Curt Hitch Released for ordering 2010 Prius
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Complex, Jul 20, 2009.
  1. noweyout
    noweyout Trying to get used to it
    24
    SoCal - SGV
    Anybody use loctite?
  2. vuduvgn
    vuduvgn Junior Member
    Chico, CA
    2015 Prius v wagon
    2" hitch found, installed. Discussion is on here, search it.
  3. LetsGoCamping
    LetsGoCamping New Member
    22
    Illinois
    rrolff - did you ever get an answer as to whether this is a 2" receiver? If not, we would have to use an adapter and extend the whole rack out more behind the car. (Even a "little" more would not be good as it was out plenty far on our 2005 with a 2" receiver.) Did you get this one?
  4. LetsGoCamping
    22
    Illinois
    ??????Who found a 2" hitch and installed it? Have searched many forums on this and have not found where anyone has installed a 2" hitch and reported on what kind it was and how it worked. I would like positive answer from someone who has done this. What kind was it? How is it working out? Was the installation easy? From what I can find out here and on the Curt website, this Curt hitch is only a 1 1/4" receiver - not acceptable. Quality S makes a 2", but still looking for a report from someone who is actually using one. Please reply only if you can answer the above questions with helpful information. Thanks.
  5. vuduvgn
    Chico, CA
    2015 Prius v wagon
    http://priuschat.com/forums/gen-iii...ch-2010-available-anywhere-5.html#post1151613
  6. The Critic
    The Critic Resident Critic
    3,193
    2,332
    CA
    Bumping this thread up...
    Thinking about getting the same Curt hitch for my Prius. However, I may want to occasionally rent a 5'X8' trailer from Uhaul for towing.
    The u-haul trailer uses a 2" attachment. The curt hitch is 1 1/4". So, will an accessory like this be safe to use in order to accommodate the u-haul trailer?
    Hitch Adapter - 2" Adapter for 1-1/4" Hitches
    Thanks.
  7. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    I worry the uhaul won't let you off the lot with a trailer if you show up with a Prius
  8. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    First - why would you get a 1.25" when there are 2" Class III hitches now available???
    Second, UHaul will look up your car, and I doubt they will rent to you. Even if they would, you'd need the lighting harness....
