Does a Prius have shocks?
Discussion in 'Gen 2 Prius Main Forum' started by gobux, Oct 7, 2010.
  1. gobux
    gobux Junior Member
    60
    Columbus, OH
    I ordered my struts on a KYB outlet site. It's 4 KYB struts. However, I saw nothing about shocks.
    I'm so confused on shocks/struts..
    KYB Online Parts Catalog
  2. narf
    narf Active Member
    611
    45
    Colorado
    Four Touring
    Struts are shocks. ...Actually struts are shocks that also support part of the cars weight.
  3. Patrick Wong
    18,204
    6,505
    "An automotive suspension strut combines the primary function of a shock absorber (as a damper), with the ability to support sideways loads not along its axis of compression, somewhat similar to a sliding pillar suspension, thus eliminating the need for an upper suspension arm. This means that a strut must have a more rugged design, with mounting points near its middle for attachment of such loads."
    [ame]http://en.wikipedia.org/wiki/Strut[/ame]
    Thus, the Prius has front struts and rear shocks.
  4. qbee42
    3,079
    If you mess with any of the orange wires, the Prius can produce a tremendous shock. The 12V system is unlikely to produce a shock unless you stick your tongue onto it (highly unrecommended). I find I often get shocks from touching the door frame after sliding out of the car.
    Hope this helps. ;)
    seaglasspearl2013, UGC and patsparks like this.
  5. ursle
    ursle Gas miser
    1,049
    192
    NH
    I just ordered replacement parts yesterday, hope you got everything you need, here's what I got, the rear struts are the same, the front struts are different, so there's a left and right, you need the bushings for the top of the rear struts and the strut mounts for the front struts, and you need the boots that protect the struts from the elements.
    The assembly is called a McPherson strut, it's a strut inside a spring, the whole assembly is removed from the car, the spring is compressed with a strut spring compressor and the strut is removed and the new one installed. After replacing the struts the vehicle has to be realigned.
    On Your Order:**Part #:* KYSB1082006 Toyota Prius Base 4 Cyl 1.5L KYB Shock and Strut Boot Shock and Strut Boot PriusKYB*Qty:* 2.00 *Price:* $ 12.93*Part #:* KYSM53822006 Toyota Prius Base 4 Cyl 1.5L KYB Strut Mount Bushing Strut Mount Bushing PriusKYB*Qty:* 2.00 *Price:* $ 11.60*Part #:* KYSM52152006 Toyota Prius Base 4 Cyl 1.5L KYB Shock and Strut Mount Shock and Strut Mount PriusKYB*Qty:* 2.00 *Price:* $ 65.35*Part #:* KY3333892006 Toyota Prius Base 4 Cyl 1.5L KYB Shock Absorber and Strut Assembly Shock Absorber and Strut Assembly PriusKYB*Qty:* 1.00 *Price:* $ 55.67*Part #:* KY3333882006 Toyota Prius Base 4 Cyl 1.5L KYB Shock Absorber and Strut Assembly Shock Absorber and Strut Assembly PriusKYB*Qty:* 1.00 *Price:* $ 55.67*Part #:* KY3413222006 Toyota Prius Base 4 Cyl 1.5L KYB Shock Absorber and Strut Assembly Shock Absorber and Strut Assembly PriusKYB*Qty:* 2.00 *Price:* $ 62.36
  6. patsparks
    10,664
    567
    Adelaide South Australia
    Thanks Tom, saved me a post. well actually i posted anyway. I take back my thanks.
  7. bstephens
    bstephens Junior Member
    36
    Oklahoma
    Patrick Wong failed to mention that he has posted a very detailed write up on priuschat on how to change out the front struts and rear shocks. I used his info for my rear shocks (thanks Patrick).
  8. s3nfo
    s3nfo Member
    164
    24
    San Diego, Ca
    Did my rear shocks yesterday. Not a hard job, but not a job for the faint of heart either as you've got to remove everything in the back of the car including the interior trim panels and the rear seat backs. Only thing I didn't take out was the traction battery and the spare tire. Took me just a bit over 4 hours to do the 2 rears.
  9. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Did you use stock shocks or upgraded?
  10. s3nfo
    s3nfo Member
    164
    24
    San Diego, Ca
    KYB GR2's. Don't know if the OEM's had just worn out, or the GR2's really are stiffer, but she handles a lot better now.
  11. ljdog
    ljdog Junior Member
    Do you know where that write up is posted? I've tried looking in his Posts, but with no luck.. thanks (I'll also contact Pat)
