Techron or Fuel Additives?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Crankykentucky, Sep 24, 2010.
  1. Crankykentucky
    Crankykentucky Junior Member
    65
    Midwest
    I grew up around some mechanics who swore by Chevron Techron--especially for around town driving. When a friend of mine ran a couple of tow trucks that idled a lot, he added Techron every 10,000 miles. Since the gas engine on the Prius starts and stops quite often, does anyone see a need for a fuel additive to keep injectors clean, etc?
    Just wondering.
    Thanks!
    Fred
  2. Paul58
    Paul58 Mileage Miser
    1,126
    125
    Atlanta
    Interesting question, I'd be interested in hearing some opinions on this as well...
  3. Fuel Miser
    Fuel Miser Junior Member
    86
    22
    Ontario, Canada
    I used to use Redline SI-1 which has a similar chemical to that found in Techron. That chemical is (PEA) polyether amines.
    It acts as a surfactant instead of a solvent making it safe for all components in the fuel system. It attacks carbon and deposits like no other, and even survives the combustion process so it can clean O2 sensors, catalytic converters and EGR valves. If you are going to use anything, those that contain PEA are the best.
    Redline SI-1
    Techron
    Gumout w/Regane
    just to name a few of the big ones. I'm sure there are more.
    Now Shell advertises a new nitrogen enriched formula, they are referring to the nitrogen atoms that make up amines.
    I will continue to use these products as it has proven itself to be the best of the best. I've brought back a lawnmower, a snowblower, and some guys car from up the street with this stuff. Go ahead and use with confidence.
  4. DetPrius
    DetPrius Active Member
    545
    92
    Southeast Michigan
    I used to use an independent Honda shop for my CRX and the service manager said that while they did not believe in the "mechanic-in-a-can" idea, they found the Techroline product to be helpful in keeping the components it targets clean. They told me this when I had them clean the throttle body after the idle became rough. I've been using one bottle each time I get the oil changed and never had the throttle body cleaned after that. No, this is not scientific proof that it works. I have several bottles left in the garage and haven't decided if I will use it proactively in my Prius.
    On a related note, I did call the Chevron technical hotline with a related question and the gentleman told me that Techron Concentrate Plus is a better product than Pro Gard.
    YMMV
  5. Paul58
    1,126
    125
    Atlanta
    So, are these products available at you local Advance Auto, Pep Boys, O'Reilly's, etc, or do you have to get them at some speciality auto shop?
  6. hpartsch
    hpartsch Member
    102
    pa
    Yes, even walmart carries some of them.
  7. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Yeah, I use a bottle of Techron once a year and always buy it at WalMart...
  8. Paul58
    1,126
    125
    Atlanta
    Awesome... Thanks!
  9. Genoz World
    Genoz World ZEN-style living
    797
    22
    La Canada
    I've got upwards of 50K on my prius now and I think I've used about 3 bottles of chevron techron so far. Everytime I use it, I feel the difference. maybe all in the mind.
    PrimeDan and Palmoyas like this.
  10. Crankykentucky
    65
    Midwest
    Thanks for this. It's like vitamins for your body, my doctor always says you are wasting your money on them but my pharmacist tells me doctors always buy vitamins and CoQ10 from him for their own use. Some dealers and service techs will tell you additives are a waste of money.
    @Genoz World--My mechanic friend used to say that Techron was one additive that you wanted to be careful with when it comes to the recommended amount/bottle size per gallons of fuel. I thought he was crazy and put a full bottle in a half tank of fuel on my old S-10 Blazer. The Blazer ran fine for a while and then started to stutter a bit, so I think he was right.
    I brought back a friend's car using the old BG (is that right?) additives that you can only buy from a mechanic or full service station. They are great additives.
