Prius 2010 only, tire pressure
Discussion in 'Gen 3 Prius Fuel Economy' started by bwilson4web, Dec 19, 2009.
Prius 2010 only, tire pressure poll
Poll closed Dec 31, 2009.
  1. < 30 psi, 207 kpa
    0 vote(s)
    0.0%
  2. 30-32 psi, 207-221 kpa
    0 vote(s)
    0.0%
  3. 32-34 psi, 221-234 kpa
    4.0%
  4. 34-36 psi, 234-248 kpa
    10.0%
  5. 36-38 psi, 248-262 kpa
    12.0%
  6. 38-40 psi, 262-276 kpa
    22.0%
  7. 40-42 psi, 276-290 kpa
    36.0%
  8. 42-44 psi, 290-303 kpa
    8.0%
  9. 44-46 psi, 303-317 kpa
    4.0%
  10. 46-48 psi, 317-331 kpa
    4.0%
  11. > 48 psi, 331 kpa
    0 vote(s)
    0.0%
  1. bwilson4web
    16,204
    Please, this poll is for 2010 Prius owners. If there is something remarkable about your tires that would make the pressure range different (aka., snow tires, after-market) feel free to share but do include your target pressure.
    Note, the usual practice is to check the tire pressure every two months and in times of cooling temperatures, a little more frequently. Comments about 'what I found' versus 'what I expected' are always welcome.
    A short poll, it should be over December 31, 2009.
  2. kgall
    kgall Active Member
    984
    152
    Olympic Peninsula, WA
    Bob,
    Are all the tires for the Prius 44-45 psi max? If not, would there be a way to indicate in the poll a different maximum air pressure recommendation from manufacturer?
  3. Tideland Prius
    16,555
    40/38 for the stock tyres. My winters are actually running on 42/40 b/c of the higher max sidewall pressure.
  4. bwilson4web
    16,204
    This evening I found my tires at 40 psi. They are back up to 44-45 psi. The last time I checked them was about 2-3 months ago when I had the oil changed ... the standard Toyota tire pressures were found afterwards.
  5. Erikon
    Erikon Active Member
    819
    105
    Rochester, NY
    42-40 on my stock tires seems to give me good ride quality and I assume some MPG benefits.
  6. bwilson4web
    16,204
    I couldn't figure out a good way. For example, our 2003 Prius runs Sumitomo T4s that have a 51 psi maximum sidewall pressure. But other folks use different brands with lower sidewall pressures. The only way that makes sense is to ask folks to report their tire pressures actual and maximum ... ugly. The other is some sort of relative pressure to maximum sidewall, "max sidewall -4 psi" or "max sidewall +2 psi". Then we lose the absolute values.
    I may come up with an approach but right now, it looked to be too confusing.
  7. kgall
    kgall Active Member
    984
    152
    Yeah, it's ugly to ask for actual and max sidewall pressures, but it gets the numbers you want.
    Am I right that all the original equipment tires are 44 psi max? Then you would only need to ask for max pressures for winter or other aftermarket tires.
  8. bwilson4web
    16,204
    That is my understanding.
  9. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    According to our tire poll http://priuschat.com/forums/gen-iii...61926-what-tires-did-you-get-your-2010-a.html The PriusV (215/45-17) has come equipped with three different tires:
    Bridgestone Turanza EL400 max pressure 51 psi
    Michelin HX MXM4 max pressure 44 psi
    Toyo Proxis A20 max pressure 51 psi
    Information on pressures for Michelin and Bridgestone from the TireRack web site. For the Toyo's from the tires on my car.
    I use 48 lbs in my Toyo's; if I had the 44 psi tires I would use 42 lbs.
  10. ksstathead
    ksstathead Active Member
    1,244
    245
    Kansas
    My Bridgestones are the Ecopia EP20 at 44 psi max (running at 40/38 for now).
  11. 2010priusowner
    2010priusowner New Member
    37
    FL
    42 to the front and 40 PSI to the rear is that the way wr do it here for best fuel economy?
  12. fjpod
    fjpod Member
    419
    72
    New York
    Is there any correlation between high tire pressure and the existence of the easily activated anti-lock brake issue?
  13. Downrange
    Downrange Active Member
    372
    212
    2024 Prius Prime
    SE
    Just a comment - I've found my tire pressures tend to "naturally" go down by about a pound per week. I've taken to checking them at least once a month, and they are usually down 3-4 lbs/tire. When I let them get down that much, I can see the gas mileage hit clearly - about 2-3 MPG per tank.
    Make mental note to self - check tire pressures every couple of weeks!
    Tires seem to last longer at 40 PSI, as well, from what I've seen anecdotally.
  14. ursle
    ursle Gas miser
    1,049
    192
    NH
    Nitrogen...
  15. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    I'm using a 78% nitrogen, 20% oxygen 2% misc mix.
    If the claims about air leaking out faster than nitrogen are true, I will soon have nearly pure nitrogen in my tires.
  16. Downrange
    372
    212
    2024 Prius Prime
    SE
    Ha ha - nitrogen. Good one!
    Just keep 'em inflated.
    LOL, gotta love the snake oil salesmen!
  17. Judgeless
    Judgeless Senior Member
    1,821
    257
    Cleveland, OH
    Great stats for someone trying to figure out the best tire presure vs MPG's on a Gen III
