Gen III Engine Air Filter
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Sealawyer, Nov 20, 2009.
  1. Sealawyer
    Sealawyer New Member
    32
    Fort Lauderdale, FL
    Has anyone else noticed that opening and changing the Gen III engine air filter doesn't seem as intuitive as it was on the Gen II?
    Apparently, when the time comes to change the filter, if you want to do it yourself, it appears that you'll have to actually loosen (or even remove) some hoses.
    I checked with the "do it yourself" portion of the user's manual, and it doesn't even discuss changing the engine air filter -- note: at the same time it does give a good insruct for changing the cabin filter (very surprising) :eek:.
    Am I correct in assuming that changing this filter is now more difficult?
    Has anyone done it yet, and can give direction on the procedure?
    _____________________________________
    Mark
    Model V w/ATP, Blue Ribbon Metallic, Dark Grey Interior
  2. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    I didn't change mine. but you need no tools to change it. I have removed mine a few times. You just need to unsnap all 4 of the clips then pull it towards you and then lif it up some to remove the air filter.
    2 people like this.
  3. jayrider
    jayrider Member
    163
    17
    southwest illinois
    Has anyone found an after market source for gen III air filters other than KN?
  4. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    I believe NAPA has one but it was $23.00 the Toyota Factory was less money.
    alfon
  5. Colonel Ronson
    Colonel Ronson New Member
    443
    33
    Tucson, AZ
    no aftermarkets i can find. The Toyota one is still cheaper though. $14, Made in Japan. Can't go wrong with that.
  6. cossie1600
    cossie1600 Active Member
    903
    94
    CT
    Mine looked relatively clean after 1 year and 22K miles, but like others said, it was $15 from Toyota, I am not going to cheap out on my engine for $15.
  7. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    My car is almost at 15K miles, so I was considering changing the engine air filter and the cabin air filter (assuming they need replacement after a visual inspection). I was amazed by the price variation.
    Here's the prices I got from a handful of local dealers:
    cabin / engine
    24.41 / 22.80
    37.19 / 21.40
    45.74 / 27.03
    20.00 / 21.41
    42.88 / 26.38
    For the prices that were way out of line, I mentioned this to the parts guy, who double checked and confirmed them.
    So where did you guys get an engine air filter for $14 or $15?
  8. bino
    bino JDM ZVW30
    1,348
    706
    SoCal 91739
  9. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    I show list as $21.41 and avaiable at $15.52 from Toyota Parts at toyotapartszone.com: Toyota Accessories, Toyota Auto Parts Plus shipping. About $25 shipped to California.
  10. Colonel Ronson
    443
    33
    Tucson, AZ
    If it looks clean and you have no reduction in mpg, dont worry. a dirty air filter doesn't mean dirt is getting into your engine, it just means less oxygen is getting in. The filter is designed to block all particles of a certain size, regardless of saturation. Its like a net, the more clogged it gets, the more it blocks, not lets through.
    Any toyota dealer parts website... These are their online prices. My dealer, camelback toyota, sells parts online and allows you to pick them up at the dealer parts dept for the online price. The MSRP from Toyota for the part is $18. Those dealers you called are ripping you off.
  11. cossie1600
    903
    94
    CT
    You said it yourself. The older it is, the less it is going to flow. I am not going to rob my engine of power for 18 dollars. The car is already lacking power, i need everything i can get.
    i paid 18.16 taxed for 22600 miles, i am okay with it.
  12. davidiiiii
    davidiiiii New Member
    35
    Midwest
    That is a pretty fancy air filter. What is the advantage of using this kind? Where did you order?
  13. vindicator
    vindicator Junior Member
    Rochester, NY
    The economic, ecological AND performance option is to go K&N. My '04 has used one for over 100K miles and my new '10 will get one at 20K miles
