Another Strut Tower Brace Option
Discussion in 'Gen 2 Prius Accessories & Modifications' started by mrbigh, Apr 5, 2009.
  1. mrbigh
    3,686
    699
    Long Island, NY
    This was my solution and with no "clearance" problems. I used a Corolla aftermarket brace.
    I made my Strut towers installation almost 6 months prior Brian's BT tech, offering his innovative product for sale.
    SFO and Frayadjacent like this.
  2. boppo
    boppo Active Member
    799
    139
    Owego, NY
    Re: BT Tech Strut Tower Brace install pictures and Text
    SWEET, where did you get it and what was the cost? Nice pics and I like this option better, looks like when you put the plastic back on it's all most invisible.
  3. CBarr31
    CBarr31 Active Member
    436
    225
    Charlotte, NC
    Mrbigh,
    It looks like that is a Megan Racing Front Upper Strut Tower Brace #MR-SB-TC001 for Corolla Model years 03-08 ... is that correct?
    If so that brace can be purchased for about $70 plus shipping at a few different websites it looks like. Another added bonus is that it can be ordered in blue, red, black or silver. Of course that is somewhat meaningless since as it was pointed out earlier it will be completely hidden.
    Did you have to make any modifications to the brace/car or did you just install it "right out of the box" as is? If that was the case this might be the way for me to go.
    Thanks for all the help.
    Chris
  4. boppo
    boppo Active Member
    799
    139
    Owego, NY
    It look like the wiper assembly was removed, I wonder it that was a big job.
    Thanks,
  5. CBarr31
    436
    225
    Charlotte, NC
    Boppo,
    There is a GREAT "How to" at the beginning of the post from Gadgetdad (Lee) on how to install the BT Tower Strut Brace. Thanks Again Lee!!!! The procedure would be the same for this brace.
    Boo also converted these instructions to a Microsoft Word format and posted it in Post #32 (for me) which you can download and print. Thanks to you too Boo!!!!
    PriusChat ROCKS!!!! :D:D:D
    Thanks again,
    Chris
  6. boppo
    boppo Active Member
    799
    139
    Owego, NY
    Thanks for the info.
  7. boppo
    boppo Active Member
    799
    139
    Owego, NY
    How do you like the way it handles now that you have installed it?
    Thanks
  8. FireEngineer
    FireEngineer Active Member
    1,247
    124
    SW-Side of Chicago, IL
    Well my friend, what is the info on this and how was the fit?
    Wayne
  9. stellaf
    stellaf New Member
    24
    new york
    2001 Prius
    It is such a nice stuff and I really like it. Thank you so much for sharing.
    Stella
  10. mrbigh
    3,686
    699
    Long Island, NY
    "This post was transfered from another thread as general information."
    First let me tell you that I Installed this brace almost 3 years ago, so some details I do not have but I''m rolling the information I can remember.
    The bar was purchased through an eBay dealer for about 55.00 and in deed, there were some color selections on the finish, I choose blue. Today days may be other options but my selection was a "Flat T6 Al Brace, more rigid and less vibration that a cylindrical tube.
    CBarr31 is right, that's the merchandise information.
    The 2 tower brackets: These are the most important pieces and everything plays with physical clearance with the cowl, I had install these inverted, with the adjusting bolt facing down , and shimmed the brackets with SS washers in the towers bolts, the brackets do not have to be flat on the bubble, mine are installed with an inclination toward the engine, like an slightly slant.
    These brackets should be securely fasten with the original strut tower bolts, take a look at the pictures for guidance.
    Then you install and fasten the connecting rod, making sure that you do not push of pull the strut towers out of their original alignment.
    Re-install the cowl, the wipers assembly, the wiring harness, the plastic grill and then the wiper arms.
    Having all materials on hand ( the proper size washers), will not take you more than 1 hour from start to finish.
    2 people like this.
  11. Frayadjacent
    Frayadjacent Resident Conservative
    375
    Austin, TX
    Interesting. A quick search of Ebay finds several cheap brand Corolla braces, and a few Greddy braces.
  12. djhnd
    djhnd Junior Member
    San Anselmo, CA
  13. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
  14. Ray66
    Ray66 New Member
    153
    Miami, FLORIDA
    I got this one a few days ago ... Tanabe USA Inc. - Sustec Tower Bar
    My 06 seems to be more stable at high speeds. I also installed the G7 under stiff plate off of ebay--a China man from Riverside County makes these plates ... Both fit perfect and I feel more secure on LA's crazy freeways. My new 205/60/15 Mich Pilot Exalto feel good too...
  15. Ray66
    Ray66 New Member
    153
    Miami, FLORIDA
  16. Robertzerosmog
    Robertzerosmog New Member
    Los Angeles
    Love the blue anodizing and the red @Ray66. It actually looks like a stock part. I never thought to add one to my Prius. I've added one to practically every other car I've owned and it does firm up the handling. Probably had the greatest impact on an 85 Mustang GT I used to own. That car had a pretty wobbly body.
  17. pEEf
    pEEf Engineer - EV nut
    720
    580
    Berkeley, CA
    I tried a JDM Corolla brace. The brackets look identical to the above, but this one is a steel tube instead of an aluminum bar. There is no way I can make the cowl drain pan fit back in unless I were to cut it up. (which I'm not going to do)
    The cowl wont fit even with just the brackets installed, no matter how much I tilt them.
    Beware!
  18. mrbigh
    3,686
    699
    Long Island, NY
    Probably you should try this approach with similar product. Mine is 5 years old already.
  19. patsparks
    10,664
    569
    Adelaide South Australia
    Where is that brace from?
  20. mrbigh
    3,686
    699
    Long Island, NY
    Hi Pat,
    truthfully I do not remember the dealer I purchased from but it's a Corolla 2005 after market accessory. At those days, was an eBay bargain.
