What grease (or similar) in license plate holes?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Skoorbmax, Oct 2, 2010.
  1. Skoorbmax
    Skoorbmax Senior Member
    2,641
    265
    Western NY
    I have just spent quite a few hours playing around with POR-15 on my other car (not a Prius) and also drilling out a rusted bolt when I had to change the plate (thing was totally rusted in and I even took the impact screwdriver to it!).
    On that vehicle, and others I see on the road, there is often rust on the back around the license plate area. I believe that the license plate's metal resting up against the paint is awful on paint, so I've put a few daps of silicone on the back of my plate before putting it back onto the car (yes, I let that silicone dry!). But also I want to lube up the holes where the screws go in. I'm less concerned with them locking into the threads (anti-seize would solve that) than I am moisture just "hanging around" that area and rusting out where the screw goes.
    Any ideas on good greases? I cannot find for example if lithium brake grease is safe on paint. I know car wax is obviously but it has a limited lifespan.
    I'm pretty sure most people just apply their plates straight into the car and I am pretty sure it's a bad thing to do as years down the line it can cause issues.
  2. phoenixgreg
    phoenixgreg Senior member
    1,157
    291
    66
    Phoenix
    Try plumber's high temperature grease (easily found in hardware stores). It is silicon based and should prevent any corrosion on the threads. It can also be used on the door seals (if they make noise or begin to dry out) and on the glove box latch tabs to quiet interior noises.
  3. hyo silver
    hyo silver Awaaaaay
    15,269
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    Another plumbing item that would work well is some teflon tape. It should seal out the water and won't dry out like grease eventually will.
  4. Skoorbmax
    2,641
    265
    Western NY
    Tape coudl work but would only seal the threads. I was in lowes and the silicone lube spray says specifically safe for paint but I am not sure whether the silicone brake grease would be also safe (I said lithium in first post, meant silicone).
  5. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    Use stainless steel screws.
  6. chrisj428
    chrisj428 Active Member
    680
    144
    35
    Vernon Hills, IL
    You can get anti-seize compound in an auto-parts store.
  7. Michael33
    Michael33 Member
    372
    62
    Upstate NY
    2013 Prius Plug-in
    If you can get to the other side of the hole, use plastic screws and nuts. If not I've had good results with white petroleum jelly. Stainless steel is better than mild steel, but don't think it won't rust - it will. Brass is better, again if you can use screws and nuts.
  8. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    Don't the screws go into plastic? I would just leave it alone as it's already plastic and if you lube them up they can come out. I would bet the plastic tabs the screws go into only cost 1-3$ to replace.
  9. Skoorbmax
    2,641
    265
    Western NY
    On the Prius they may. It does appear that the dealer used plastic screws in this case so I'm good to go. I'm surprised not everyone has been using plastic for years, it just makes so much sense in this case.
  10. tumbleweed
    tumbleweed Senior Member
    4,067
    691
    Eastern Oregon
  11. Barefoot
    Barefoot Junior Member
    43
    Lusby MD
    Depends on which stainless alloy you use.
  12. Former Member 68813
    3,524
    983
    US
    Dissimilar metal is going to invite galvanic corrosion. Plastic is best.