    I also have a friend who had a fuel injection failure on a new Ford Taurus and when the mechanic got done charging him $2,000 for the work he told him that Techron could have helped keep his injectors from getting plugged. My friend uses it religiously. You have to watch it because there is a Chevron additive that looks like Techron, but it isn't. Walmart used to carry the real thing, so be careful.
  11. nthach
    nthach New Member
    174
    I use Techron, SI-1 or Regane. They're safe for the fuel system as the only solvent that carries the PEA in it is either kerosene or stoddard solvent(paint thinner). I wouldn't use BG 44K/Berryman's in a Prius due to the potential risk of fuel bladder damage from the methanol, acetone and toluene in those products.
  12. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    Why fuel additives? Oil compaines spend billions of dollars refining their products so they will be the best there is.
    I remember when I was a kid back in the 60's there was all types and sizes of snake oil products availaible.
    Personally, I do not use any of them and I have been driving since
    1966, and never seen a need for them.
    If there was a clear and concise scientific study I would take a peek at it, but I know of no scientific research where snake oil products do all they claim to do.
    al
  13. cobradb
    cobradb Member
    105
    tn
    colgged or restricted injectors usually shows up at idle first... its a head thing beyond that... for example i purchased a used motorcycle and it had a rough idle,, techron fixed it in about 30 minutes.
  14. cit1991
    cit1991 New Member
    289
    95
    Tulsa, OK
    Techron is old, but it's the real deal. Buy it anywhere that has it cheap. It's generally easy to find.
    Redline SI-1 is also good, but harder to find. For many years BMW's dealer-sold, BMW-branded fuel injector cleaner (in the US) was Redline SI-1 with a different label (same bottle though).
    Those two are the real stuff. There may be others now, but there are TONS of impostors that are nothing but light naphtha (about $1.50/gallon cost).
  15. lonewolf69
    lonewolf69 New Member
    84
    Jericho, NY
    I've been using Techron in my Lexus Truck GX470 and my Brand New Prius religiously I'm a little more "liberal" in my application though, I use it every other tankful...
    Is it keeping the engine/injectors clean, don't know but I figure with the $$$ that I'm saving at the pump, I'm more than happy to spend a few extra $$$ for the Techron...
    Really glad to see so many positive replies about the product...!
  16. richard schumacher
    7,664
    1,047
    United States
    Use E10 and your injectors and valves will get all the cleaning they need.
  17. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    I add a bottle of Techron every 5K miles or so. It doesn't hurt and it probably helps, especially since I don't always use tier 1 gasoline. I don't use any other additives for my vehicles but I think this is one that really works.
  18. MG6
    MG6 New Member
    Bay Area
    pouring in Techron fuel injector cleaner isn't a bad idea... but if you pump tier 1 gas, you should be good as well because gas company nowadays have additives already in the refining of the gas.
  19. Paul58
    1,126
    125
    Atlanta
    What about Seafoam? I tried to purchase a bottle of Techron at Advance Auto the other day for my wife's CR-V and they told me Seafoam was a miracle in a bottle! Was I scammed?
  20. Skoorbmax
    Skoorbmax Senior Member
    2,641
    265
    Western NY
    Like in health there are a lot of hunches and anecdotes. Factually most fuel additives are either not helpful or actually injurious. Techron is, as far as I know, one of the very few that have an actual proven benefit in some cases. However, always defer to the manual. You do not know better than the engineers who built the engine. And neither does your mechanic, no matter where he works or what cars he's worked on. I don't know what the manual says for fuel additives. In many cars the manual says don't use them.
    I recall that Chevron gas has some techron added to it. I have put some bottles through my other vehicles every 10k or so. I have no idea if it helped but I do recall reading it can be one of the fuel additives worth trying. To be honest I'll check the manual on the Prius first. If it says, and I almost bet it does, do not add additives I will not, period.
    Some people write songs about seafoam. I've never used it. My believe in these things is until you can show me a real study indicating its proven benefit I am not going to use it, no matter what Jimmy at Autozone has to say about it.
