Ugly scrapes on . . . Rubber?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by kgall, Sep 11, 2010.
  1. kgall
    kgall Active Member
    984
    152
    Olympic Peninsula, WA
    Thanks to everyone who answered my queries about
    [​IMG] Touch up paint? a week or two ago.
    Now I've noticed some worse scrapes at the bottom sides of the front panel (where the bumper would appear on most cars). They are a few inches long, up to about half an inch wide, and black (my car is silver). The underlying substance feels like rubber or plastic--the dealer says rubber.
    The dealer had three ideas--have the guy who does the touch ups on their used cars do it, probably for under a hundred bucks, get a body shop involved for much more, or do it myself.
    When I asked if I should sand the thing, he suggested that would make it worse--I should just paint over, even though it feels a bit rough.
    Any suggestions, gang?
  2. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    Pix would help.
  3. danvee
    danvee Blizzard Brigadier
    326
    53
    New Jersey
    It's most likely a kind of Polyurethane. If the dealer can have his touchup guy do it for about $100, I'd check out his work and probably go for it. It will probably need to be filled with a patching compound used on these bumpers then painted.
    Depending on how low on the car the scrapes are, how visible they are and your tolerance for (im)perfection, the touchup guy may just work.
    A body shop could easily get 3X or 4X the cost.....
    Good luck!
  4. mechanic
    mechanic New Member
    is it soft or hard rubber? painting over soft rubber sounds like a bad idea
  5. kgall
    kgall Active Member
    984
    152
    Here's a photo of the worst part of my problem, from the front driver's side:
  6. stream
    2,977
    452
    Long Island, NY
    Doesn't look like a DIY job to me.
  7. Teakwood
    Teakwood Member
    491
    73
    New Mexico
    D'ya think that just maybe it's made of ABS plastic?
  8. danvee
    326
    53
    New Jersey
    I'd still be betting it's a kind of urethane.....
    The scrapes seem a bit deep and filler may be required. There are guys out there that do pretty decent patch jobs on dealers' cars, so I'd be checking out the offer from yours to have their guy look at it.
    You might also check eBay, as I've seen a number of bumper covers available in your color with less damage (sometimes under the front license bracket) that would cost about $250 shipped. If you can do the swap yourself it would cost considerably less than what the average body shop would charge to repair and repaint your original cover.
    Just a thought.......
