1. priuscritter
    priuscritter I am the Stig.
    1,525
    199
    Indiana
    So after driving a few blocks i hear a tick-tick-tick sound. pull over and take a look and it's a bolt in the tread of the tire. naturally, on saturday of a holiday weekend. prius is grounded until tuesday unless i find a tire shop open tomorrow.
    my question is, does the tire pressure monitor need any special treatment if i have to replace the tire? i haven't dealt with this before since i've never had to have a tire fixed on a vehicle with the tpms. the tire may be repairable, but i can't see for sure how wide the bolt is because it's pushed all the way in and i can only see the bolt head. car is three weeks old; not a happy camper here.
  2. qbee42
    3,079
    Tell the repair shop that you have TPMS. They should know, but it doesn't hurt to mention it. TPMS doesn't take any special handling, except to make sure and not break the sensor.
  3. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Make sure the shop has experience dealing with alloy wheels too. The can be damaged fairly easily (bead).
  4. priuscritter
    1,525
    199
    Indiana
    thanks guys. i have a feeling i can't get this fixed until tuesday because of the holiday. gonna look for a place open but i doubt i find it.
  5. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    TPMS is standard (by law) on every new car, and has been for some time, so any tire shop should have experience with it.
    If they determine the tire is repairable, be sure to have it repaired with a patch/plug (applied to the interior of the tire), and not just a plug (inserted from the outside).
    I'd check the tire pressure (vs. the B-pillar sticker values) after the tires cool down, since my experience is they don't always get it right. And then reset your TPMS system (instructions in owners manual).
  6. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
    So they would repair an unrepairable tire?
  7. priuscritter
    1,525
    199
    Indiana
    No they wouldn't. Nobody said they would repair an unrepairable tire.
  8. Airbalancer
    Airbalancer Active Member
    892
    73
    Cobourg, On, Canada
    You probably pick up a screw and not a bolt
    Bolts have flat end, screws have pointed ends :D
  9. RRxing
    RRxing Senior Member
    2,539
    1,813
    NEPA
    Many, many years ago I "picked up" a freakin' tire iron. :eek:
    When I took the wheel off I used the socket end as a convenient carrying handle...:D
  10. Airbalancer
    892
    73
    Cobourg, On, Canada
    I thought you use the tire iron to hit the next person who ask you where the plug is:p
  11. stream
    2,977
    452
    Long Island, NY
    Nothing like a self-answering question.
  12. priuscritter
    1,525
    199
    Indiana
    here's a picture of the beast in my tire....lol. may not be a bolt but it's hard to tell.
  13. stream
    2,977
    452
    Long Island, NY
    Looks like a roofing nail to me--should be repairable.
  14. Joe166
    Joe166 New Member
    720
    97
    South Florida
    I have to think you could have repaired, replaced, improved or done anything you could imagine to that tire with half the effort you have spent posting and taking pictures.
  15. priuscritter
    1,525
    199
    Indiana
    hey joe, keep the hate out of my thread ok? if you don't like the thread, then simply go elsewhere. not sure why that's an issue for you. just so you know, my tire shop closed at noon on Saturday, and was closed sunday and monday, so i've had a little time to post. if this would have happened friday, i would have had it fixed by now. this is small town indiana here, and we're somewhat limited on services during holidays, so you thought wrong. i didn't really think it was safe to drive to a bigger town, nor did i have the time due to job responsibilities out of town.
    but if you would have actually read the original post, my question was about tpms sensors since i've not had to have a tire repair on a car with that system.
  16. priuscritter
    1,525
    199
    Indiana
    tire is fixed! it was a screw, about a half inch or so. it looked like the kind of screw that comes with the build-it-yourself furniture. easy patch job, should be good now.
