Driving in third world country roads, over inflate tires?
Discussion in 'Gen 3 Prius Main Forum' started by mwok86, Oct 12, 2010.
  1. mwok86
    mwok86 New Member
    203
    usa
    I'm driving in third world country roads right here in DC and was wondering if over inflating the tires will reduce the impact from the potholes? I also notice that the prius constantly lose braking because the roads are in such bad condition.
    What PSI should you over inflate the front and rear tires to?
  2. silverfog
    silverfog New Member
    152
    Raleigh,nc
    PSI won't cut it.
    Why not check out visa and work permit requirements for Europe?
  3. fuzzy1
    10,421
    Higher tire pressure makes for harsher rides, so the potholes will hurt even more.
  4. mwok86
    mwok86 New Member
    203
    usa
    Don't really care about harsher rides but want to prevent damage to the Prius. I thought that high pressure tires will absorb the impact and cause less stress on the shocks, structure, suspension etc.
  5. patsparks
    10,664
    567
    Adelaide South Australia
    Softer tyres reduce shock loads on the car and suspension but increase rolling resistance.
  6. Skoorbmax
    Skoorbmax Senior Member
    2,641
    265
    Western NY
    Horray! Another obsessive post by mwok.
  7. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    The general rule of thumb when driving on roads with ruts and pot holes is that higher tire pressures will put the tires at greater risk but might help save the rims. Rims usually cost more than tires so I would use higher than the recommended pressures.
    If it were me I would try 40 psi or so. The ride will be a little harsher than with the recommended pressures.
  8. Skoorbmax
    2,641
    265
    Western NY
    You're right, but also the higher tire pressure is going to slightly increase wear on the suspension components, so mwok's suspension is going to have a shorter lifespan :eek:
  9. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    You need to inflate the front tires to 95 psi and rear tires to 93 psi. Otherwise, you risk a tie-rod end break, at which point the car will lose steering and go "in the weeds" or the electronic steering will command "full left," which will cause you to crash head on to a SUV, leaving 5 dead.
  10. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Are you kidding? Either that or you're being mischievous! There's no way I'd inflate my tyres to 95 psi, well not unless I want an imminent blow out or bounce 5 foot off the ground if I hit a bump.
  11. Skoorbmax
    2,641
    265
    Western NY
    I can't find it now, but there is a graph showing wear and tear on the Gen 3 based on PSI and it goes up hugely with PSI. However, there is a very tight range sweet spot at which MPG soars to 115 city and 97 highway and will let the car hit over a G on the skidpad. That must be what 32kcolors is referring to.
  12. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Just don't go all the way to 95.
    The sweet spot is 94.5.
    http://www.apriliaforum.com/forums/showthread.php?t=209808
  13. Former Member 68813
    3,524
    983
    US
  14. Skoorbmax
    2,641
    265
    Western NY
  15. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    My guess is that the male significant other in her life created those bombs for her to drive around on.
  16. fuzzy1
    10,421
    Don't anyone tell this to Wayne Gerdes's tires. It might give them ideas.
  17. mwok86
    mwok86 New Member
    203
    usa
    It doesn't make sense. If there is more PSI in the tire, doesn't it absorb the impact? With less PSI, the tires deflect the impact to the rims and suspension?
    Sort of like an airbag. The airbag inflates and absorbs all the force.
  18. Skoorbmax
    2,641
    265
    Western NY
    Take a pillow. Now take a ball that weighs the same and blow it up nice and high. Which one would you rather have hit your face at 50 mph? The more air in a tire, the less it compresses. The less it compresses--travels--the shorter the distance a given impact is dissipated. Shorter distance = higher acceleration forces. A ball made out of diamond would still compress, albeit it very little. It would be like a very high PSI object. How much impact would that absorb? It would make for a rough ride riding on diamonds instead of tires.
  19. GWhizzer
    GWhizzer not so Senior Member
    120
    24
    Winnipeg, Manitoba
    Sure, if you deflate your tires enough and hit a big enough pothole, the tires will "bottom out" and the rims will take the brunt - and they are much harder than tires. At recommended or near recommended inflation, you'd have to hit one hell of a pothole to bottom out. So much so that I'd be more worried about my car, perhaps my kidneys.
    At the end of the day (assuming one utilizes common sense and keeps at least a reasonable minimum inflation), the rule of thumb is the more PSI the harder the tire and the rougher the ride. The rougher the ride, the harder it is going to be on you and your car's suspension.
  20. mwok86
    mwok86 New Member
    203
    usa
    So should I keep it the recommended PSI levels or just a tad lower (what PSI?) on poorly maintained roads?
