My Yellow ABS and Red Brake lights came on. Can I use this method to turn the lights off?
Discussion in 'Gen 2 Prius Main Forum' started by Danny21, Oct 2, 2010.
  1. Danny21
    Danny21 New Member
    Oklahoma
    The Red Brake light and the Yellow ABS light came on 2 days ago. But I have continued to drive the car and cannot detect any difference in the cars braking performance. I did spend a couple of hours on these forums searching the threads for clues and suggestions. I have tried all of of the suggestions, and still the lights are on, but the car seems to be fine.
    Also on these forums, I found this thread which describes this method of turning the "trouble" lights out using a jumper wire and pumping the brake pedal 8 times within 5 seconds and wondered if I should use this method to try and turn the lights off.
    I don't have scanguages or any type of device to read any possible codes that may be stored in the cars memory. And since the brakes seem to be fine, I was hoping to find a way to turn the lights off, and then see if they come back on later, at which time I would either get it to a dealer, or purchase a device to retrieve and read the codes.
    So, do you think it is okay to use the above method to turn the lights off, and see if they come back on?
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    You should get the car serviced. The warning lights indicate a problem.
  3. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    Yes, I agree with firepa63, it's Dealer time!!!
    The car is smart enough to alert you of a problem. you should listen to it. The LAST thing you want to ignore is BRAKES!!!
  4. Patrick Wong
    18,200
    6,498
    1) If the ABS light is on, then that system is inoperative. If you hit the brake pedal hard in an emergency stop, the tires will skid.
    2) The BRAKE light being lit also indicates a serious system problem.
    3) Since the braking system is a crucial safety system, you really should not mess around. It is possible that the DTC logged is for an intermittent problem. More than one DTC may be logged at different times. If you erase the codes then you will lose this history.
    4) Since you are in a position where you feel the need to ask this question, I assume that your Prius-specific technical knowledge is at a low level. I also assume it is unlikely you will be able to DIY repair the system.
    5) Therefore, I recommend that you follow the advice provided by the other posters, take your car to your local Toyota dealer ASAP, and don't worry about spending ~$100 for the DTC to be read and a diagnosis provided to you. Good luck.
  5. Blizzard10
    Blizzard10 New Member
    168
    Queens, NYC
  6. Danny21
    Danny21 New Member
    Oklahoma
    Thanks Patrick and the rest who replied to my question. Yes, my technical knowledge on the Prius is definitely a beginner level. We have only had the car for a few months. I have tried to spend a lot of time reading on these forums to start obtaining a "basic" knowledge of the car. And so far, we absolutely love the car.
    And I certainly agree.... with all of you, that the car needs to be checked out by a dealer or a qualified Toyota/Prius shop to see for sure what is going on. Unfortunately, this is not possible right now. I didn't want to go into it when I submitted the original post, because of making the original post longer than I had already made it....
    But basically...... serious health problems + cancellation of my health insurance by the insurance company = Unable to work = ZERO available funds for any repairs right now.....
    All that we can do is what we have already done. Park the Prius, and drive my Ford Ranger...... which is getting about 1/2 the mileage that we get with the Prius..... In re-reading my original post, I'm sure that everybody thought that I/We are continuing to drive the Prius all over town. I have only driven it a few times, on a back-road in our neighborhood...... just to test the brakes.... No cars, people, animals....etc..... on the road..... In fact, no houses on that road.... they haven't developed that area of the housing addition so far.....
    But I have driven the car on that road a couple of times....and experimented, slamming on the brakes..... backing up and slamming on the brakes..... slowly applying brakes..... etc...... and so far it has never hesitated to stop..... The only thing that I do notice, is that when hitting the brakes hard, I do not hear that "clicking" sound that I have always associated with "ABS" brakes..... So I am sure that you are right, and the car does not have the ABS function of the brakes.....
    I guess I should have made my original question clearer..... In the method of turning off the brake warning lights on my dashboard...... the method that I found on these forums that involves using a jumper wire to short pins 4 to 13, and then pumping the brakes 8 times in 5 seconds, etc...... (PriusChat won't let me insert links yet) But I was under the impression that this method would only reset the warning lamps (turn them off) So I guess you are saying that this method will also lose the "history" of any codes that are in the car's memory? If so, I definitely don't want to do that.....
    I thought that I could use the method to turn the lamps off..... and then if they came back on, there is definitely a problem..... but if they don't come back on, everything was fine..... but no???
    There were several posts that indicated that might be true..... some suggested that sometimes these warning lights come on for "unknown reasons" ...... just a "fluke" so to speak......
    So that was my thinking...... turn lights off with jumper wire method...... see if the lights come back on...... Park the car until we have some extra money to get it to the shop......
    So, if anyone has any more thoughts on this last question, I would be very grateful. That question being....."Does this jumper wire/brake pumping method....... turn the warning lights off on the dashboard without erasing the internal vehicle codes?"
    Thanks for everyone's help and patience with a newbie.
    Danny:)
  7. Patrick Wong
    18,200
    6,498
    Hi Danny,
    Very sorry to hear about your financial issues. The jumper method will definitely erase any pre-existing codes.
