Volt EV Range: It Finally Comes Out
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by hill, Sep 23, 2010.
  1. hill
    8,794
    25 to 50 Miles is what you'll get. Lead Foot - Cold Weather going aggressively uphill, with an older battery, you'll only get 25 miles. Drive easy on flat ground at lower speeds at ideal weather and you'll exceed the 40 they promise.
    GM: Chevrolet Volt Has a Typical EV Range of 25 to 50 Miles
    Now MY question is, WHEN will they ever come out with its CS mode mileage?
  2. LeadingEdgeBoomer
    289
    29
    New Mexico
    Um, isn't that about what GM predicted the EV-only range all along? After that the engine kicks in to charge the battery while the Volt continues to run on the electric motor. Corrections welcome.
  3. evnow
    evnow Active Member
    816
    155
    Seattle, WA
    2013 Nissan LEAF
    Until now, they have only talked about 40 miles. Nothing else.
    ps : This is what I don't get. Volt uses liquid cooling (active thermal management). They use only 50% of the 16 kwh battery. Yet, they have as much variability of range as Nissan Leaf using 80% of the not actively cooled battery - but with same 8 yr warranty.
    Is the LG battery of the same chemistry (Manganese Spinal) really that dated compared to Nissan's ?
  4. Erikon
    Erikon Active Member
    819
    105
    Rochester, NY
    Hmmm, a "moderate driver" will see 40 miles. In other words, drive it like a Prius? I do not know if that'll work with the typical GM customer!:D
  5. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Volt's battery pack has to work twice as hard as the Leaf. These are the contributing factors:
    1) Smaller battery pack (16kWh vs. 24kWh)
    2) More powerful electric motor (111 kW vs. 80 kW)
    3) Heavier car
  6. Rybold
    Rybold globally warmed member
    2,760
    322
    Southern California
    OH, THE HORROR !!!!!!! :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek:
    ... actually, that makes perfect sense. They've been estimated a 40 mile range. If a "normal" driver (drives with flow of traffic, in a non-aggressive flow) gets 40 miles, a lead foot gets 25 and a semi-hypermiler gets 50 miles, that makes perfect sense, since fuel consumption is not linearly proportional to aggressiveness (think: rate of acceleration), but rather a parabolic relationship (much like wind resistance increases parabolically as speed increases).
  7. TonyPSchaefer
    14,816
    2,500
    66
    Far-North Chicagoland
    25 miles would still get me to to work, where I can plug in before driving back. Forty would be best since I wouldn't have to recharge at work.
    But yeah, they've been touting forty miles of EV all along.
    Still waiting for the Charge Sustaining Mode mileage.
  8. TonyPSchaefer
    14,816
    2,500
    66
    It depends on your definition of "about".
    From the article linked in the OP:
    So that's 40miles plus-or-minus. (possibly plus 25% or possibly minus 37%)
    So, that's about right.
  9. David Beale
    David Beale Senior Member
    5,963
    1,988
    Edmonton Alberta
    I think you're all commenting on how many angels can fit on the head of a pin.
    Until they actually -SELL- the car nobody will go anywhere on EV.
    2 people like this.
  10. telmo744
    telmo744 HSD fanatic
    2,181
    769
    Portugal
    x2.
    GM, probably we will never forget the first mileage highlights you gave, so keeping us waiting won't change the (bad) smell of the marketing perfume.
  11. hill
    8,794
    The fact that CS mode has been kept so very secretive is a brain teaser. GM doesn't even mention CS mode in its IPO fileing. GM leadership isn't the type to keep good news secretive, so CS mode my be quite a shocker ... maybe enough to offset its EV capability?
  12. priushippie
    priushippie New Member
    330
    Pennsyltucky
    The Volt is an awesome vehicle and I congratulate GM for it! We need more of these vehicles. I might buy one.
  13. 1SMUGLEX
    1SMUGLEX I love the smug!
    315
    51
    Atlanta
    Good for driving around on short commutes but their HYPEBEAST is making any new facts look unremarkable.
  14. telmo744
    2,181
    769
    Portugal
    CS Speculation or a nightmare?
    If CS mode with a Volt gives 38MPG (not so bad for a 1.4liter SI or so), let's compare to a 3Gen Prius 52MPG...
    Take this example for a weekend trip 130miles long with no charge:
    Volt = 35mi EV + 95mi CS 38MPG = 2.5gal
    Prius = 130mi 52MPG = 2.5gal
    So GM, why did your Volt bring a electric cable along? Maybe to be pulled by a Prius...LOL
  15. 1SMUGLEX
    315
    51
    Atlanta
    Okay maybe its just me but here GM got saved by Taxpayer dollars and they invest it in this vehicle that continues to get more and more underwhelming figures and then they will sell it at 42k then offer a "tax credit" to purchasers who lent them their money to make it in the first place.
    This is not looking like some true new alternative at all and for the price seems like a giant let down. $42,000 or so before a credit? Nearly twice as much as a Prius? Really?
  16. hill
    8,794
    Well if you want a TRUE alternative, created by GM, with Fed tax bailout money, GM IS releasing a pure EV this year. See if you can pick one up. Heck, I'll take one too!
    http://priuschat.com/forums/prius-h...lt-even-if-theres-cruze-electric-vehicle.html
    See? Your tax dollars ... hard at work
  17. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    For years GM said "40 EV miles," it is only recently they changed it to *up* to 40.
    The person who gets 25 EV miles will have been promised 60% more EV miles. I find the symmetry funny: GM promised $25k, but ended up charging ~ $40k; they promised 40 EV miles, but deliver 25.
  18. drees
    drees Senior Member
    1,782
    247
    Yeah, it's about right.
    Just like 50 mpg +25% -37% is about right for the Prius.
    Not sure why people are getting their panties in a bunch here.
  19. hill
    8,794
    The panties bunching may be simple. If GM is counting on a substantial percentage of Leaf drivers getting only 25 miles, that would be worse that if (for example) you have (per MILLION) 1/2 of 1% of Prius drivers getting 37mpg ... that would be maybe 5,000 lead foot / freezing weather / short trip, drivers per million. IOW, it may all turn on the per centages. of folks doing way better or way worse than the promised EV range. Since GM has been so consistent with over promising ... truth twisting ... and out right lies ... well ... one tends to facter that into the 'truth equasion'.
  20. lytthans
    lytthans Junior Member
    52
    I saw a prototype of the PHEV Prius at the Los Angeles County Fair last week and asked the lady working the booth what the electric only mileage would be. She said that on this prototype it runs about 13 miles, then switches to the normal Prius mode, with less mileage, due to the extra weight of the batteries. But they are still tweaking it.
