Rear Rattle
Discussion in 'Gen 2 Prius Main Forum' started by heimdm, Oct 20, 2005.
  1. heimdm
    heimdm New Member
    31
    When I am driving usually above 20 or so I can hear a rattle in the back of the car. Not exactly sure where it is coming from? It sounds kind of metal-ly. Any ideas?
    I have an 2005 Prius with less than 1k miles.
  2. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    - make sure your rear seats are locked in the upright position
    - check the rear luggage area and make sure nothing's floating around back there
    - make sure the tonneau cover bracket is in place
    if that doesn't work, and nothing is loose elsewhere in the car (soda bottle or whatever) take it back to the dealer. 1k is a very new car.
  3. KTPhil
    KTPhil Active Member
    1,379
    Check both the tray under the back floor, and underneath it; maybe your spare is loose.
  4. heimdm
    heimdm New Member
    31
    Thanks. I went back there and checked, and appearantly one of the back seats was back, but not far for it to lock. So hopefully that was it.. we will find out tomorrow :)
  5. davidstdy
    davidstdy Guest
    My rear cargo cover used to rattle a bit. I used blue wall puddy around the inside of the holder. Never a problem since....... :D
  6. jamarimutt
    jamarimutt New Member
    985
    Coming soon... dash rattle.
  7. DanMan32
    DanMan32 Senior Member
    3,799
    27
    Tampa Bay, FL
    "Coming soon... dash rattle. "
    To all theaters, or just a select?
