Nissan Leaf 0-60 Time Now Official: 7 Seconds
Discussion in 'Nissan/Infiniti Hybrids and EVs' started by hill, Oct 21, 2010.
  1. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    With the estimated curb weight of the Leaf at 3500 lb and the motor at 80KW/106HP.
    The weight to power ratio is = 3500/106 = 33 lb/hp, no way the Leaf can do 0-60 under 10sec.
    It will need at least 210 hp to do 7 sec.
  2. drees
    drees Senior Member
    1,782
    247
    I think you underestimate the benefit of having 100% power without having to shift.
    As another example, the Volt has a 111 kW (149hp) motor and weighs 3800 lbs, but it will do 0-60 in 8-9s.
  3. bedrock8x
    1,483
    137
    Volt 3800/149 = 25.5 lb/hp 9 sec
    Leaf 3500/106 = 33.0 lb/hp >10 sec
    Tesla 2723/248 = 10.9 lb/hp 3.7 sec
    Prius G3 3042/134 = 22.7 lb/hp 10 sec
    Camry Hy 3680/187 = 19.7 lb/hp 8.8 sec
    adding
    Mini E........3230/204 = 15.8 lb/hp 8.5 sec (0-62)
  4. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    Really? Well car and driver just tested the two cars and says Volt 9.2 and the leaf 10 seconds 0-60. So the Volt is fater then the Prius and the Leaf is about the same. And i have read other soursces saying the same thing.
  5. msirach
    msirach Member
    321
    Southern Illinois
    My co-driver last week at Nissan North America for the preview was Tom Martin from Winding Road. Driven: 2011 Nissan Leaf
  6. hill
    8,732
    estimates of 7 seconds versus 9.8 secnds in Tom Martin's run, according to the article:
    I wonder whether some of the leaf's controllers are being monkey'd with. How else can there be such a wide variability.
  7. 1SMUGLEX
    1SMUGLEX I love the smug!
    315
    51
    Atlanta
    I think its pretty impressive. 7-8 seconds is more than enough for most people.
  8. drees
    drees Senior Member
    1,782
    247
    You're still just guessing and not taking into the account of shifting.
    Even the Prius with the PSD takes some time to build up full steam when you hammer the throttle. On an EV, it's instant.
    With nearly all test results coming in slightly under 10s - why do you insist that it must be slower?
    I think the 7-8s 0-60 the InsideLine guys is a total fluke - they must have been either going downhill or had human error in their measurements. No one else have even gotten under 9s for the 0-60.
  9. austingreen
    austingreen Senior Member
    13,664
    4,204
    Austin, TX, USA
    Not at all a fluke. Most likely a liar. Possibly just incompetent or a cheat. I find it likely someone just made up the time to see who would believe it.
  10. Skoorbmax
    Skoorbmax Senior Member
    2,641
    265
    Western NY
    7 seconds would be AWESOME, but it appears to be a unique case, so will reserve props until we know for sure.
  11. drees
    drees Senior Member
    1,782
    247
    Maybe there's a hidden "drag-race" mode we don't know about... :)
  12. Skoorbmax
    2,641
    265
    Western NY
    Maybe it actually has a gas motor to run in parallel with the electric like the Volt.
  13. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    No, there may be a fuel cell stack hidden under the hood and in-wheel motors for extra performance. :p
    Seriously, Nissan was aiming at Prius so I think it will be about 10 seconds. For highway speed passing Prius should be faster.
  14. msirach
    msirach Member
    321
    Southern Illinois
    It's strange that there is only 1 report of 7 seconds and several others have reported about 10 seconds. I was driving the car that Tom Martin timed.
  15. evnow
    evnow Active Member
    816
    155
    Seattle, WA
    2013 Nissan LEAF
    Really - you think Edmund's people are cheats ? I think they just timed it wrong - or had a different firmware.
    Nobody has measured with proper instruments yet - so we have to wait.
  16. bedrock8x
    1,483
    137
    News release from Nissan, Leaf is now weight in at 3362 lbs.
    Leaf ........3362/106 = 31.7 lb/hp
    Little improvement but still nowhere near the 7-8 sec mark.
    The guy who used the stop watch must be smoking something.
  17. austingreen
    13,664
    4,204
    Austin, TX, USA
    We don't need to wait to see that the blog was wrong. Let' me leave it to you to judge. Definitely the report lacks journalistic integrity, and since it has not been corrected, shows intent. Do you think reporting something as news that is false or misleading to drive them to your website is an honest mistake? Here is what was said.
    "2011 Nissan Leaf EV: Second Drive Shows First Impression Wasn't Wrong " Green Car Advisor
    That seems to imply he made a couple of 0-60 runs in a parking lot, which is unlikely, and that he hit a button on a watch to start a timer and another to stop it, which we find out is untrue. This is what he said when called on it.