    If the 12V battery is marginal, that has the possibility of inducing a "false" DTC. I suppose it won't hurt for you to erase the codes since you won't be fixing the car any time soon. You'll probably need to log 1,000 or 2,000 miles to see whether the warning lights reappear. Good luck.
    2 people like this.
  8. RobH
    RobH Senior Member
    2,376
    988
    70
    Sunnyvale, California
    A little perspective on ABS...
    The Prius is my first car with ABS. So losing ABS on my car would revert it to the braking capability of my previous cars. It also has airbags all over the place, while my previous car had one on the steering wheel. Earlier cars had none.
    So would it be safe to drive a 1990 car on the roads today? One without ABS, multiple airbags, or, heaven forbid, no TPMS?
    I know Autozone stores offer to pull DTC codes for free. You might try to find a store or mechanic who could pull the codes. Once you know what the codes are, you'll be in a better position to understand the potential dangers.
    I agree with Patrick that the 12V battery could be the main issue. A marginal 12V battery causes all sorts of problems with the multiple computers (ECUs) on the Prius. For a 2004 vehicle, I'd seriously consider replacing the 12V battery just based on its age.
    Sorry to hear about your medical/insurance problems. Time to start checking out the wealth of medical information available on the web. One place to start is DoctorYourself.com - Health, Naturally! . Our medical system has priced itself out of the range of many people. And for all the money, they're long on diagnosis and short on cure. Harrump.
  9. Danny21
    Danny21 New Member
    Oklahoma
    Many thanks for your response and suggestions on the brake issue Robert.
    And even more thanks for the comments and insight into the medical issue..... and for the the link to DoctorYourself. With my current health condition, I am in bed half the time, so I am able to do a lot of reading & research on the internet. But I didn't know about the DoctorYourself web site. Very enlightening reading. I plan on ordering one of the books. I am considering ordering either "Doctor Yourself" or "Fire Your Doctor" as an introductory book. Any recommendation between the two?
    And as for the Prius issues:
    The same thoughts had run through my mind. All of those years back in the 70's & 80's when we were crisscrossing the US in my Dodge Van, making a living as a musician.... and we are still here??? Amazing!
    Seriously though, I am sure that ABS and all of the new brake technology is for the better, but I have never been in an accident that was my fault, where brakes were a factor. Just lucky I guess... Still.... I'm keeping the Prius parked for now, makes the most sense..... since we do have another vehicle we can drive.....
    I plan on calling a few of the Autozone's and O'reilley's and others in the area, to see if I might find someone who would pull the codes for free, or at a reasonable cost.
    Checking the 12V battery has actually been on my list of things to do for the Prius. I can only get around 45mpg in town, no matter how I drive (wife only gets about 39) and I had read the posts that indicate that a weak 12V battery can cause a loss in mpg. I don't know how old the battery is, but maybe it is the original. We bought the car from a used dealer down in Texas, and the dealer claimed to not have any of the car's history. We did obtain a little bit of history on the car when I joined the Toyota web site and registered the car. But nothing about a battery change, so I guess it could be the original battery. I did download and print out several methods of self-testing the battery, so I will do that. I guess if I do find a bad battery, I will then consider "erasing the codes" after I am able to replace the battery. Or if I can find someone to pull the codes before I get a chance to check the battery, I may go ahead and erase the codes (and turn warning lights off) once I have recorded the codes that the vehicle's memory has stored now.
    Thanks again!
    Danny
  10. RobH
    RobH Senior Member
    2,376
    988
    70
    I haven't read either of those books, but I do like his attitude. Either one should be fine.
    One book that I have read and recommend is "A Return to Healing" by Len Saputo, MD. In it he points out that only about 15% of what doctors do is backed up by good research.
    The simplest immediate thing that you can do for your health is to make sure that your vitamin D status is optimal. I attended a health seminar on vitamin D where the researchers went on about literally dozens of problems made worse by low vitamin D. Heart disease, cancer, MS, diabetes, flu, and on and on. As someone with a health challenge, my guess is that you need at least 50,000 IU per day for several weeks, reducing to 10,000 IU per day thereafter. The target is 100 to 200 ng/ml on a blood test after about 3 months of supplementation. At these high levels, it is necessary to not take any supplemental calcium, and do regular blood testing of calcium. Anybody who recommends 1000 IU or less per day simply is not up on the current research. Recommended web sites are GrassrootsHealth | Vitamin D Action - GrassrootsHealth | Vitamin D Action and Vitamin D Council | Understanding Vitamin D Cholecalciferol . Recommended book is "Vitamin D The Sunshine Vitamin" by Zoltan Rona, MD, MSc.
    The next thing you can do is diet. And I don't mean a "skin the chicken and no egg yolks" one. My favorite diet doctors are Dean Ornish, John McDougall, Caldwell Esselstyn, and Joel Fuhrman. McDougall has the most palatable recipes.
    For cancer issues, read "Knockout: Interviews with Doctors Who Are Curing Cancer -- And How to Prevent Getting It in the First Place" by Suzanne Somers. To describe this book as controversial is putting it mildly. But a few success stories sure beats the average outcomes that I've seen with cancer. Oh, and the lady who runs the Grassroots Health vitamin D site that I mentioned above describes herself as a "breast cancer treatment survivor".
