2008 Prius Top Plastic Radiator Cover.
Discussion in 'Gen 2 Prius Main Forum' started by ronhowell, Oct 3, 2010.
  1. ronhowell
    ronhowell Active Member
    681
    32
    Cypress, CA.
    I'm sure many of you are familiar with the top plastic cover on the 2nd gen Prius which covers the cooling fans and radiator just under the engine hood. It is secured by 6 plastic fasteners, which have to be, IMHO, the stupidest type of fastener ever invented!
    I have studied the design format of these things and have yet to determine the correct way to either remove or replace them. Both actions end up being a hassle, and today I broke one of the fasteners when trying to remove it. Maybe the experts use a special tool.
    It is of course no major calamity, but I have wondered if any others in the community have figured out how these things should be removed or replaced. Even when replaced in the panel, they don't seem to hold it very securely.
    Any constructive comments are welcome.
  2. Patrick Wong
    18,200
    6,500
    Hi Ron,
    1) Rotate the fastener with a Philips screwdriver while applying upwards pressure on the cover near the fastener. The idea is to pop the fastener out of the hole.
    2) The plastic becomes brittle with age and ozone exposure. Don't worry about the fact that some fasteners will break as you attempt to remove them. If you frequently DIY repair, I recommend that you maintain a stock of those fasteners so that you won't be frustrated when they break.
    3) Please see my post #4 here: http://priuschat.com/forums/gen-ii-...bleshooting/30477-plastic-push-fasteners.html
  3. Bob64
    Bob64 Sapphire of the Blue Sky
    1,540
    93
    Virginia
    The easiest way is to push from under the cover. Most of them are within reach. Just curl your finger under and push them out. Easy.
  4. dogfriend
    7,512
    1,189
    Carmichael, CA
    Yes, this is what I do. There is only one that is difficult to reach from below, and for that one I do what Patrick suggested above, I lift the cover slightly.
    To replace them, you just push them into the hole.
  5. David Beale
    David Beale Senior Member
    5,963
    1,988
    Edmonton Alberta
    The -correct- way to release them is to press the centre out half way. I usually end up forcing them out anyway. ;) Just be ready to catch them. They fly very well!
    They are cheap and used by most makers. That's why they are there.
  6. ronhowell
    681
    32
    Cypress, CA.
    Thank you all for your remarks and comments on how to handle these little tykes. I did finally find some illustrations on removal in my Prius Handbook.
    As you say David, they do fly well when trying to extract them, but since they must be cheap enough I should probably pick up a number of them from someplace. Somehow though I imagine that they'd have a huge mark-up at the local Toyota dealership.
    Any suggestions on where else I might obtain a supply?
    PS. Thank you Patrick for the link.
  7. kohnen
    kohnen Grumpy, Cranky Senior Member
    317
    58
    Fullerton CA
    I found them at Lowe's (the hardware store).
  8. David Beale
    5,963
    1,988
    Edmonton Alberta
    I found them at a bodyshop supply store.
  9. jelloslug
    jelloslug It buffed right out!
    813
    55
    Greenville, SC
    I have half a box of them left over from when I repaired the '08.
