Accident avoidance and lane following -- standard?
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by bwilson4web, Jul 7, 2009.
  1. bwilson4web
    16,130
    NHTSA may impose more safety features | detnews.com | The Detroit News
    This is some of the best news I've read about vehicle safety in a long, long time. It is a sensible approach and made universal, it will bring the cost of these systems down significantly. It was the one option I wanted on my Prius but it would have cost $10,000 more due to the other 'eye candy' that I didn't need.
  2. Tideland Prius
    16,508
    and add more weight to the base vehicle.
  3. yardman 49
    yardman 49 Active Member
    606
    77
    Northern Kentucky
    I worry about how much the automatic braking could contribute to highway backups?
    Imagine that most cars on the road had this system. One car cutting into a lane could trigger a "deceleration cascade" reaction that could further contribute to those unexplained traffic backups that we all have probably experienced.
  4. Tideland Prius
    16,508
    Depends. When ggood was on the highway and some guy in a Lexus IS cut him off (California lane change from an onramp), PCS engaged the seatbelts but didn't brake so it won't cause a backup. Also, it'll let the car close into the other vehicle first (if at lower speeds). I tested the DRCC at 60km/h and it closed in before finally braking. (I had it set at the LONG setting).
  5. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    The system will do some braking in various scenarios, but its not like it slams on the brakes (other than in extreme situations). It probably does a better job of slowing to just the right speed than most humans.
  6. hill
    8,732
    I'm still missing & lamenting the Gen III (with collision avoidance) that we passed on ... :(. Trying to not dwell on that, here's another factor. From a products liability angle, it's highly likely ALL manufacturers will rush to standardize this feature, just like side curtain air bags are becoming more popular. Reason being, when technology is available, and manufacturers DON'T implement a proven safty feature ... and the feature would likely prevent the damage ... the manufacturer easily becomes responsible (at least in part) for the injury/damage. So to prevent exposure to negligent manufacturing claims, it's often more cost effective to just implement the safe feature as a standard feature.
  7. drees
    drees Senior Member
    1,782
    247
    Automatic braking is only activated when the system detects that an accident is unavoidable.
    So no, it won't contribute to highway backups. Hopefully, it will make accidents less severe so that highway backups are less severe when they occur.
  8. burritos
    burritos Senior Member
    4,946
    252
    Can you deactivate the system if you wanted to intentionally run something or someone over?
  9. bwilson4web
    16,130
    Roll up your windows so the 'beeps' won't be heard and use "R".
  10. drees
    drees Senior Member
    1,782
    247
    Don't know, but it's not going to stop you from hitting something if you want to, only slow you down before you do.
  11. Tideland Prius
    16,508
    Yes you can deactivate the system. No, I'm not going to say how.
  12. skilbovia
    skilbovia Member
    400
    91
    Massachusetts
    Has anyone actually rear ended a vehicle in a Prius Gen III with the Pre-Collision System?
    If yes, what were the details?
  13. kgall
    kgall Active Member
    984
    152
    Olympic Peninsula, WA
    How about blind spot accident avoidance? Will that be part of the gov't proposal?
  14. UsedToLoveCars
    UsedToLoveCars Active Member
    448
    102
    I agree 100%
  15. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
    Some blind spot monitor system only warns you but don't do squat. I read somewhere that Infiniti M class actually intervenes and prevents you from steer into lanes with cars in the blind spot. It also intervenes and prevents you from steer into lanes with cars fast approaching in the blind spot. Blind spot monitoring system should have been integrated into the lane keep assist on our priuses.
  16. skilbovia
    skilbovia Member
    400
    91
    Massachusetts
    I think they took the button away. The manual shows where it is on Page 250 but it's not there on my 2 week old Gen III Prius V Techno. Do you know if it's been removed totally or moved somewhere else? I do not want to disable Brake Assist. I'd just like to make sure that it's enabled so I don't find out the hard way that it's not some day.
  17. macman408
    1,179
    367
    You're probably not looking far enough forward to see the button. It's wedged way up there, and quite hard to see unless you're practically on your back on the floor.
    And no worries about whether it's enabled - the PCS warning light will be on if you disable the system.
  18. GasSaving
    GasSaving Saves $1,000/yr on gas
    52
    Boston
    Media reports hyped the non-existant unintended accelleration of the Prius.
    Here you guys are attempting "Intended accelleration" ;-)
  19. Tideland Prius
    16,508
    what macman said. Everything is on by default. If it's off, you'll see the PCS light after you press the PCS OFF button.
  20. skilbovia
    skilbovia Member
    400
    91
    Massachusetts
    Thanks for the responses. Two more questions.
    Is there any safe way to test this feature to see if and how it works?
    Will it actually stop the car and prevent an accident if the driver is totally distracted?
