2007 Prius e-Brochure available?
Discussion in 'Gen 2 Prius Main Forum' started by Azipod, Sep 1, 2010.
  1. Azipod
    Azipod Member
    139
    NorCal
    I'm a new owner of a 2007 Prius.
    I would like to get an electronic PDF version of the brochure for the 07 model. Unfortunately, the only thing I found from certifiedtoyota is their reprint for the 2007 Prius, but not actually a copy of the actual 2007 brochure in electronic format.
    Does anyone know if there's any where on the web that I can find the actual brochure they handed out in 2007? I googled quite a bit but found something for Cananda, but not for the US models.
    I thought it would be cool to look at what they had going in 2007. Please let me know if there's something out there.
    Thanks!
  2. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Moved to the Gen II main forum...
  3. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    1. If you want the 2007 Prius eBrochure on PDF, then download it from Certified Toyota.
    2. If you want the 2007 Prius print brochure, then you can see it at a website called ToyotaReference.com which was started by PriusChat member named toyotareference:
    Toyota Reference: Paint Codes, Information and Specs for Toyota, Lexus and Scion
    If you want the 2007 Prius print brochure on PDF, then maybe you should send an email to toyotareference, and ask him whether he would be willing to email it to you. Here's the PriusChat Profile of toyotareference which has his email address:
    PriusChat Forums - View Profile: toyotareference
    Edited by Tideland Prius on June 2017:
    Toyota Reference website has moved to ImportArchive. See below
    ImportArchive / Toyota Model Lineup
    #3 Boo, Sep 2, 2010
