New Prius-questions???
Discussion in 'Gen 3 Prius Audio and Electronics' started by paulh, Aug 14, 2010.
  1. paulh
    paulh Junior Member
    55
    evansville,indiana
    Just picked up our new Prius last night. I've got the navigation package. Two things I could not get done. I couldn't get the garage door opener programmed. It kept flashing slow but the speed never picked up. I also couldn't get my Samsung Impression to download my contacts and phone numbers. What should I try???
  2. teeasal
    teeasal New Member
    420
    ON, Canada
    This had been discussed somewhere in the Forum already. Please search the Forum or Google for answers. I did found the solution by searching and was able to set the Homelink garage door opener. Note that even after successfully set it up, you still have to press on the button for a second or 2 to make it work.
  3. Paul58
    Paul58 Mileage Miser
    1,126
    125
    Atlanta
    There are also How-To videos on YouTube:
    [ame="http://www.youtube.com/watch?v=y-xAHczNfog"]Homelink[/ame]
  4. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    The instructions in the owner's manual worked for me--you have to follow them exactly. If you have a rolling code opener (I believe all garage door openers made in the last 10+ years are), you need to press the button on the opener unit in the garage at the appropriate time. Also, I've found with various cars that you need to keep the remote very close to the mirror during the process, and if the remote battery is weak it could cause issues.
    Also--opener manufacturer specific instructions are on HomeLink
  5. paulh
    paulh Junior Member
    55
    evansville,indiana
    Guys, thanks for the response. Found the answer about the phone. The phone doesn't allow for multiple transfers of contacts. Bummer!!!!
  6. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Can't answer any of your questions but wanted to say Welcome!
  7. paulh
    paulh Junior Member
    55
    evansville,indiana
    Thanks,I find the car and all the manuals a little intimidating but awesome. This is our first Toyota. Had a Honda Accord for 19 years. Found the fix to my garage door problem. Had to go on the homelink site and find the manufacturer of the opener . Their procedure is a little different then the Toyota manuals but it worked. Love this website and the information available.
  8. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    While it is about the 2004 to 2009 Prius, this manual gives sage advice without reading like it was translated from Japanese.
    John's Stuff - Toyota Prius User-Guide
