LED bulbs
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Superdrol, Oct 2, 2010.
  1. Superdrol
    Superdrol Member
    399
    32
    Is there a led bulb website that ppl who have replaced their bulbs with recommend ? I am guessing that the type of bulb is in the owners Manuel. Also I was looking at the interior lighting, are the covers just held in by pressure clips that you pry off ?
    The interior lighting would look better with a whiter light vs the stock orange.
    Thanks
  2. LulzChicken
    LulzChicken Prius Enthusiast
    791
    135
    Alabama
    Here is a thread I made a while ago. It should have all the information you need.
    http://priuschat.com/forums/gen-iii...or-led-installation-pics-info-bulbs-used.html
    The dome lights are easily taken off. I think I have a picture in my thread somewhere showing how to do it. You just have to get a flathead in the little space and pry it off - you'll see the space if you look for it.
    EDIT: Also - I replaced the front door lights that come on when you open the door to blue. Looks really neat.
  3. Superdrol
    Superdrol Member
    399
    32
    Thanks for the info . Did you also change out the trunk light and the vanity lights by the fold down visors ?
  4. alekska
    alekska Active Member
    435
    138
    Atl
    I used superbrightleds dot com several times (I'm not allowed to post links yet.)
    Never had any problems with them or their products.
    Best,
    - Alex
  5. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
    I use panel style instead of bulb style because I wanted all the LEDs to shine into the cabin. You can see pictures of my interior in my signature.
  6. LulzChicken
    791
    135
    Alabama
    I actually did not change those out as I never use them. However I assume they are easy. I believe the trunk light is a Festoon bulb as well. Not sure about the fold down visor spots though.
  7. cproaudio
    2,401
    762
    CA
    Fold down visor bulbs are the same as front map lights and door lights.
