.IMO,You should search relative information on internet
    2.[FONT=&quot]Some big car forums recommended this company
    3.Directly find dealers
    [/FONT]
  10. txl146
    txl146 Member
    301
    NY
    Just installed a set of side molding purchased from eBay for $85 shipped:
    Think these look a lot better than plain boring side moldings. ;)
  11. cmrj
    cmrj Junior Member
    34
    Boise, Idaho
    I just bought a set of these last week from Sparks Toyota for our silver Prius. The instructions utilize a magnetic straightedge to install them. Did you just use painter's tape to mark the line?
  12. txl146
    txl146 Member
    301
    NY
    yes, I just used making tape. Took me 15 min to install them.
  13. robing25
    robing25 New Member
    I am so shocked but these side moldings look great. Like they were meant to be there. Now I feel like my doors are naked. Can't believe you can put them on yourself. How do they hold up with car washes and wear and tear? Thanks for the great pics. I'm a new Prius owner and happy to finally own one. :)
  14. JayLn
    JayLn Active Member
    248
    141
    Four Touring
    Where did you buy this?
  15. Nobody123
    Nobody123 Member
    160
    33
    United States
    2015 Prius Plug-in
    They're discontinued and no longer available from Toyota.
