Hybrid battery connection not very protected.
Discussion in 'Gen 2 Prius Technical Discussion' started by PJM, Aug 25, 2010.
  1. PJM
    PJM New Member
    This past weekend my car lit up like a xmas tree and died. It's a 2005 Toyota Prius. Techs at Toyota Service had no clue what had happened until they got into the hybrid battery connection site. Over a year ago a bottle of laundry detergent had leaked on the area behind the driver side, the seat was down for hauling. I cleaned the carpet and the fleece lined blanket that covers the back. Had no clue that the soap had run down through a hole and right onto the hybrid connection. The residue was dried but it had caused havoc with the hybrid system. The techs thought it had fried the hybrid battery and the computer system. Turns out it had fried the water pump to the hybrid system and fuses, among other things. This is something that would have been nice for me to know, that the hybrid battery is so vulnerable, not a secure cover to protect this key part of the car. A small amount of liquid, laundry soap in this case, caused a major repair. The techs had never seen or heard of something like this. Wanted to share this info.
  2. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    It may not be related. We are seeing reports of the inverter pump failures. I fail to see the connection with that pump behind front bumper and the detergent leak in the trunk.
  3. JimboK
    JimboK One owner, low mileage
    2,817
    189
    49
    Chesterfield, VA
    Yes, I agree. There is no water pump in the vicinity of the battery.
  4. hybriddriveguy
    98
    63
    Sanford NC
    This is something that would have been nice for me to know, that the hybrid battery is so vulnerable, not a secure cover to protect this key part of the car. A small amount of liquid, laundry soap in this case, caused a major repair. The techs had never seen or heard of something like this. Wanted to share this info.[/QUOTE]
    The pump is not related. Also, on a 05, it would be very unusual for a small amount of soap to get on any HV connections. They are very well covered.
  5. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    Was there any corrosion of the HV battery connections? Would be nice to see some pictures. As others have already pointed out the pump is under the hood, not in the trunk.
  6. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Charging and discharging any battery produces heat. (Ask laptop owners) It would not be easy to build a water proof container that allowed that much heat to dissipate easily. The battery is protected in the 'have a wreck" sense, but it is not 'sealed' nor can it be.
  7. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    If you should remove all the casing plates surrounding the HV battery, you will see it is nicely packaged. No, it is not water proof. AND it does not take much liquid to get to the pefect two points, causing either a partial grounding condition or a high resistance short circuit. The best place to carry any liquid is on the floor. The car is not to blame!
