Passenger Side Window Wont Go Up
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by chancedubuque, Sep 7, 2010.
  1. chancedubuque
    chancedubuque New Member
    US
    Hey, so i'm trying to take a roadtrip in my parents Prius tomorrow, but when I got in it tonight to take it for a test drive the passenger side window refuses to go up.
    All other windows work just fine. There is also a small light illuminated on the dash that looks like (!)
    Anyone have any idea what the issue could be?
  2. qbee42
    3,081
    The (!) is the TPMS giving a tire pressure warning. It should be unrelated to the window.
  3. chancedubuque
    US
    Thanks for the info.
  4. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    Not sure if this is your issue, but on my previous car I had a similar issue, and it was related to the anti-trap feature. I had to reinitialize it. On that car, you pressed and held the window button until it went fully up, then held an additional 5 secs; and then repeated the process downward.
  5. Joe166
    Joe166 New Member
    720
    97
    South Florida
    Sounds tough to do if the window won't go up at all.
  6. Airbalancer
    Airbalancer Active Member
    892
    73
    Cobourg, On, Canada
    Are you sure you are not driving a GM pick up
    I have tape on my window since it about 1/4 in openned and the motor is dead :p
  7. donalmilligan089
    239
    22
    virginia usa
    There is a window lock button on the passenger sida that may have gotten bumped
  8. phoenixgreg
    phoenixgreg Senior member
    1,157
    295
    66
    Phoenix
    Check fuse #15 above the driver's foot well. It should be a 25 amp that protects the circuit of the passenger's front window. If blown, find out what caused it as replacing it may not solve the issue. Do your parents recall the circumstance of the failure?
  9. DumbMike
    DumbMike Active Member
    560
    119
    Los Angeles
    Do everybody else's remedies first (I think it's the fuse). If they don't work, it could be that the motor is dead or about to go dead (just one of those things). Try this: Locate about where the motor for the window would be. With the window button pressed in the direction you want the widow to go (in this situation, up), bang on the inside of the door with your fist about where the motor would be located. Do this as hard as you can but not so hard that you will cause any damage to the car door or your fist. If you had an old car, I'd tell you to use a rubber mallet or even take the door lining off. The reason not to use a mallet on a new car is because people get carried way. Sometimes the motor freezes and this can get it unstuck. But it's a last-ditch thing to try, and generally, only use it in case you really have to. Somebody mentioned resetting some setting. If you temporarily have to get the window to go in a certain direction, this might be an alternative. Otherwise, you'll have to take it into the shop.
    Dumb Mike
  10. Colonel Ronson
    Colonel Ronson New Member
    443
    33
    Tucson, AZ
    This might be a dumb suggestion but did you turn off the lock on the drivers side?? I accidentally forgot to disable the window lock and spent 25 minutes befuddled.
